Question about Brother Multi-Function Center MFC-3360c All-In-One InkJet Printer
Hi Guys I have a Brother MFC 3360C the problem is i have replace a new Black Ink Cartridge and the machine cant print black anymore it can only do color. What cause this to happen and also what is a solution for this issue Please???
  • 524 Answers
Hi...
as you repalced please check the following.
1.check weather the catridge is been placed correctly and in correct position
2.when you get a new catridge there is a protective cover placed in the outlel of the catridge so please check weather you remoced that protective coating.
3.the outlet may be blocked by the old ink which got dried up. so please clean the outlet of the catridge and try once
if may answer was usefull please vote
Posted on Jul 14, 2010
After I replace my black ink cartridge the message " install cyan..." comes up. I don't know what is cyan is. My printer is a Brother Multi-fuction center mfc-3360 c I am only replacing my...
Possibly at the time of release catrid black ink, color ink catrid position slightly annoyed and thought catrid sofwear printer cyan ink has been removed so that the request to install cyan. But it could also be due cyan ink has run out and ask to be replaced as new. Please check the contents of cyan ink may have run out, if still a full release catrid cyan and black, then attach it again, then go into maintance, and do head celean and do nozzle check or test printing
Aug 23, 2011 | Brother Multi-Function Center MFC-3360c...
Brother MFC-290c printer does not print black anymore. Test print page color ok but not black printing. What is the problem?
The problem is either:
* out of BLACK ink -- replace the ink-cartridge
* clogged ink-jets -- the ink is not spraying onto the paper, so run a few print-head-cleaning cycles
* dead electronics -- not triggering the jets to spray ink, so replace the printer
Feb 20, 2011 | Brother MFC-290C Multifunction Color...
Have replaced old black ink caartridge plus the other 3 ink colors and machine still says replace black ink cartridge which i now have 3 times now and it still repeats the same message. whats wrong?
Probably the printhead of black cartridge side in the printer is damaged in the worst scenario.Else,just clean the contacts where the black cartridge connects after snapping into the printer,with some cleaning liquid (Nephtha,CCL4)etc.I hope this solves the issue.
Aug 21, 2010 | Brother Multi-Function Center MFC-3360c...
Black cartiage is not working
Sir,
Check the black cartridge it will refill or not? open the black cartridge and shake it and reinsert. Check with printer options, if any option selected with color only uncheck it and select the best quality option.
Thanks
Good Luck
Aug 05, 2009 | Brother MFC-3360C All-In-One InkJet...
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
May 30, 2009 | Brother MFC-3360C All-In-One InkJet...
Print only black and white for brother mfc 3360c
Power off the printer.press menu and power on .do'nt release menu button until maintenance appear and flashes fax, scan and copy . type 10 . then next type 49. you will see 00000000.just change last 0 to 1. 00000001. press 99 to exit. you will find the printer only prints B/W only.
Feb 10, 2009 | Brother MFC-5440CN All-In-One InkJet...
Replacing the cart holder on a Brother MFC 240C
Somethings that have worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
2. The cartridge holder in the printer has an "electronic eye" (light sensor) of some type for each cartridge.
Some users have found that putting either permanent marker/sharpie/black PVC tape either on the area of the ink cartridge that goes near the sensor or alternatively putting tape over the sensor itself allows printing to occur.
The problem with this method is that the printer will no longer recognise near-empty cartridges and so will not warn you to replace them and so the print head may be damaged. This is said to work on LC57 icartridges used with the following models: DCP-330C, DCP-350C, DCP-540CN, DCP-560CN, FAX-2480C, MFC-240C, MFC-440CN, MFC-465CN, MFC-665CW, MFC-685CW, MFC-885CW, MFC-3360C, MFC-5460CN, MFC-5860CN.
Sep 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
Black cartridge doesn't print
you need to do a hard reset on the printer as well it might clear up the problem and recognize the ink at its proper levels.
refer to your user manual or let us know and we will find the procedure to do so.
i have a similar model and know how picky they can be.
Aug 03, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-3360C cyan ink cartridge replace ment
On the front of the cartridge there is a sight tube for the ink, the fax shines a light through this tube to detect the ink.
I wraped a piece of paper around the tube to block the light beam on all the cartridges.
I dont need a processer to tell me if the machine is out of ink, I can work thay out when it stops printing!!
Now tell me you are out of ink you peice of electronic ****.
Jun 27, 2008 | Brother Multi-Function Center MFC-3360c...
Brother mfc 210c printer
Check ink cart if it is well placed into the ink cart assy. Do the cleaning procedure by pressing INK skip the arrow-button down until CLEANING is displayed. Press start mono (blue button). After cleaning cycle you are asked by machine to print a quality test sheet. Do so and follow display instructions. Do the cleaning procedure a max of three times! When there still is no BK the printhead either is clogged or dryed out. Sorry, this cant be fixed anymore.
Oct 09, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-3360c All-In-One InkJet Printer Logo
444 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
