Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool refrigerator I have a whirlpool Mark 1 series. The problem is that the refrigerator side is not cooling properly. The freezer side is doing great. What do you think the problem might be?
SOURCE: ge refrigerator model TFH22JW problem
You most likely have an automatic defrost problem. When one of more of the defrost components fails, frost accumulates behind the freezer wall and restricts airflow to the fresh food side. You will still generate cold into the freezer section but will have virtually no cold to fresh food side. If it is a few years old it is most likely the defrost heater which is defective. Replace the defrost thermostat (bi-metal) as well.
Posted on Oct 02, 2007
fridgetech
  • 473 Answers
SOURCE: refrigerator problem
3 most common things that cause this are a defrost problem (will notice frost build up on back freezer panel), bad evaporator fan motor (should hear fan running in the freezer), or bad damper (vent to the fridge section). If no frost and fan is running check for air flow out of the vent. It should be at the top of the fridge section.
Posted on Oct 05, 2007
catriver
  • 878 Answers
SOURCE: Whirlpool Refrigerator - Model# ED22LF
Tom, I would start with the overload and relay that is on the compressor, If it is white it's a good possibility that it has failed. The fact that both sides are not cooling leaves me to believe the compressor is not operating. Take the overload and relay off. If they are both contained in a white cover shake it. If it rattles, I believe that is your problem. Let me know what you find...Catriver.
Posted on Jun 28, 2008
mikedurland
  • 481 Answers
SOURCE: whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 29, 2008
  • 9 Answers
SOURCE: my refrigerator is not cooling the freezer is working
please check the rear interior freezer wall to see if there is any ice built up.If yes,that means you have a defrost heater problem.The defrost system consists of 3 components,1)defrost timer,2)the actual heater(which is located right inside the evaporator coil compartment),and 3)a terminating stat(which shuts off the the heater before the heat cycle ends to prevent overheating).There are ways to test this with a volt and amp meter. So,if this is the case,and you need a temporary fix,and I do mean temporary,(3-5 days)you can turn off the fridge for 24 hours and leave just the freezer door open until the ice melts,OR unplug fridge,then remove the interior back panel of the freezer and melt the ice by pouring hot water over the iced up coils(CAUTION:DO NOT POKE IT WITH AN ICE PICK OR ANYTHING,YOU WILL MAKE A HOLE IN THE EVAPORATOR).after ice is melted,reassemble rear panel plug it in,and it will buy you a few days. In a refrigerator, all the cold is produced in the freezer section,then through a small hole in the dividing wall,a small percentage of cool air is blown into the fresh food section.When the coils do not defrost 3-4 times a day like they should,the air cannot pass thru them and no air will be delivered to the fresh food section. Now, if you don't see any traces of ice buildup,you may have the air exchange door in the wrong position.The air door is a little door that determines how much air is passing thru to the fresh food section.Most fridges have the selector with either numbers or letters.Example A-B-C-D-E OR 1-2-3-4-5.Now when this air door selector is in the "1" or "A" position it means the maximum amount of cold air is going to the fresh food section,which in your case,is where you want it to go. Anyway if this is the case with you, after you have made the adjustment,please wait 24 hours to take effect,it's a slow process. I hope these suggestions help you. I know I probably gave more info than you needed to know. Good luck
Posted on Aug 26, 2009
My Whirlpool Mark Series Model # EB19MK is not cooling or freezing. Compressor is working, fan is working. Does it have reset button?
No reset of that kind. Did you loose cooling gradually over several days? if yes, you may have a problem with the defrost system causing an excessive frost buildup in the freezer section. symptoms would be excessive frost on freezer back wall. Possibly a bad defrost heater. Replace defective part and manually defrost refrigerator before re-starting.
May 24, 2015 | Whirlpool Refrigerators
Fridge not cooling whirlpool model gd5rhaxn000
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Aug 28, 2011 | Whirlpool S20DRSS33 Side by Side...
Whirlpool gold refrigerator is not cooling ice build up in freezer. Water on bottom of refrigerator.
Too much build of ice in freezer will not cooled the refrigerator side, you need to defrost the fridge. Set it to proper temp setting, just enough to have ice on the freezer and also remove water on the bottom.
Thanks for asking.
Jun 24, 2011 | Whirlpool Refrigerators
Whirlpool refrigerator is not getting cold but the freezer is. The freezer is located below the refrigerator.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 23, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
1 month old whirlpool refrigator is almost 60 degrees in frig part and 10 below zero in freezer side
It sounds like one of two things, either the evaporator fan is not running(fan in the back of the freezer behind lower back panel) or the bi-metal thermostat that may be in series with it is open..
Also some newer models use a lower voltage fan motor, use to be all were 120 volts........
It is under warranty for one year so call for authorized service to repair it......
(all of the cooling on the refrigerator side is done by air circulating from the freezer side, also possible there is ice blocking the air flow somewhere)
hope this helps
Feb 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frig is very hot on the outside ban that meets the seal
That heat that you feel is part of the design of all refrigerators. Those heaters are there to keep water from condensing on the outside of the cabinet around the freezer door. Just like water condenses on a cup of Ice water. It will do the same on a refrigerator. If those small heaters were not there. The water would cause the paint to rust badly. There are various arrangements of heaters used on Freezers and refrigerators around the doors. Particularly the Freezer door.
As long as the fridge is cooling properly it is fine.
If the fridge fails to get cold, the outside of the cabinet will actually get quite hot.
Hope this helps,
Best, Mark
Dec 28, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Cooling problems with OLD Whirlpool ET20MK refrigerator.
top up the freon gas charge you have a low charge
Jul 19, 2010 | Whirlpool Refrigerators
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
213 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
