My Rinnai 2001 heater turns off after about 10 minutes and will not re light for about 20 minutes.
  • 70 Answers
SOURCE: Rinnai 2001 Gas Heater - turn off
when the repair guy cleaned water heater did he run white vinger through the coil inside the heater. Does the control pad show any errors
Posted on Apr 18, 2008
SOURCE: Rinnai 2001 space heater: stuck dial
mine did a similar thing, when in off position, it would only turn to pilot/ignite, but would not move past this point. I took off bottom cover to locate regulator. where the slector knob shaft meets the regulator, try spraying wd40 in the top of regulator where square shaft goes into reg. There is a saftey lock mech in there, and in my case it was stuck in the locked position. I then worked the knob back and fourth applying alot of pressure, but not enough to break the knob. it worked after a few tries, and lights and functions normally, locking again if pilot goes out. good luck.
Posted on Jun 28, 2008
SOURCE: my rinnai 556fa propane heater
I had the identical trouble with my Rinnai 431F just now & read the unanswered posts.
I checked my intake & exhaust & found them connected & intact then went out to check the exterior vent assembly. The "bell" or dome was almost entirely clogged with ice.
I suspect the 60 - 76 lights flashing means insufficient combustion air.
Anyway, I took a hair dryer to it & in 10 minutes it was working as well as ever.
This won't help you October posters but if anyone else has this problem in the future I would start with the outside vent assembly. Get a good look right up inside because I would have missed this ice if I didn't get up close with a flashlight.
Here's a good source for manuals too...
http://www.houseneeds.com/products_rinnai.asp
I'm going back to bed.
M.
Posted on Dec 22, 2008
  • 126 Answers
SOURCE: Rinnai heater turns itself off
Dannizen,
You could have something as simple as an air hose off, or a piece of carbon on the flame sensor. Your problem could also be a gas valve , which is much more complicated. If you are handy with tools you could be able fix either quickly. If you’re not good with tools you will need to get some help. Either way you have to have some back ground info on your heater. Get in touch with Rinnai and get a service manual for your unit. They cost around $15. If you have to call a service guy, use the Rinnai web site to find an authorized service person. Don’t just let your fingers do the walking and get some guy who has no idea what a Rinnai is. You’re only asking for trouble there. Your unit is a little older so don’t be surprised if parts are hard to find.
Good luck,
Tom Hawkins
Bethel, Alaska
hawkins111@gci.net
Posted on Mar 07, 2009
  • 148 Answers
SOURCE: we have a Rinnai 2001 heater, pilot and gas are
could be the the bearings starting to dry up see if you can oil it
Posted on Jun 25, 2009
Rinnai wall heater lights but in about 5 or 10 minutes makes a wind blowing noise and goes out. Including the pilot lite.
The model number would be nice to know! I am concerned about the way you say it is vented.
Dec 07, 2016 | Rinnai Heating & Cooling
Rinnai RL94i - Produces hot water for 3 minutes, then stops
I just had this exact problem. It kept getting worse until we had no water. Our Rinnai tankless hot water heater started the same way though, with hot water for a few minutes and then would shut off with an error code 10. We just had to shut the hot water off and then back on, wait a minute or so and we had hot water back for a few minutes. Our unit would come on with a loud vibrating noise and remain until it shut off with an error code 10 (air flow fault). The solution was to remove the blower fan and blow out the squirrel cage. Ours had moths in it. We also vacuumed out the fan housing. Be careful to mark any wires you disconnect and take pictures before removal. Our unit is now almost silent when it comes on and supplies endless hot water.
Jun 10, 2014 | Rinnai RL94i Tankless Water Heater
I have a Rinnai RCE-329H gas heater that keeps turning off.
Check..for gas pressure creep.....2 lb sys....big problem...change to green hat....pig tail line.....rinnai gas valve problem being fixed....
May 31, 2012 | Heating & Cooling
Hi there I am trying to help a friend who has a slightly older version of the Rinnai Timberflame Centrum and he was cleaning the controls on top of the heater and in doing so has pressed one of the...
Sue, have you friend turn the Master ON/OFF Switch to OFF and unplug the heater from the electrical outlet. Wait 15 - 20 minutes and plug the heater back in. Turn the Master ON/OFF Switch to ON and the heaters electronics should revert back to the original factory settings. From there he can reset it to the settings he had, before the little mishap.
Hope this helps solve the problem. Please let me know. Thanks.
May 17, 2011 | Rinnai Heating & Cooling
How do you light the rinnai glo-ray heater
Without pushing in the knob, turn knob to "IGN" position, THEN press and hold in knob while in that position, repeatedly press "Ignitor" button. (If it's the first time you've lit it, it may take up to 5 minutes of doing this to get the gas line supply full enough to light the pilot.) After the pilot is lit, continue to hold in "IGN" button for 10 seconds, then release, then you should be good to go.
Nov 22, 2010 | Rinnai Heating & Cooling
My Rinnai infinity 20 water heating is not lighting
Just joined fixya and am a Rinnai service manager in Australia. Is this still an issue?
Apr 11, 2010 | Rinnai Digital Remote Water Heater Control...
My rinnai 556fa propane heater
M.
Oct 29, 2008 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
Rinnai fan stops turning.
You can reach the fan wheel by using a can of compressed air normally used to clean your compute keyboard. Make sure you hold a vacuum wand close to the heater when doing this to collect the debris. Using a small coffee stir straw, lubricate the end of the fan motor shaft with light motor oil. This will keep the motor alive for a bit longer.
Aug 13, 2007 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Heating & Cooling Logo
89 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
