Question about Gateway Audiocodes MediaPack MP108-FXS 8 Port VoIP Phone
I have Audio Codec MP-108 voip Gateway and i dont know it's ip Address how do i retrive its ip address
5 Suggested Answers
SOURCE: I'm having trouble acquiring an
I had to bring my computer to an expert, they have to re configure the hard drive because of symantix
Thanks
Posted on Oct 02, 2008
EmmettPinger
  • 63 Answers
SOURCE: Says I have an invalid IP address
Go to control panel select network right click icon go to tcp/ip properties and choose get ip address automatically DHCP
Posted on May 01, 2009
crok41
  • 621 Answers
SOURCE: laptop will not find ip address
Try updating the wireless driver from manafacturers website or if youve already done this uninstall the driver in device manager and reboot the laptop. This will auto reinstall the driver with all the default settings. If still having trouble reset the wireless router see how it goes with no security settings to start then just leave at minimal depending how much security you need. Good luck hope this helps
Posted on Jul 11, 2010
jadiazq
  • 2878 Answers
SOURCE: audio codec for gateway M6843
K-Lite is the best and most powerful codec packs out there. Not to mention free.
Posted on Oct 01, 2012
How to configure my router
Just Google
make model set up manual.
You set it up from a computer by logging into it.
Open a web browser such as Internet Explorer.
Go to the Address bar and enter the IP Address of your router then press Enter. For example, 192.168.15.1 is the default IP of most VOIP routers.
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/spa8000-8-port-ip-telephony-gateway/108646-setup-voip-108646.html
Dec 04, 2017 | Computers & Internet
Unable to access a fresh Audio codes box via http using default IP address.
What IP address are you pointing at? 10.1.10.10? 192.168.0.1? try with 10.1.10.10 and worst case scenario install wireshark on your PC and take a trace when connected directly to MP and power it on, there you will see some bootp messages (IP address 0.0.0.0) and after that you will see messages from MP announcing its IP address. If device is brand new you should login fine using Admin / Admin. Beware that some internet explorers do not allow login even with right user/password, try with a couple of them.
Aug 22, 2011 | AudioCodes MediaPack MP-114 FXS and FXO...
How to get the ip adress from a linksys rtp300 phone adapter
I'm not sure if your asking for the IP ADDRESS of your Linksys or the DEFAULT GATEWAY of that device because your router's ip address will be provided by your server or Internet Service Provider (ISP) depending on your service. There are two ways of obtaining an ip address first will be DYNAMIC, where your ip address changes all the time and STATIC where you are given specific ip addresses for example 192.168.0.1 -to 192.168.0.25. The easiest way to obtain those ip addresses, by the way, is to contact your Internet Service Provider (ISP)
example: AT&T, Roadrunner, Time Warner, etc....
But, if your looking for the DEFAULT GATEWAY for you to access your router's configuration, most of the time it is found underneath the router itself. For Linksys the Default Gateway is 192.168.1.1
>I hope i helped you out with this... Enjoy!
Sep 15, 2010 | Linksys VOIP PHONE ADAPTER 2-PORT (PAP2NA)...
How can I retrive my password or wep key off my Belkin wirelless router I bought a new laptop and can't acess my router
Connect your laptop to the router with a network cable and type 192.168.2.1 into your internet browser address field. You should get the router maintenance page, which gives you access to the encryption and security functions.
Please come back with a comment if that does not work.
Mar 26, 2010 | Belkin (F5D8231-4) Wireless Router...
AudioCodes MP-11R/2FXS
The easiest way (if enabled) is to use the voice menu as if you would assign a new IP to the device.
  1. Connect a telephone to one of the FXS ports. Lift the handset and dial ***12345 (three stars followed by the digits 1, 2, 3, 4, 5).
  2. Wait for the 'configuration menu' voice prompt to be played.
  3. To change the IP address, press 1 followed by the pound key (#).
  • The current IP address of the gateway is played. Press # to change it or hang up if you don't want to change it.
  • Dial the new IP address; use the star (*) key instead of dots ("."), e.g., 192*168*0*4 and press # to finish.
  • Review the new IP address, and press 1 to save it.
Of course you can try the default IP of 10.1.10.10 if the device is set to it's default standards.
If not, you can try a network scanner like angryip (link) or network scanner (link) - this might take a long time, since the IP can be virtually anything.
If you have physical access to the device, you can also use a straight RS-232 cable to connect the AudioCodes to your PC and use HyperTerminal to connect (Baud Rate: 115,200 bps (MP-124), 9,600 bps (MP-11x), Data bits: 8, Parity: None, Stop bits: 1, Flow control: None)
If you need the manual (and it never hurts ;-) here is the link:
http://www.audiocodes.com/filehandler.ashx?fileid=36320
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 22, 2009 | AudioCodes MP-112R/2FXS/3AC/SIP-3/UC...
Lost ip address so can't connect to wireless
If you are able to connect to the router via Ethernet cable, connect, go to the gateway ip address and you can retrive the IP address info from the routers configuration page.
Good Luck.
C2Solutions
Jul 30, 2009 | Acer Aspire One A150-1006 Notebook
Dont know ip for my Sharp AR_C270 i just bought
Find out what the gateway setting are on your computer and assign an ip address based on the gateway.
For example if your gateway is 192.168.0.1  then a good ip address would be 192.168.0.XXX.  xxx=available ip address to use.
Your copier does have a DHCP setting that allows the router to assign on automatically for you if the copier is connected to one but you should assign that ip address manually after using DHCP because if the power goes out, it could assign a different one than the previous assignment making the IP port assignments to print with on your computer useless without creating a new port.
Oct 19, 2008 | Sharp AR-C270 Color Copier
I have a Netcomm NBPlus 4 Wireless Modem/Router and I have now bought, in addition, a D-Link DVG 1402S VOiP Router. I seem to have a problem getting the two to talk to each other prior to configuring the...
Set one of them up in bridging mode.
To get to the admin screen, check the bottom of the voip box to see if it's accessed through another IP.
If you have the voip router plugged into the Netcomm router, the IP address to access the voip is going to be assigned by your netcom. Assuming the voip router isn't serving dhcp addresses (i.e. 192.168.1.100, 192.168.101 and so on)
FYI: Be sure you don't have both routers set up as dhcp servers.
You can acquire the voip router's ip from the admin interface of your netcom router.
If you are wanting to get them to talk to each other through entirely different IP addresses (subnets), create a route in your netcom router for your voip router. Bridging mode may make things easier for you.
Going back: If you have your netcom dishing out ip addresses to wireless and cable users, and you plug in the voip router to the netcom router, your voip router will receive an ip like any other computer on the network. Thus will use the netcoms ip as the default gateway and it gets messy after that --lack of connectivity.
Nov 15, 2017 | Computers & Internet
Internet Exporer
"Obtain ip address automatically" indicates that it will use DHCP. DHCP will also provide the Internet Gateway address, which is required to access anything outside your local subnet (like the internet). You can set your IP address manually, but you also have to enter the Internet Gateway and DNS server addresses ( and you have to know what those addresses should be for your pc ).
Feb 17, 2008 | Computers & Internet
158 people viewed this question
Top Gateway Audio Players & Recorders Experts
Kolbrun...
Tom Chichester
Are you a Gateway Audio Player and Recorder Expert? Answer questions, earn points and help others
