Question about HP Photosmart C5180 All-In-One InkJet Printer
Not networked properly
I've had my C5180 networked via usb, but occasionally when I try to scan something, it says it is not networked. It then says I can only "scan and reprint" or "scan to memory card". In the past I would get a full menu of scanning options, such as scan to word doc but I no longer have that option.
    Scholar:
  • 53 Answers
Solution To resolve the issue, follow the steps in the solutions below in the order presented. Solution one: Scan from the EWS (Embedded Web Server) Verify that the product can scan and is connected to your network by scanning from the embedded Web server (EWS) on the product. Use the following steps to scan from the EWS:
  1. Print a Network Configuration Page from the product. NOTE: See the product documentation, User Guide, or online resources for information on how to print the Network Configuration Page.
  2. Locate the IP address.
    • Check in the Wired section if the product is connected with an Ethernet cable
    • Check in the Wireless section if the product is connected using a wireless network connection.
  3. Make a note of the IP address found in the appropriate section (wired or wireless); for example, 192.168.1.1.
  4. Open the Web browser.
  5. Type the IP address into the address bar of the Web browser (such as http://192.168.1.1) . Then press Enter . The EWS for the product opens. If it does not open, STOP and click here to check the network connection between the computer and the product (c00047176) (in English).
  6. If the EWS page opened, find the Scan on option.
  7. Click Scan to perform a scanning operation.
  8. If you can scan from the EWS and not from the HP Director/Solution Center or from the product front panel, then continue to Solution two.
Solution two: Check the personal firewall settings When the firewall program is re-enabled after installing the All-in-One software over the network, it may block HP programs or ports required for scanning. If you see pop-up screens asking you to permit access to the network when you try to scan, you should permit access. NOTE: Firewall programs may also block the scanning operation even if they were enabled while installing the All-in-One software. Firewall programs do not always provide messages when blocking access. Follow Step one to allow access to HP program files and ports needed for scanning. Step one: Add programs to the firewall exception list
  1. Open the firewall program.
  2. Add the following files to the Highly Trusted programs list:
    • hpqkygrp.exe , located in the C:\program files\HP\digital imaging\bin directory.
    • hpqscnvw.exe , located in the C:\program files\HP\digital imaging\bin directory.
    • hpqste08.exe , located in the C:\program files\HP\digital imaging\bin directory.
    • hpzipm12.exe , located in the C:\windows\system32 directory.
    • hpzinw12.exe , located in the C:\windows\system32 directory.
    • hpqtra08.exe , located in the C:\program files\HP\digital imaging\bin directory.
    • hpqthb08.exe , located in the C:\program files\HP\digital imaging\bin directory.
  3. If these files are already added, check whether full access has been granted to them.
  4. Open the following ports on the firewall utility by following the instructions provided by the manufacturer:
    • UDP ports: 161, 427 and 137
    • TCP ports: 9220, 9500 and 9290
Step two: Restart devices on the network After making the changes to your firewall application, turn off the All-in-One, the computer you made the firewall changes on, and your router, and then turn on these devices in the following order:
  1. Router
  2. HP All-in-One device
  3. Computer
Posted on Jun 09, 2008
Sharp MX-2300N Color scanner can't find network
Drivers are for print functions only (or twain scan via USB). Check for bad cable, port, or jack. Could be another device on the network is being handed the IP of the copier via dhcp (or vice versa) can you ping it from a workstation? I have also seen the dell network assistant utilities on some dell workstations cause issues like this.
Jan 11, 2013 | Sharp MX-2300N Color Copier
Can the C5180 be used as a wireless printer?
if its connected via usb to a desktop pc that is left switched on then yes you can print to it from a wireless computer. You just need to share the printer on the pc that its connected to. Then add a printer on the wireless printer and choose network or wireless. You also need to enable file and printer sharing on both computers
Apr 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
My 3210 will not scan
I now have 2 of these and both print ok but can not scan with either, never tried to till now.
I have re- downloaded the driver from HP.com via Internet Explorer (usually use Mozilla Firefox) and i get 2 diff. error messages : network busy (impossible since it is connected via USB) and the 1 at my office connects wirelessly but error message is something to do with software.
Thanks!
Nov 02, 2008 | HP Photosmart 3210 Printer
HP Photosmart C5180 Cant upload pics from the memory card slots
Didn't try via USB. Via ethernet connect i can reach the card reader by entering '\\printer' in an explorer window. You can find the name of your C5180 on the network settings in the printer menu.
Hope this helps
Jul 31, 2008 | HP Photosmart C5180 All-In-One InkJet...
Modem are not connect in reliance netconnect
if you can, remove and reinstall the modem and/or the program.
look at the cable fittings and see if something is broken or bent.
try your local geek network online.
go to your usb port settings and see if it is reading the proper link to your modem and see if your modem is recognized.
may be the network settings you have. in conflict with your modem and network router.
May 21, 2008 | Computers & Internet
SCAN to pc useing Copystar 1820
please specify how the machine communicates with computer (network, USB cable, or parallel cable). once this is known I'll be able to tell you how to setup the scanning.
As for the 2nd question, yes this machine does support vista, both 32 and 64 bit
May 14, 2008 | Kyocera Copystar CS-1820 Black and White...
Does HP LJ 3055 printer scan over the wireless network?
Scan over wireless network is not supported with this printer. You can try set it up and get scanner to work with usb and then change port from usb to HP standard TCP/IP for the device, but I don't think it will work.
Apr 08, 2008 | HP LaserJet 3055 All-In-One Printer
Getting error when trying to fax or scan
The L7580 is not meant to be set up as a scanning device on a network. This unit can only function properly as a USB connected device to have all the features work. Also, for the software to install with out problems, all other All in One software fro previous HP printers need to be removed. Once we did that and did clean install using USB only then did it work.
Mar 03, 2008 | HP OfficeJet Pro L7580 Color All-in-One...
Scannen c5180 by ethernet
Have you tried connecting to your printer through the EWS (a direct connection using the printer's IP address). If you manually set up the IP to say 192.168.1.205 , then you would go to your browser and type http://192.168.1.205 which would then bring up the EWS page. This gives some general information for setup & basic testing including scanning. My C5180 has the same networked issue, a port scan reveals loss of connection on UDP.
The C5180 appears to use UDP: 161-SNMP,137-Netbios,427 Server Location.TCP: 21-File Transfer,80-www HTTP,139-Netbios Session service,9100-HP JetDirect card,9500 ISM Server.
Jan 13, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
354 people viewed this question
Seeker5211
Seeker5211
