Question about Diesel Audio NS-1600 Car Audio Amplifier
Diesel car amps not working
I have a NS-900 4 channel and only one channel is working.
I also have a NS-1600 2 channel it is not comming on at all.
could you tell me whats wrong?
    Genius:
  • 1,139 Answers
Hello Rudnette,
With out being given much information to work with I can only give you a basic run down of what the problem might be. It sounds like the MOSFET amplifiers have blown out on those channels that are not working. Did your system become ungrounded at some point while it was playing, and or did you have some kind of power surge?
Let me know the conditions under which the problem happened and I might be able to provide a better analysis.
Thank you,
Shuttle83
Posted on Apr 22, 2008
On the Insignia TV remote, how do I get back to being able to choose channels with Direct TV remote?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code
Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
Nov 28, 2015 | Insignia Solutions Original INSIGNIA TV...
I have a Yamaha AX-900 Integrated Amp that I puchased back in the late 80's. It still works great, with one exception. The left channel is not as loud as the right channel and I have to put the balance...
Hi...
The tone control circuit has "issues". Could be a bad interconnect or a failed pre-amp chip.
If you dont mind putting about $100 into it, get it looked at
Sep 30, 2010 | Yamaha P-1600 Amplifier
I have a 250 watt / 4 ohm subwoofer i have a diesel 700w amp / 2 channel / hpf or lpf with bass boost. i dont have speaker wires and want to utilize my to speakers in the back of my 2008 mustang to...
if you are trying to use it with the stock headunit you would need to buy a line output converter to use your amp and sub. after you buy the converter you will then need to splice into one of your rear speaker wires so you can run the rca's to the amp and continue with normal install
Aug 10, 2010 | Diesel Audio NS-700 Car Audio Amplifier
My amp will not power up
try hotting your remote wire to your batter if it don't come on u will need a new amp
Jun 14, 2010 | Diesel Audio NS-1000 Car Audio Amplifier
Why does the hifonics bxi1608d 1600 watt super D-class mono have 2 postive terminals and two negative terminals? would that cause my speakers to blow?
That is still a single channel cass D amp. Each (-) and each (+) terminal are connected so its actually like only having one. This is so you can hook speakers up in a series circuit to lower impedance, because this amp is 1ohm stable. What causes your speakers to blow is too much power. What kind of speakers are you running? This hifonics amp is very powerful, they are getting big in the competition industries beacuse they put our true power for less money and they are tough. That 1600 amp you have may be putting out more like 1800 watts at 14.4 volts which is 900 per sub at 1ohm so be careful this amp has tons of power and its true rated its not like a sony or rocksford or kenwood that says 1800 max and then in small writing it says 500 rms. This amp puts out true. I have 3 hifonics amps and love them.
May 07, 2010 | Hifonics BXi1608D Car Amp
Best car amplifier
I've got a boss 1600 watt 4 channel amp ,720rms watts. up for auction on ebay right now that would work great. brand new in box. check it out. http://shop.ebay.com/?_from=R40&_trksid=p3984.m38.l1313&_nkw=boss+1600w+amp+4+channel+with+level+remote&_sacat=See-All-Categories
Oct 05, 2009 | Cars & Trucks
1600 watt pyramid royal blue 2 channel amp need diagram of amp itself
if i keeps blowing fuses then it means the amp is bad
May 12, 2009 | Car Audio & Video
Speaker amplifier calculation
for $85 i can sell you an Almani 900 watt 2 channel amp i would stay way away from those 3 brands they are all really poor quality and i can get you any major name brand cheaper.
I can get you a hifonics 4008 amp (800 watts peak 100 watts per channel rms) for $100 shipped with full factory warranty. you find an amp you like and i will get you a price. I am a factory wholesale distributor for most brands.
Jan 08, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
NS- 1600 amp
You need to use a multimeter to confirm that you have a good ground and sufficient voltage on the B+ and remote wires. I'll assume that you've checked the on-board fuses (if it has them).
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v and the amp does nothing, the amp probably has a blown power supply.
May 03, 2008 | Diesel Audio NS-1600 Car Audio Amplifier
Diesel audio NS-600
it can be done providing it isn't driven too hard.
May 19, 2007 | Diesel Audio NS-600 Car Audio Amplifier
Diesel Audio NS-1600 Car Audio Amplifier Logo
109 people viewed this question
Top Diesel Audio Car Audio & Video Experts
armando martinez
Level 1 Expert
Tom Chichester
Are you a Diesel Audio Car Audio and Video Expert? Answer questions, earn points and help others
