Question about Thomson GE 27907GE1 Cordless Phone
Thomson colour tube is gone
I HAVE THOMSON TV FROM LAST 12 YRS NOW IT IS NOT WORKING AS ITS COLOUR TUBE IS GONE SO COULD YOU PLS HELP ME HOW CAN I GET REPAIR PICTURE AND SOUNDS ARE ALL WELL WORKING SO WHAT SHOULD I DO HELP ME
  • Thomson Master
  • 17,130 Answers
If you had mentioned that the picture tube is defective and confirmed it is a serious fault. You can rejenuvate the picture tube with a gun tester and short remover.This is not a confirmed solution but you can take a last try. Changing the picture tube is not recommendable for an old set and I would like you to go for a new Tv which will work out cheaper and gauranteed.
Hope you decide sensibly. Good day
Posted on Jul 14, 2010
The colour has gone green and purple
I will start with a simple deduction that one primary colour has gone, the set has three Red, Green and Blue with this and our easily tricked eyesight we make other colours.
To me if this was a hulking glass tube type TV I would think one of its tube guns has stopped working this can be the chroma drive IC or more likely an out put which is mostly transistors mounted on the tube base gone bad or dry joints in this area. A tube can go but they mostly age and go off colour over time, I have also seen sets have power supply troubles which causes a low supply rail this results in some very strange events. A hoover started up in front of the screen can magnetise it as can a child with a strong magnet moving it around on the glass, a set will try to cure these last two each time its switched on (degauss) though the magnet one will be harder to cure! I am afraid it would need a service call to determine if its a joint or small part it may then be worth it, while a tube problem forget it. Also if this is a flatscreen then its possibly not worth it anyway, if its the screen+output IC set up, a screen is about 66-75% of a flatscreens build cost. On the other hand if its the main circuit board all an engineer can do is replace it with a new one (if around) because they are made in such a way with machines a man with a soldering iron stands No Chance. Hope this helps.....
Feb 15, 2015 | Televison & Video
Red colour on screen
if crt pic tube magnitized need to degausse with coil
Jun 01, 2010 | Thomson 21DC320 21" TV
Red colour appearing on screen
Your tv could have one of several faults. None of which are to be tackled by anyone except a qualified engineer due to the electric shock hazard.the first problem could be the crt (tube) the second could be the componets on crt base circuit board ie resistors or ic.
With a tv 9 years old it may not be economical to carry out a reair.
Lost sound on my GE (Thomson)46GW947X1
pls. first open your tv menu and select sound & colour -sys see the sound-sys / colour-sys is maching with your country transmitiongh sys {EXP.: PAL-BG / NTSC-DK /NTSC- MN /SCEAM- I ) IF your not set purfictly pls select AUTO colour sys and set automaticly set colour & sound .[see user's menual book and set your tv.]
Oct 06, 2009 | GE 35GT695 TV
Thomson Scenium 52''Rear Projection TV set -
you have a laser that has gone out blue or green take the face off and see which of the colors you need you can still find lasers on ebay if you need one but it will require someone with a little expertise to replace them. if this is not for you then its time for a new TV this is probably the best option its more expensive to fix in most cases than to replace..........I hope this helps
Jul 20, 2009 | Thomson Televison & Video
Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
May 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Help
try mcm electronics there were a rca dealer
Feb 01, 2008 | Televison & Video
Television cannoy be turned on
i think you have weak picture tube. when gun becomes faulty this happens. Measure Red -Green-Bluue cathode voltages. and filament voltage.if everything is perfect then the problem with your picture tube assembly. Contact service centre for further rectification
Dec 22, 2007 | Televison & Video
Thomson tv
http://online.projectordoctor.com/Projector-TV-Lamps
http://beamerlampen.biz/projector-bulbs/projector-lamp-Thomson-44DLW617-Nr-5400.html
Dec 07, 2007 | Televison & Video
TV Screen Gone Green Red Yellow etc
 would this be the picture tube?
no, not at all.
it might be due to change in direction
 or some body might have turned  tv direction
or any magnetic thing might be near tv.remove it like speaker or headphone etc.
put off tv for 30 minutes & see it will be ok.
hope this will help.
good luck.
Oct 15, 2007 | Televison & Video
Thomson GE 27907GE1 Cordless Phone Logo
148 people viewed this question
Top Thomson Lands Phones Experts
David Burbee
David Burbee
Are you a Thomson Lands Phone Expert? Answer questions, earn points and help others
