Question about Fuji Pictrography 4500 Thermal Printer
Check water level on Fuji 4500 printer keeps showing on panel. I have changed water and water is at proper level. I have repowered printer many times and an error E211 came up one time. Please tell me how to fix. Thanks! Bill
  • hydrobill22 Jul 18, 2010
    Fuji 4500 Pictrography printer shows " check water level". I have changed water repowered the printer many times. Thwater is pumping into tray and draining when power is off. Is there a way to check water bottle senser? The machine is used in moble printing and was level.Is there any tricks in replacing the water bottle senser?
    Bill
  • Fuji Master
  • 6,826 Answers
According to a post I read on the Fuji 4500 printer, the printer must use distilled water and there is a hose kit that must be periodically replaced:
http://photography-on-the.net/forum/showthread.php?t=460639
On this post the author says the following:
Check water level on Fuji 4500 printer keeps - icon1.gif Re: Fuji Pictrography 4500 I use to work for Fuji and actually repaired these. The price is about right. It is worth between 2000 and 3000. The 4500 is the last of the PG's and no longer made. They are very reliable and phone support is free. You will not get a live person for phone support and they will call you back. (Eventually). If it breaks...Good luck getting a tech to repair your machine UNLESS you register the machine and get an account set up. Even if you do that GOOD luck getting a tech for repairs. You are not a Walmart and you are on the bottom of the list. You need donor and reciever to make prints (expensive material)
Make sure the laser is calibrated. As far a maintaince, just change the hose kit on the maintaince cycle and use the recommended water. ( I believe it uses distilled water only.
Did I say parts for repair are EXPENSIVE !!!! Did I say a Service Repair tech is EXPENSIVE !! Did I say not all techs know how to fix these in the field or on the phone
Why use Old techology and no warranty.
I would go with the ASK 4000 for 2500 at B and H. The PG 4500 IS BIG !!!' --- I hope this post helps!
Posted on Jul 18, 2010
  • hydrobill22 Jul 20, 2010
    I have a Fuji 4500 and a Fuji 4000 early model. I up graded and now using the 4500 because I am using a PC. The check water level warning keeps coming up. I changed water and I have been using distiled water. The water pumps thru the printer and drains when the power is off. I ever changed the water bottle senser and still shows this error. Is there another senser that detects this condition/ What else wolud you suggest? Please reply ASAP.
    Thanks!
    Bill
    Please read my last statement.
    Thanks!
    Bill
  • Fuji Master
  • 19,396 Answers
Hi Bill.
Disconnect power, empty water, and check for clogs or blockage in the water supply hose running from the water bottle. If that does not fi the problem you may need to replace the water cartridge or the sensor. In that case you will need to contact Fuji at the number listed on manual, to arrange repair or to get the parts.
Posted on Jul 14, 2010
  • hydrobill22 Jul 15, 2010
    I have turned power off and restarted it. Refilled water tank and changed filter. The pump does pump water in the tray and dumps it when you turn the power off. I just purchace this printer and it worked a few times. I am using this printer as a moble printer in a van to do special events. I was very warm when I got the E221 error code. What are yuor thoughts?
    Bill
How do you change the date on fuji finepix 4500 bridge camera
You may download a copy of the manual here. The date/time instructions are on the setup menu, described on page 99.
Oct 13, 2012 | Fuji FinePix 4500 Digital Camera
Reset 4500 hp estimated inklevel
The best you can do is, Disconnect the power cord from back of printer ( while printer is on ) and reconnect after 30 seconds.
This should help you in displaying ink level on printer front panel and also from solution Center on your pc ( if the complete software is installed )
Basic software installation or just connected to PC will not display ink level on your PC Screen
Regards,
Suhail
May 17, 2012 | HEWLETT-PACKARD Officejet 4500 All-in-One...
Will start but will stay running
there are a couple things to check -- first check and drain the carburetor bowl,, there could be water and other contaminates inside that are not allowing the carburetor to perform correctly. this start and not stay running problem could also be caused by a bad ' governor ' . ----- BUT the problem may be also caused by a bad oil level/pressure safety switch,, check to make sure the oil is at the correct level and then check the switches to make sure they operating properly.
c...
Jan 17, 2011 | Hobart Champ 4500 Welder/Generator Outfit...
Does the Fugi Pictrography 4500 wont print
Buy distilled water from the grocery store for $1.00 and then clean out the water tank and refill to the fill line. Change the water filter every 6 months (according to the manual). Clean out the water hoses by ramming soapy chopsticks through them and then forcing some water through them.
Mar 06, 2009 | Fuji Pictrography 4500 Thermal Printer
Printer drivers fuji pictography 4500 mac 10.5.6
On the link below there are all drivers available for your printer, if you do not find MAc OS 10.5, then try 10.3x, if printer still does not work, then it is not compatible with this system.
See all 15 Download Drivers & Software for Pictrography 4500
Feb 03, 2009 | Fuji Pictrography 4500 Thermal Printer
Request for the english langage
Hello sir i have fujifilm finepix 4500 digital camera how i can english in english language
Jan 17, 2009 | Fuji FinePix 4500 Digital Camera
Driver for pictography 4500 for MCOSX 10.4.8 FOR G3
I haven't done it yet, but Fuji shows a driver on their US site for 10,4 and the Epson driver for 10.4 is also on their support site- I can provide links, but thye are easy to find just digging down thru the web sites
Dec 29, 2008 | Fuji Pictrography 4500 Thermal Printer
ANy solution to the lack of fuji drivers for new macs and OS?
4500N can't be recognize with an Intel Mac, because the Appletalk doesn't work. My solution to print: I've got a powerPC as an interface between Imac intel and fuji network adapter. The pictro driver is installed on both machines. On The Intel, The Appletalk is connected on Airport. On the PowerPc, The Appletalk is connected on Ethernet. Ethernet cable between powerPC and pictro network adapter. SCSI2 cable between PNA and the 4500. Of course, auto calibrating + eye-one color calibrating. WELL!! it works.
Nov 13, 2008 | Fuji Pictrography 4500 Thermal Printer
Fuji Pictro Proof e252
E 252 doesn't seem to be listed in the troubleshooting guide. Are you sure of the number?
May 21, 2008 | Fuji Pictrography 4500 Thermal Printer
i just bought a used 4500N printer and can't get it to be recognized by my mac or pc...any ideas how I get an ip address for it?  Thanks
May 10, 2008 | Fuji Pictrography 4500 Thermal Printer
Fuji Pictrography 4500 Thermal Printer Logo
53 people viewed this question
Top Fuji Office Equipment & Supplies Experts
billconfused
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
