Question about Electronics - Others
Iam using lexar 2gb micro sd card and it is showing some bad sectors how to repair and recover the data in the micro sd card
  • 6,826 Answers
Http://www.lexar.com/support/index.html
The above is lexar support's website.
Unfortunately, I couldn't view information on recovering and repairing the micro sd card, at this time.
There is a way of reformatting it and recovering lost secters, I think.
Posted on Jul 14, 2010
    Genius:
  • 1,112 Answers
Hi:
You might try formatting the card. Go to the drive and rigth click on properties and then click on tools, first try error checking the drive, a box should pop up that has two options 1. Automatically fix the system errors and 2. Scan for and attempt to recovery of bad sectors select both boxes then click start. If all goes well and windows is able to repair the device then your data is saved. If not them reformating the device is the only way to restore the device, but data on the device will be lost..
Unable format micro sd
Try to format it using this low level format tool -> http://scut.co/n4b
Remember to select correct drive.
Aug 17, 2013 | Electronics - Others
My 2gb sandisk micro SD card reduce the size after formatting
Possible micro SD bad sectors. To check your micro SD bad sector or not, you use the HD Tune software. To restore the capacity micro SD, which is done is Low Level Format. You can use the software HDD Low Level Format Tool.
How to use HD Tune and HDD Low Level Format, you can see here
Transcend Repair Bad sectors
How to repair micro SD, you can see in here
MMC Repair Without Losing Data Video 2
Oct 12, 2011 | SanDisk 2GB microSD Memory Card
When I enter my memord card in nokia 311 it say the operation is failed and the memory card is not formatted.how to remove virus from my memory card and replace my music and Image.
All you have to do is
Step One (save data)
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
When do the data recovery process, you can find the cause of damage to the micro SD.
Cause of the damage the virus infected (solutions: see method 1)
When saving data, be careful, do not recover the virus file. You must choose the proper file for the recovery.
Cause of the damage bad sectors (solutions: see method 2)
Damage to the partition table (solutions: see method 1)
Micro SD write protect. Characteristics: (solutions: see method 3)
1. Micro SD can be opened, the data can not copy and paste (from the micro SD into a computer, or from computer to the micro SD). When the format, the message "Removable media write protect".
2. Micro SD can not be opened, and when the format of the message "Removable media write protect".
Step two (repair micro SD)
Method
Using the HP Drive Key Boot Utility, the first way
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
Method 2
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
Method 3
To write protect a micro SD cases, 40% probability of success.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
I hope this information helps. Thank you for using FixYa!
Oct 02, 2011 | SanDisk 2GB microSD Memory Card
My memory card micro sd is no open and no detected in my computer
Micro SD card can not open or connect with computer? Try 4Card Recovery software. It can easily deal with these problem, especially data loss case. How to Recover Photos Videos off SD Card after Formatting Unformat SD...
Sep 02, 2011 | PNY 2GB microSD Memory Card
How do i shut off write protection
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 16, 2011 | SanDisk 2GB microSD Memory Card
How I format micro sd card if MSDC write sector error?
Do this click my computer>right click icon of your micro sd card>choose format (don't check quick format) need full format to recovered bad sector. if finish formating, right click icon of your micro sd card >properties>choose tools>choose error checking and click check now.
To fix your micro sd card.
Also try to scan using anti-virus sometimes virus became write sector error.
Jul 15, 2011 | Computers & Internet
Data and bad sector Recovery software for 8 GB SAndisk
you can try some data recovery software. You can see
Recover data from memory card
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Jan 27, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
The SD m2 2gb Micro does not work on my phone
the card shows sign of a rom ic being lost its firmware
Sep 05, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
To recover my 2gp micro sd memory card
you can recover memory card with card recovery software like asoftech data recovery, download the software with link below
Memory Card Recovery Software
Jul 07, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sd card needs to be formated?
Did you put the card into your phone. This does not sound right
that your pc did not see the folders on the card.
Do not format card. This is a free file recovery software that ill post below, the ones you pay for like data doctor are better.
Try and recover the data before you do anything.
Read how to use the recover software before you use it.
http://www.freedownloadscenter.com/Utilities/File_Maintenance_and_Repair_Utilities/USB_Flash_Drive_Data_Recovery.html
Apr 07, 2009 | Motorola Mobility KRZR K1m Cellular Phone
Electronics - Others Logo
168 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
