Question about Beko Dishwashers
Hi there, My Beko DW600 dishwasher will not change programmes. Its stuck on the No Heat programme all the time. Any advice appreciated, Thanks, Genie
5 Suggested Answers
  • 123 Answers
SOURCE: Beko Freestanding Dishwasher
Hi there ....this condition is ususally caused by a water leak into the sump of the dishwasher which activates a safety switch to run the drain pump..preventing the appliance from being used....Remedy...tip the dishwasher back in the head allowing excess water to exit from the sump...then with the door open check that the air vent lock ring is secure, thet the salt unit retaining ring is secure..and finally that the filter unit to base screws are secure...this done re-start and you should b fine
Posted on Jan 05, 2007
SOURCE: BEKO D 2731 FW Dishwasher Problem
yes man,it worked 1st time,cheers for that info.
Posted on Sep 28, 2008
abhishek33
  • 1239 Answers
SOURCE: Teka Dishwasher DW6 59 FI
hi Because the timer controls many operations, a faulty timer can cause many problems. The timer is a complex component, so you shouldn't attempt a do-it-yourself repair. Test the timer with a VOM set to the RX1 scale. To gain access to the timer, remove the front control panel. The timer is directly behind the main timer control knob. Disconnect one of the timer's terminal wires and clip one probe of the VOM to each terminal. If the meter reads zero, the timer is working. If the meter reads higher than zero, the timer is faulty and should be replaced.
If possible, use the same procedure to test the selector and cycle switches. The wiring hookup, however, may be too complicated to figure out on either of these switches. If you aren't sure you can deal with these switches, call a professional service person. Replace a faulty timer -- or a faulty control switch -- with a new one made for the dishwasher.
The timer is connected to several wires that supply power to operate the various functions of the dishwasher. To replace the timer, have a helper hold the new timer next to the old one. Connect the wires of the new timer one by one, removing the old wire and connecting the new, to make sure you connect the wires correctly. The wires may be friction-fit on the terminals. If they are, use long-nosed pliers to remove the wires. Don't pull up on the wires, or you may break the connection between the wires and the clips.
After connecting the wires, set the new timer in position, secure it the way the old one was secured, and replace the control panel and knobs.
Posted on Oct 13, 2008
  • 70 Answers
SOURCE: dishwasher keeps getting stuck on
Hi, it's most likely pausing in wash cycle because it is not heating, most d/w timers will loose power to the timer motor until the wash tub has reached a desired temperature, if its not heating the water it will not advance, although it still could be the timer it self but most likely a faulty heater element or thermostat, does the timer advance at all?
If so where timer dial pauses (gets stuck) open door and check water temp (just feel) and close door give it 10Min's or a bit more and water should get alot hotter (anywhere from 45°c to 75°c) note if it is hot fill water may be hot but not hot enough to trigger temp thermostat to activate timer, if your handy and can see its not heating try to check the Resistance of thermos and heater
Posted on Jun 27, 2011
We are trying to replace a door handle on a beko dishwasher DSFN 1530B. We cannot remove the programme panel all screws have been removed and we are stuck. Can you advise
before you can remove the top panel you have to remove the front outer door panel, there are screws down the sides to remove it.
May 14, 2017 | Beko Dishwashers
How do I change the waste pipe on a dishwasher dw600
follow the pipe iced the machiene and there is a sprung clip like a jubilee clip holding it on ..... you'll need a pair of pliers to squeeze it together
Sep 20, 2014 | Beko Dishwashers
Cannot programme to anything but a cold wash
The computer switch needs replacing (start control)
Jan 21, 2018 | Beko Dishwashers
Beko dw 600 dishwasher, all programme lights stay on and it wont run or clear
I had this problem and followed the advice from Gallagher to no avail.
I sorted it as follows andd bear to mind I have never seen inside a dishwasher. I found the float valve and removed the connection to open circuit the switch, still the same, I then did the same to the sensor in the water container still the same. I concluded that the only thing left was the control module in the door.
I got the pcb on line for 22-00 and fitted it. job sorted
It says the changing of the module requires an expert, dont know why its a piece of cake.
Jul 08, 2012 | Beko Dishwashers
Beko 2410w dishwasher problem
hi there.....sounds like your through heater has failed..and requires relacing....can be difficult to test in situ...however if its testing ok....then u require a new programmer
regards Sir Galahad
Feb 01, 2009 | Beko 24 in. D3421F Free-standing...
I have a Beko washer WMA 1613S and recently the programme dial is skipping through the set wash functions without performing all the relevant actions in the cycle. This seems to occur on all number...
I have a Beko washer WMA 1510S and recently the programme dial is skipping through the set wash functions without performing all the relevant actions in the cycle. This seems to occur on all number settings.
Andrea
Aug 30, 2008 | Washing Machines
Belling IDW 603 dishwasher
You can cancel the programme at any point by holding down the last button on the right hand side for about 10 seconds until it clears (its the same button you use to get it going again when you open up the door).
Mar 05, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Hotpoint DWT10 Dishwasher error codes/lights
food stuck in drain pump remove and clean out or scoop out - soak up all water then fill with 3 or 4 hot litres of water . cancel programme , start new one ( first thing unit does is switch to drain cycle ).
Then rock machine back and forth - this sometimes frees jammed debris thus pumping out of machine.
This works for me i have done it several times and it works
Jan 26, 2008 | Dishwashers
Jun 28, 2006 | Beko 24 in. D3731F Free-standing...
Dishwashers Logo
339 people viewed this question
Top Beko Dishwashers Experts
Eric Taylor
Marvin
Marvin
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
