Question about Casio SGW100B-3V Watch
Sgw 100 b try figure out caliburated the compass and temperature , its read it but it went blank juz dotted line not even err or batt how do i fix the problem or the sensor is faulty
After calibrate sensor display numeral are blank
Posted on Aug 09, 2010
Casio sgw 500 the compess reading is very wrong
You have to calibrate.For that, go to your manual appropriate section and follow the procedure.
Mar 04, 2016 | Casio Watches
The compass on myTimex WS4 fails to calibrate. Have tried removing the battery and resetting everything but still no joy. Is the any other way to calculate the compass?
There is a process to make an all reset. After the reset try again. The user user manual can be downloaded from Timex. Make very sure the watch is absolutely flat and far from metal objects. Even being near most furniture can effect the reading because they can have metal springs. Many homes have a lot of metal in their construction. It's best to calibrate the compass out doors away from power wires or cars or anything metal. On the street you can have metal under the pavement.
If this does not work call Timex. There have been instances where the compass module or sensor had to be changed. I have the same watch. It's a very good one.
Sep 25, 2014 | Timex Expedition WS4 WideScreen 4...
I just bought the Casio SGW500H-2B Mens Twin Sensor 100M Digital Sports Watch Compass Thermometer. My problem is the digital readout in compass mode reads fine but the needle/ second hand points to east...
To fix this, hold down the A button for 4 seconds. this allows you to recalibrate the home position of the second hand. My secondo hand was posting exactly 90 degrees west in compass mode, and this home position recalibration fixed it 100 percent.
Sep 11, 2013 | Casio Watches
I have a tcm 217362 watch with a digital compass how can i set it up to show me north it currently shows cal. and when i press the top right and left button it shows err.(probably error) it is a black and...
Hi john30x,
You have to calibrate the compass.
1. Press the upper right button (switching to compass mode)
2. Press and hold upper left button. The "CALL" will appear on the display. You are in compass calibrating mode.
3. Rotate the watch horizontally (around his vertical axis) slowly, so to be sure that he point the North at least 2 times.
4. Now press the upper left button again to input the
declination (this is the angle between the magnetic and real pole). It is different for the area around the world, that you want to explore.
5. Switch between the positions of the cipher by pressing bottom left.
6. Change the cipher by pressing bottom right.
7.
Switch between the active position by pressing bottom left. Now you have to enter East or West declination
8. If you are ready press the upper left. "END" of calibration will appear on the screen
Once you calibrate and set the declination you can use the the compass by pressing upper right button. As the compass is very sensitive It is good idea to calibrate it on a field, far away of metal objects and electromagnetic fields (cables, ect.). You need to calibrate the compass each time you want to use it by different surrounding.
Remember the compass function of your watch need much more energy than the watch itself. Don`t worry to change the battery when dead. The water resistance remains good even after. Very robust and accurate device. I hope that should help.
May 15, 2011 | Watches
Lost manual for watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please.
Mar 30, 2010 | Casio Watches
How to set the compass on a casio SGW 100
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 24, 2010 | Casio Digital Compass Twin Sensor Sport...
No instruction manual
For Compass Adjustment search on Google or FixYa
For Temperature calibration:
1. Pull the crown to most extended position (2 notches)
2. Temp hand moves to a default position
3. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button)
4. When done, push crown to 0 position
(I used melting ice water to calibrate and fix to 0 deg C)
For Tide calibration:
1. Pull crown to middle position (1 notch)
2. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button)
3. When done, push crown to 0 position
Hope this helps
Sep 17, 2009 | Timex E Tide Temperature Compass Watch...
I lost my owner's manual for my Casio SGW-100B. When I try to use the compass it asks me to please calibrate
Above link no longer valid. Here's the current one:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3157.pdf
Also, the key was inputting the correct #, in this case 3157 - NOT the 100B - at the following page:
I had almost given up when I looked again at the back of my watch and found the other number.
Sep 16, 2009 | Casio SGW100B-3V Watch
My old field watch is showing an err (error) and the internal klight wont work
I changed the battery in my PRT 50 but Alt and Baro still not working the light and Compass however is??
Oct 27, 2007 | Watches
Casio SGW100B-3V Watch Logo
1,231 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
