Try to re-seat the cartridges in the printer. Open the printer
cover > remove the cartridges > close the printer cover > re-brick you
printer by pulling out the power supply - black box behind the printer where
the power cord is plugged in, and re-plug after 10 seconds. When the printer
turns on, reinsert the cartridges and close the cover. Try to print a document
again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print
cartridge nozzle. Please follow the steps below to fix print quality issues
with your model:
On your computer, go to Start
menu.
Go to Programs.
Go to Lexmark 1200 Series
folder.
Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks.
Your printer will then print a page forcing ink through to clean the print
cartridge nozzles.
After printing the test page, try to print a document again to
Please follow the steps below to clear the print queue and restart the print spooler of your computer.
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the
print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\
folder. You should see files there ending in .SPL and .SHD created around the
time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the
Try to print a document again to verify that the
problem is fixed.
Try the steps below to clear print jobs stuck in the print queue:
4. Double click the printer icon in the lower-right
corner of your taskbar to examine your print job queue and browse to View ->
Refresh.
Try to print again to verify that the problem is fixed.
It could be that your cartridges needs some cleaning. Try to follow the steps below to fix the problem:
Make sure your printer is connected to your computer and is turned on.
From your computer, go to Start menu.
Go to Programs or All Programs.
Go to Lexmark 1200 Series folder.
Your printer will then print a test page forcing ink through the cartridge nozzles and clean them from possible clogs and dirt. After successfully printing the page, try to print your document again to verify that the problem is fixed. If that doesn't help, you can manually wipe the cartridge nozzles with a slightly damped paper towel. Then reinsert the cartridges and try to print again. If the problem continues, then it could be a faulty cartridge. Try to insert a different known working cartridge or better yet a brand new genuine Lexmark cartridge. Lexmark products work best with original supplies. I hope this helps. Thanks.
Try to open Lexmark Solution Center application on your computer and check if the software recognizes the ink levels of your cartridges. Go to Start menu > Programs > Lexmark 1200 Series folder > Lexmark Solution Center.
You can also use the software to clean the cartridge nozzles for possible dirt and clogs. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print a document again to verify that the problem is fixed.
There is a firmware update for the Lexmark Interpret S405 printer that addresses print quality issues. Please visit the Lexmark website to download and install the Lexmark S400 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct. After successfully updating your printer, try to print your document again to verify that the print quality has improved.
It could be that the cartridge has become dry. you have to try several head cleans using the printer software and if that doesnt help then the cartridge needs to be replaced.
