Question about Zebra Z4Mplus Label Printer
How to reset zebra z4mplus dt printer setting
    Problem Solver:
  • 11 Answers
Factory Reset
Press Setup/Exit - 2 Times
Press '+' - 3 Times
Press 'Select' - 1 time
Posted on Aug 16, 2012
    Problem Solver:
  • 13 Answers
Change it on the printer:
Go to the menu by hitting the "SETUP/EXIT" button Hit the "+" button until you get to "PRINT METHOD" Hit the "SELECT" button Hit the "+" button to change between Thermal Transfer (Ribbon) and Direct Thermal (no ribbon) Hit the "SETUP/EXIT" button twice to save your changes
Let me know!
Posted on Aug 16, 2010
4 Suggested Answers
  • 3 Answers
SOURCE: Zebra Z4MPlus doesnt communicate with PC
Ok,
This machine has a parallel port. Try to print via parallel cable. If it works, consider staying with it. Serial ports are a pain to manage.
If you absolutely have to do it via rs232 though....
Question 1. Has it ever printed?
If yes, Go into Windows Printers and Faxes control and select the Zebra or whatever printer that you are using. Right click on it and you should get a menu that at the bottom say "Properties", select that, then you should get a new window with tabs at the top. You want the tab for "Ports". Select it and you will see all of the different output ports that you can direct your printing. RS232 is a COM port. So start at COM1, check it and try to print. If that doesn't work, go to COM2, etc.
Last resort, If you can't get control via the printer driver program, you will have to try redirecting the print manually (now you will understand why I said to stay with parallel output).
What you have to do is redirect your printing via the dos "mode" command.
Under "Start Menu" goto "Run" and put in "CMD" and click "OK".
This opens a black square window with a cursor blinking. Type in this:
mode com1:9600,n,8,1 (enter)
mode lpt2=com1 (enter)
Tell your program to use LPT2 if you can and see if it works.
By now a parallel cable instead of RS232 should be looking really good.
Posted on Mar 13, 2008
bartech9
  • 155 Answers
SOURCE: Z4MPLUS P3/P5 ERROR
The display shows P3/P5 ERROR? You can try to load firmware, download the file from www.zebra.com press the keys - and +, turn the printer and you see FIRMWARE DOWNLOAD in screen, download the file through the parallel port.
Roberto Martinez
Posted on Oct 06, 2009
  • 62 Answers
SOURCE: Zebra Z4MPlus not printing dark enough
Problem is the temperature, printhead not hot enough. Download the zebra setup utility, you can use this utility to configure the print quality.
Heat setting can be found in the printer driver and easily adjusted there.
Posted on Nov 17, 2009
I just bought a used Z4Mplus printer, I need an illustration/drawing to show me how to install the ribbons? Thanks.
Goto http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html and then ctrl+f paste Z4Mplus in the Find: slot.
You will find (Z4Mplus & Z6Mplus Users Guide 13163L-002 Rev A (en)). Next column: 13163L-002 Rev. A, next column: User Guide next column: English last colum: Download. The download is a 171 page manual.
Jun 01, 2011 | Zebra Z4Mplus Label Printer
I nstalled Zebra Z4Mplus printer drivers. is it supports to ZEBRA ZBR2303372 drivers?
shivacando: You can use the "zebra universal driver", the "zebra designer driver" from Zebra Technologies and also the "seagull driver" from Seagull Scientific Systems.
Roberto Martinez
padrino99@prodigy.net.mx
Dec 15, 2010 | Zebra Z4Mplus Label Printer
How do i find the IP address on a Zebra Z4MPlus?
If you can not see it in the LCD menu on the front panel, you can find it by printing the IP info on a label. There is a reset button near the Ethernet jack that will let you reset the print server settings or allow you to print a config label. Load up some media, power the printer on. Once the printer is fully booted, use a paper clip or the like to press the button once. A label will print that details the IP settings. Once you have the IP settings, you can log into the printers web interface by typing the IP address in your browsers URL bar. Do get a copy of the manual.
Jan 19, 2010 | Zebra Z4Mplus Label Printer
Zebra Z4MPlus Ribbon Wrinkles
I changed the print head, and the issue was solved.
Aug 01, 2008 | Zebra Z4Mplus Label Printer
Stops printing after sending job
try to reset to factory defult,
run calibration and sensor profile.
if dont help,
it is possible that the power suply or logic board is faulty.
Jun 30, 2008 | Zebra Z4Mplus Label Printer
Zebra z4mplus
iN THE DRIVER CHECK THE head TEMPERATURE ISSUE. Most certainly you do not heat enough to do the transfer.
Else your ribbon is not mounted correctly. Zebra has an out inking transfer film
May 21, 2008 | Zebra Z4Mplus Label Printer
Printing die cut labels on Zebra Z4Mplus?
Set the printer to transmissivefrom reflective gap sensing.
This will cause the printer to loog for the inter-label gap to tell it where the top of the label is at.
Steve Weinrich
LazerTek, LLC
Dec 15, 2007 | Zebra Z4Mplus Label Printer
Zebra z4mplus printer resets to thermal transfer
Please go to the inhouse program & click printer properties and
change the printer setup to direct thermal and that's it.
Joe
Dec 12, 2007 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus Label Printer Logo
1,417 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
