Question about Mitsubishi HC1500 DLP Projector
I have a mitsubishi hc 1500, and it has been great, today though i went to turn it off and it made a very loud pop sound, but it shut off, when i tried to turn it back on, the picture would not display but the lights are green on top by the power button and it is making a loud popping like sound>?
  • thedannydude Jul 23, 2010
    the lamp still lights up though, why would i need a new lamp if the one i have in there still lights up
  • Mitsubishi Master
  • 6,826 Answers
Http://purelandsupply.com/HC1500-Mitsubishi-Projector-Lamp.html
The above link takes you to the link for getting a new lamp.
Posted on Jul 14, 2010
  • Duane Wong
    Duane Wong Jul 23, 2010
    You're right, if the lamp is not what went pop, then don't replace that part (sorry about that).
    Genius:
  • 1,417 Answers
what this sound indicate i that the picture sensor power I C has gone bad due to the power input load
what you will have to do to fix up this problem to make your mitsubishi hc 1500, back to his function as expected is to unscrew (open) with stroll driver the system then trace the panel down to the sensor (lens) remove it and then replace it with a better one or you order for the lens from the below site
connectreviews.com
testfreaks.com
craave.net
projectorreviews.com
all these site offer a great service to customers and a competitive price fix the lens a simple assignment to the offer do it your self
thank you and thanks for using fixya.
Mitsubishi hc3000 wont start
this is a problem in your power board.
thi unit is getting OFF due to heating problem
Jun 29, 2008 | Mitsubishi Office Equipment & Supplies
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
Dec 16, 2010 | Mitsubishi WD-65736 Television
I heard a popping sound in my tv, then it shut off. I turned it back on with no picture, then the green light went off and the red light came on. Is it the lamp?
yes , the lamp went out , u can get a shipone over the internet or buy the original from mitsubishi , i recomment the mitsubishi
Aug 26, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
It shuts its self off picture is still great everything works great it just makes a loud pop and shuts its self off i can turn it back on after a few minutes sometimes it shuts off again minutes later and...
saw a similar problem w/a Samsung and eventually the Focus Transformer gave out w/a big electric pop sound and all power went out. So it's probably related to a problem with high voltage and Flyback issue. Hope that helps a little.
Oct 02, 2009 | Televison & Video
TV made popping sound and then shut off
You need to look in your owners manual for the telephone number and order a new bulb. It should cost about $200, but they will ship it overnight and minimize your downtime.
I've replaced 2 in my WD-52525 in the last 3 years, the first one went like yours did, very suddenly, with an audible POP!! The second one was preceded by an orange warning light, which the book says is a warning that the bulb has about 20 hours left on it.
To replace the bulb, UNPLUG THE TV, remove the left speaker screen, with a philips screw driver unscrew the bulb, pull it out by the handle, then replace it with the same type, in reverse order. This is a very easy replacement that does NOT need to be done by a service technician to complete.
Dec 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My DLP TV made a loud popping sound then went off
first. unplug the set for 5 minutes and see if it will reboot. if it does not the you have 2 problems, the chassis is also bad. next open the lamp door cover, it is behind the speaker grill, and behind the lamp door.
take out the lamp and see if it has broken on the inside if it has it needs to be replaced. mits will send you one i believe it is about 100.00 the number is 915P020010. if the lamp looks ok then the color wheel has probably fallen apart.if this is the case the light engine need to be repaired. check out www.tv-techs.com
TV shut off will not stay on.
Sounds as though you have a video problem. It may be the convergence chips. The TV is shutting down do to a default in the circuit ( the set knows there is an error of somekind so it shuts down to protect itself). This is a problem that needs a pro trouble shooter since it could be in about any board. Sorry I couldn't help more
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | Mitsubishi VS-55707 TV
Mitsubishi HC1500 DLP Projector Logo
63 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
