Question about Water Heaters
Power light is on with my Mira electric shower
Power light is on and water is warm in the normal way but goes cold after a minute or two and the warms again. There is plenty of water pressure
    Problem Solver:
  • 9 Answers
More than likely the inner dip tube has become detached which is causeing stacking of cold water. You will need to have a tech come in and fix the problem
Posted on Jul 29, 2010
When i turn on the shower the water will be warm for one minute and then cold, I have to turn it down and open again to get warm water
Reasons for this: ???
  • bad elements,
    • if one is bad, just replace both
  • bad thermostat or both of them?
  • broken dip tube / cold water mix tube
    • Notice the "RED" in the 1st pic on the left. 90% + of the tank is hot, with a broken tube, 75% of the tank is luke warm to cold.
Check for them. not that difficult of a fix
Mar 13, 2015 | Water Water Heaters
Mira 88 not supplying hot water
may have a screwed up washer seal on the hot side..it will stop the flow to a degree and allow more cold water in..calls for dismantling the entire control or replacing it..
Jan 26, 2014 | Water Heaters
My oil fired hot water heater provides only sporadic hot water. For example, when I am home alone it takes 2 minutes to get luke warm water in the shower, then it is only warm for a few minutes, then...
It sounds like your thermostat on the water heater isn't working properly. try turning it up higher and if this doesn't work I would have a service techy look at it.
Mar 24, 2011 | Water Heaters
Water turns cold very quickly
I had the EXACT same problem (installed my tankless last winter and worked fine, now this summer it fluctuates, have to turn the shower completely off and then on again to get any hot water and then it only lasts for a couple of minutes!) Argh - it is frustrating!
Here's what I found: the demand for hot water is lower during the summer (hot) months because the "cold" water coming in is already quite warm. You don't need as much hot water to make the shower temp comfortable. SO, my tankless was shutting off due to low flow demand. I've removed the flow restrictor from my shower head and it helped alot but didn't completely solve the prob. Next step is what has been recommended to me by several people but is much more expensive - change the pressure valve on your shower to a temperature valve. Or just wait til winter and it should work ok again :)
Jul 06, 2010 | Bosch & Tankless LP Hot Water Heater
50 gallon electric heater not working after about 5 minutes in the shower the water gets cold and the rest of the house i do have 240 going to water heater thermostats goood element good
Some elements will read with a meter good until they heat up.
Hot water then going to ice cold top element is working and bottom bad. Luke warm water and then goes cold bottom element good and top element bad.
Elements and thermostats are not to exspensive to replace.
If you have power only two thing's left are the thermostat's and the elements.
May 21, 2010 | Water Heaters
Water heater doesn't keep running
Sounds like youo have a problematic gas valve. But I would get a gasfitter to replace it. Not for the amatuer.
Nov 20, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
The water coming out of my faucets, washing machine, shower, etc. is not getting hot.
Your heater is on? Do you regularly drain off sediment?
Have you contunity tested your elements (power off)? Volt tested the same (power on)?
Has anyone fooled with the thermostat?
There is the possibility the dip tube (cold water going in) has broken off and instead of sending the cold water to the bottom, the cold goes straight from the cold water entrance pipe to the hot water exit pipe. Normally, one would expect cold water to sink and hot water to be on the top but, when you are drawing water off the top, with a broken dip tube, the water travels the shortest distance required, thus, your luke warm water.
I hope you can find your trouble by following one of these hints.
Thanks
a
Oct 18, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
WE HAVE CHANGED THE THERMOSTATS BOTH OF THEM, WE HAVE CHANGED BOTH ELEMENTS AND THE WATER STILL DOENT GET HOT ENOUGH. WE HAVE TURNED UP BOTH THERMOSTATS AND STILL NOT HOT ENOUGH. WHEN YOUR RUNNING THE HOT...
WE THOUGHT WE NEEDED ANOTHER THERMOSTAR, BUT WHEN WE WERE LOOKING FOR THE PART THE EMPLOYEE ASKED WHAT WAS THE TROUBLE. WE EXPLAINED, HE SAID YOU DEFINATLY DO NOT HAVE A PROBLEM WITH YOUR TANK AND ASKED IF WE HAD A SINGLE HANDLED FAUCET WITHIN THE HOUSE. NO WE DONT. HE SAID IT SOUNDS LIKE WATER IS MIXING WITH THE COLD WATER THATS THE REASON FOR THE WARM--COLD--WARM WATER. COME TO FIND OUT SINCE WE ARE REMODLING THE BATHROOM, WE HAD BOTH THE HOT AND COLD WATER TURNED ON IN THE SHOWER--BUT WERE PLUGGED OFF AT THE SHOWER HEAD AND THE FAUCET UNTIL THE TILE IS INSTALLED. SOOO ALL MY HUSBAND HAD TO DO WAS TURN OFF THE WATER IN THE SHOWER. NOW WE HAVE PLENTY OF HOT WATER, NO WARM COLD. YEA!!!
Jul 06, 2009 | Whirlpool Water Heaters
Running out of hot water after 5 minutes or so in the shower.
I think the dip tube in your water heater has failed, this is a plastic tube that goes in the cold side of your tank and forces incoming cold water to the bottom of the tank allowing hot water out at the top. When this tube deteiorates the incoming cold water mixes at the top of the tank causing the problem you have. the dip tube runs about 5 bucks but takes someone with pluming skills to install.
Dec 31, 2008 | Water Heaters
Water Heaters Logo
79 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
