Question about LG WM-2277HW Front Load Washer
My LG Intellowasher WM-1280FHD is refusing to spin, even when empty, making strange noises and displaying the code LE. I cannot find the manual to know what this means. Can anyone help?
    President:
  • 1,382 Answers
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Posted on Jul 14, 2010
Lgbl20vrestcode
Posted on Jul 21, 2010
WHAT IS THE SYMPTOM "LE"
A common reason for an LE code is choosing a high spin speed on a bulky/ very heavy load. Try a cycle with a lower spin speed. If you still get the LE code, especially if it does not even do the wash tumbling, then replace the Hall sensor on the motor.
Oct 19, 2012 | LG WM-2277HW Front Load Washer
Front Loader LG Inverter 7.5kg model WM-12330 FB On the last wash it wouldn't drain the water away. Tried 'drain' programme and rinse & spin programme - all works normally till it needs to drain and...
Have you already check your drain clean out? If it's not draining, you'll need to manually drain the washer, via the small hose that pulls out, once it is drained you can unscrew the large clean out filter, and see if anything is caught up in that area.
If all that is clear, it's most likely, you'll need a new drain motor. Also, did you notice if your getting a "OE" error code on the display?
Feb 28, 2011 | LG WM-2277HW Front Load Washer
GETTING AN ERROR CODE - LE ON MY WM2277HW
Feb 01, 2011 | LG WM-2277HW Front Load Washer
Ok my LG front loading washer agitates but when it comes to spin it makes a very irritating high grinding noise and does not spin. There is no error displayed but that may be because I stop it before it...
I have a similar problem. The washer was showing error code UE, but would tumble when empty in test mode, but would not spin and made a grinding noise. The bolt that attaches the rotor to the motor was loose and the rotor was spinning on the spindle that rotates the drum. I tightened the bolt, and it spins when empty, but still gives a UE error code when full. Remove the rear cover and check the tightness of the center bolt.
Dec 16, 2010 | LG WM-2277HW Front Load Washer
Drum will not spin
You will need to change the rotor and stator,
Jul 21, 2010 | LG WM1814CW Front Load Washer
LG WM 14225FD eu code
EU --- error means ---Unbalanced load is sensed three times during a spin operation. to resolve the issue ----Open lid. Rebalance laundry load and close lid.· Check wiring harness
· Check unbalance switch
· Check circuit board
Mar 14, 2009 | LG WD-1280FHD Front Load Washer
LG washer
23d2381.jpg This info is right out of the LG Service Manual.. Hope this helps..
Aug 16, 2008 | LG WM-2277HW Front Load Washer
LG WM 1832CW
if your getting LE code on your LG washer check if your hot and cold water is hooked up right
Jan 27, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
852 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
