Question about ASUS P4B533 Motherboard
Pci to usb2.0 card not recognized in device manager?
I have a pci to usb2.0 card installed in my old 586 desktop
pc. But I noticed that it has a ACCESSBUS controller card in
my device manager with a yellow question mark (in xp and
vista) and the device obviously not working. There is no
driver included. How to solve?
Thanks
  • DIY Jul 14, 2010
    Obviously, selecting update driver via internet will not work.
    Is it possible that the card is damaged or not sat well in its slot?
  • 487 Answers
Hi there are two ways, I presume as you have seen the problem in device manager, you have tried right clicking over the ? and selecting undate driver from there? Or try going to this link for you driver, I found this on google: http://www.download32.com/access-bus-controller-driver-software.html
Hope this helps
Posted on Jul 14, 2010
Pci to usb2.0 card not recognized in device, damaged?
Its most probably seated ok but check that but also try another PCI slot it seems to be having a conflict with something else there. Also ive never had to use more than the standard windows drivers to install those cards. Good luck from Scott
Jul 15, 2010 | Intel Motherboard
My HP M7260n doesn't recognize my new Video Card...
You might need to uninstall the old video card device, so Windows does not use the old drivers for the new card.
Another option is to try and boot in Safe Mode (press F8 during startup), so Windows uses the VGA mode (which all video cards support), and then install the proper driver.
Installing the latest ATI driver updates might also not be a bad step.
Jun 25, 2010 | HP Media Center m7260n (EG642AA) PC...
SunTech(SYBA) USB2.0 4+1 Ports PCI Card (NEC)
hi,
Kindly find the mother board manufacture and visit the site and download latest drivers and if your running xp kindly update with SP3 pack.
Jun 15, 2010 | E-Machines eMachines Desktop PC
Onboard video works fine but when I install a pci express card the video is garbled. The card checks out good on a different machine.
you need to unstill the intergrated vga port via the BIOS or disable the device via the device manager, install the new driver first the install the pci card
Feb 03, 2010 | E-Machines T6216 (827103077834) PC Desktop
I need to disable the onboard video card on the emachine t1090 but I don't have any video output
Enter the bios under onboard devices you see the the video adapter disable it there save and exit
Oct 07, 2009 | E-Machines T1090 PC Desktop
Gt5520 video card
Is this a PCI-E card? I will work on the assumption that it is. Unless you are running two video cards in SLI remove the old card, they make great paper weights. Be sure to only add/remove hardware while the machine is turned off.
Dec 20, 2008 | Gateway GT5220 PC Desktop
Video Card not recognized on PCV-RS410
Go into video settings (control panel- display- settings) Here there should be a drop down box in it you should see you onboard and new video card switch to the new one.
Dec 10, 2008 | Sony VAIO Digital Studio PCV-RS410 PC...
XP won't recognize 2nd SATA drive and shows 1st SATA drive as drive F:
To get Windows to recognize the 2nd HDD, you have to initialize it in disk management.
http://www.simplyguides.net/guides/prepare_second_hdd/prepare_second_hdd1.shtml
As far as the drive letter for the OS install, that was caused by the HDD not having an existing partition and other drives in the system having one (Either USB Drive, Printer with a card reader, 2nd Internal HDD)
Here is a Microsoft article on how to change it, but you'll notice MS doesn't recommend you try it. (Personally, I can live with ah HDD with a drive letter other then C:, so can Windows.)
http://support.microsoft.com/kb/223188/en-us
In the future, when installing XP, boot to the CD, run the install to the point of formatting the hard drive. Once formatted, turn off the computer, reboot to the XP install again, the HDD will be assigned C:
As far as the drivers go, they needed to be installed in this order:
Desktop System Software
Chipset
Video
Audio
Network
Modem
Aug 04, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
All USB ports dead....
Try removing the PCI USB Adaptor and clean the gold contact with dry brush, then place it back again. If this still doesn't work, try moving the PCI USB Adaptor into other available PCI slot.
I hope this procedure solves your problem.
-mrsolution
Jun 11, 2008 | Gateway GT5228 PC Desktop
ASUS P4B533 Motherboard Logo
51 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
