Question about Toshiba Satellite A135-S4457 Notebook
Recovery and Applications Issue (PLease help)
I put the Toshiba recovery disc and it have started to recovery and do it work. But I have forgot to plug my charger in. The power was low and the whole pc shut down.
Then I Restarted the pc, but it keep saying "Error Loading Files.."
What you I do? =/
PLease help
  • 1 more comment
  • Holylove4 Apr 20, 2008
    Oops, make a mistake ehehe...
    What should I do?*
    My laptop is Toshiba Satellite A135 S4467
    ahhhh Thank oldnovii, i will try it soon as i get home =)
    Just a question.....uhmmm What is the Adaptor? ^:^
    I am poorly on Computer...
  • Holylove4 Apr 21, 2008
    The Problems is Fixed! Thank you for your time oldnovii.
    Thank you
  • 667 Answers
Restart your computer normally without the disk in. I beleive there's a message that pops up on the screen, something like F2 for recovery ( not sure of exact key). Press the key it tells you to and try starting the process over. Let me know what happens. If this solves your problem rate this as fixed. If not, DON'T rate it yet add a comment letting me know what happened and I'll be glad to assist you further. MAKE SURE YOUR ADAPTOR IS PLUGGED IN! Thanks.
Posted on Apr 20, 2008
I need to reboot windows xp on my toshiba satellite laptop
The Toshiba Satellite A10-S169 includes several utilities to improve the performance or security of the computer, and to reconfigure the system's settings. Toshiba Satellites running Windows Vista 32-bit and Windows XP come with the Toshiba HDD Recovery Utility, which allows you to create a recovery CD of your system and applications. The recovery CD will allow you to restore your system and its settings in case your hard drive fails.
Click "Start." Click "All Programs." Expand "Hard Disk Recovery Utilities." Click "Recovery Disc Creator." Select "CD" as the type. Check "Recovery and Applications." Insert a CD into the disc drive. Click "Burn." The Toshiba A10-S169 will begin writing the recovery content to the CD. Follow the on-screen prompts to burn your recovery files to disc. Hope this helps.
Jan 10, 2013 | Microsoft Windows XP Professional With...
Safeboot corrupted error 92h message
run the receovery again and wait for the process to finish before removing the cds.
Sep 26, 2012 | Toshiba Satellite M55-S325 Notebook
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
I need to reboot my n10 notebook to factory settings,please help
Hello there,
Newer Toshiba laptops usually have the ability to create recovery discs that will let you recover to "factory settings." Try this:
1. Click Start
2. Select All Programs
3. Select Recovery Disc Creator.
Recovery Disk Creator
4. Within the Recovery Disc Creator select Create
5. When prompted enter the first blank DVD and select Ok
6. When prompted enter the second blank DVD and select Ok
I hope this helps. Thumbs up if you think so.
May 07, 2011 | Toshiba Computers & Internet
I can not make my recovery disc.
Hi there.
I'm sorry to tell you that when you reformatted the drive you deleted the recovery partition and all the recovery information on it, this is why the recovery disk creator cannot be launched and is giving you an error.
Thankfully for you, you created a recovery disk before you wiped the drive so this is your only way of restoring the system so make a back-up copy of the recovery disk you made and keep it safe as the problem cannot be solved because you deleted the recovery partition.
Thanks for using FixYa!!
Jun 04, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba 5005-S504 recovery problem
Unfortunately , you are going to have to call Toshiba.
from the sound of it your recovery disks are failing and they have already formatted your harddrve
May 09, 2009 | Toshiba Satellite 5005-S504 Notebook
I have lost my recovery disc supplied with my advent 7000 laptop can you help please
advent 7000 recovery system that doesn't require any CDs or DVDs to restore your PC to it's original factory condition.
  • There are two ways to start the recovery -
    • Restart your computer. Then Press F10 repeatedly until the message "Starting System Recovery" is displayed.
    • In Windows by clicking: Start / All Programs / System Recovery / System Recovery.
  • The recovery will load and display a box with one option:
    • Non-destructive recovery: this option will restore Windows, supplied applications, and drivers. This option will not destroy your documents or programs. These will be backed up along with the registry. These are restored at the end of the recovery process.
    To access the recovery options below that erase all data from the computer, click the Advanced button.
    • System Recovery - No format: this will reinstall Windows, supplied applications and drivers. It will move your files to a folder called "My old disk structure". Any applications (except those supplied) will need to be reinstalled.
    • System Recovery - Quick format: this option will erase your hard drive including your personal files. Windows, supplied applications and drivers will be reinstalled.
Nov 05, 2008 | Computers & Internet
Recovery Error
Do recovery again, when it asks you to insert disc 2, take out disc one and close the tray. Do not put the disc 2 yet. If you can see the error message again, then it is a RAM issue. You need to reseat the Memory module and try to do the recovery again.
If you closed the tray then no error message came up, it would be an issue with your recovery disc and order for a new one. You can contact Toshiba to have the recovery replaced due to corrupt media.
Hope this helps.
Sep 12, 2008 | Toshiba Satellite A105 Notebook
I need recovery disc
I do have a satellite a45- s150 laptop I can make a set of copies for recovery cd's if u need 'em
May 29, 2008 | Toshiba Satellite A45-S150 Notebook
Toshiba A35-S159 Recovery and Applications/Drivers DVD
If what you really need is the recovery disk, you can call Toshiba for it but if you only need the drivers, you can go to support.toshiba.com or pcsupport.toshiba.com. For the graphics driver, if you know that you have intel chipsets, you can go to intel.com/support/chipsets  -  there please select your chipset family then click on the "download" under graphics for your
specific chipset then please select your operating system. Please restart your laptop after the download
and see if it works. Thank you.
Nov 23, 2007 | Toshiba Satellite A35-S159 Notebook
Toshiba Satellite A135-S4457 Notebook Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
