Esprimo v5505 won't turn on. It just makes start up noises fails and whurs endlessly until switched off. Nothing appears on the screen.
2 Suggested Answers
alfredo_krau
  • 62 Answers
SOURCE: I need to upgrade the RAM in my fujitsu-siemens
You easily can find it . But changing of any part of laptop is your own responsibility.
Posted on Sep 19, 2009
My esprimo mobile v5505 will not let me download any apps/drivers or tools to restore it i do not have cd/dvd how els can i do this so annoying ?
Should be a recovery system partition - hidden on hard drive
https://www.youtube.com/watch?v=NOJd2Hul-6s
may be this that I found below to access recovery options -
BE AWARE you may lose any data and installed programs on your computer hard drive when re-imaging hard drive back to factory default
Press F8 during bootup to open Advanced Options.
Select Repair your Computer.
Select keyboard layout.
Select User name and Password. If Administrator account is disabled use another account.
Select in System Recovery Options the Fujitsu Siemens Computers Recovery
Restore Factory Default Settings to restore the system image.
Select the source From hard disk (recommended).
Last confirmation to restore the image.
Jul 19, 2016 | Fujitsu Siemens Esprimo Mobile Ms2216...
Pontiac montana whurring sound, constant while in motion
Drive until the sound appears and move the steering wheel left and right a little.Can you change the sound at all?If so it's wheel bearing time.
Jul 02, 2017 | 2006 Pontiac Montana SV6
Display problem
i had a laptop that did this. for me it was a broken ribbon cable. after a while the cable degrades and becomes brittle and with enough movement the cords break and separate very little and when moved in a little it would close the gap
Nov 24, 2013 | Fujitsu Fujistu Siemens Esprimo Mobile...
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
see this causes and fix it. God bless you
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Dryers
Reset bios
If you can enter the BIOS setting there maybe a setting to restore the BIOS to the default settings.
Sep 27, 2012 | Fujitsu Fujistu Siemens Esprimo Mobile...
My Acer 240 screen won't work it appears to be working otherwise
Connect a monitor to the video output, if picture is okay the problem is in the inverter board located under the laptop screen, or the backlight has failed, now if the monitor shows the same symptoms the problem is in the video card ic.
Sep 02, 2012 | Acer TravelMate 240 Notebook
I am getting a sound like i have winter tires on coming from the rear of my 2005 Mercury Montego almost sounds like stuck in low gear.
SOUND LIKE FAULTY WHEEL BEARING IF NOISE SOUND LIKE WHUR WHUR WHUR WHUR NOISE WHEEL BEARING NOISE.
Nov 10, 2011 | Cars & Trucks
Problem with fujitsu laptop esprimo v5535
I suggest doing a manual reset, and if all fails start by removing certain hardware equipment such as memory, wifi cards, etc. If you need more info, please ask.
Feb 07, 2010 | Fujitsu Siemens Computers & Internet
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
