Question about Indesit W 123 Front Load Washer
Idesit washing mechine,model WIDXL126EX?Type LVA2006c. Power supply not functioning.Rv044 and Q032 completely burnt!
Why do all lights flash when machine is turned on and unable to start the washing?
The number of times that the lights flash is the trouble code. Your machine is in need of repair.
Nov 21, 2015 | Washing Machines
The door will not open after the washing cycle is complete.I think the door catch is broken now do you go about replacing or fixing this?
u have to remove the front of door boot ie rubber seal from front of mechine 2 screws where the catch goes in holds the interlock 2 mechine remove wireing 3 wires or plug depends if three wires take note of wher the go replace interlock easy.
Feb 15, 2015 | Whirlpool LHW0050PQ Front Load Washer
My whirlpool white magic 650 P produces contineous beep sound while connected to the electric plug. However the power switch and light indicators on the mechine is not working.
Sounds like you have a control logic issue. Either a button on the control panel is stuck, or the control board is defective. Find the model number on the unit and post it in the comments please.
Jan 11, 2015 | Whirlpool Washing Machines
I require a user guide for Idesit cooker model KD13C1W
Hi Tony from retired Englishman in SW France,
You have actually posted to the washing machine forum----- but the advice is the same!
(Manual
You will need to type into your search engine/web browser '(make model number) cooker manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 17, 2011 | Washing Machines
Dear sir, i need ur hoover wa550 washing mechine catlog for 5Kg capacity. best regatd; jomy
Sorry but this forum does not supply any type of manual or schematic diagram direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Mar 19, 2011 | Washing Machines
My washing machine will not drain ..it is only 7 myths old ,i cannot seem to remove the filter either ..its an idesit w1b111 model .any help as i know its usually the filter that is blocked but as i cannot...
You will need to remoe the drain hose and get teh link out, the drain pump/valve must be clogged or filled with dirt. use a goo d jet of water to remove clogging, try to power and see if this works . or else replace the unit.
Sep 21, 2010 | Washing Machines
Missing parts i need pixtures of all parts under the mechine
You can find excellent exploded view diagrams of most Whirlpool model appliances at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
Just use your COMPLETE model number for your search criteria. If this is a Whirlpool washing machine, the model number is usually printed on a nameplate along the wash tub opening under the lid. I hope this helps you.
Nov 22, 2009 | Dishwashers
Electric supply plug burnt out
Prob is caused by bad or loose connection in plug top or socket the m/c plugs into.
Replace plug and if there are scorch marks or discolouring of the socket, then replace socket.
Plz rate my solution
Thanks.
Dec 18, 2008 | Washing Machines
Theres no power to my idesit wixl123
From what you wrote I can only hint that a fuse within a machine must have played its part for some reason so you better not mess with it. Call a repairman.
Apr 20, 2008 | Washing Machines
Washing mechine 1200 hoover
Hi, It sounds like it might need new brushes in the motor. Sometimes just before they wear down completely, they will wash but not spin, this is because the spin needs more power. Tom.
Mar 12, 2007 | Hoover H120M Front Load Washer / Dryer
Indesit W 123 Front Load Washer Logo
78 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
