Question about DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker
We are needing a new milk jug for this machine can you tell me where we can purchase one.thanks nikki
My Prima Donna avant is not giving out any milk I have descaled it and even purchased a new milk jug Steam is coming out but no milk
How long ago since the last use? Try a needle or some other small sharp object and probe the hole where tthe milk comes out. If that does not work see if you can take apart the unit where the milk is and soak the tube in hot soapy water to break the gunk up.
Feb 02, 2015 | Coffee Makers & Espresso Machines
Milk jug is making the noises and steam is coming out but no milk?
I get this about every 18 months to 2 years. The solution has been to purchase a replacement lid for the milk jug. I've just paid (yesterday, as it happens) £16.99 for one online. This will be my fourth, and we're all set to go for another 18 months-2 years.
Btw, I've tried dismantling the lid to clean it etc, (many times), and it seems to make no difference. A replacement lid is what's needed.
Bob.
Oct 03, 2014 | DeLonghi EC Coffee Makers & Espresso...
Delonghi coffee machine ecam23. Milk comes out of jug when turning machine on and milk also comes out after the water when cleaning the spout on the jug.
I think the ECAM has a second solenoid at the front near the milk jug. That solenoid valve might be stuck open.
>> service agent
Oct 17, 2013 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
I have a Delonghi Prima Donna. Blows lots of stem but wont froth milk. The 3 orings have been replaced and the fittings cleaned, but still no frothing. I pulled the lid apart and it seems ok. Any...
Where is it blowing steam from? If it is coming from the milk spout then it most likely that the milk jug is blocked somewhere. If it is coming from where the jug connects to the machine (coupling) then you might need to change the complete coupling (assuming you used the correct orings). The biggest cause of frothing problems with these machines is lack of cleaning of the milk jug. Soak the top in quality milk cleaner for at least an hour and rinse thoroughly. Also run cleaner through it regularly using the milk only function.
Nov 19, 2010 | DeLonghi Prima Donna Avante ESAM6700...
Delonghi milk cleaning solution
Hi - I had the same problem and found your question in a web search. I eventually found the solution I think. On this page http://www.delonghi.com.au/support/material_safety/msds_milk_clean_cofdscale.pdf if you look at page 2 under recommended dosage, it talks about mixing the solution in a 1:10 ratio with water, working the mix onto the nozzle, and then rinsing.
Hope this helps!
Jul 19, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Magnifica Coffee Maker the milk is not frothing properly - there's lots of steam & very little milk being issued from the spout We clean the milk jug each day, have adjusted the plastic tube...
You did not state anything about descaling, but every now and then, I also add water and descaler to the milk container and use the "Frothing" program to run through the water and descaling-solution (double-click the Cappuchino button).
I have also noticed that the first cup (and sometimes even the second) will produce less milk, and not as well frothed milk as later cups. My theory is that the machine is warmer when producing later cups.
If possible, you could try to run two-three frothings of plain water through before switching to milk. I realize this is inconvenient, but it could be worth testing this to see if it helps. We luckily have two milk containers and keep one filled with water just for the purpose of heating up (or whatever we do :) the frothing system before serving the first cappuchino.
Sep 04, 2009 | DeLonghi Coffee Makers & Espresso Machines
Delonghi Magnifica 3500 not frothing
use cold low fat milk and keep the milk container in the frig.
Make certain that when washing water come out of both holes.
Jul 09, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Change milk temperature (milk not warm enough)
It all depends in the Cappuccinotore(milk frotting part) Change a new one or
Think of a way to reduce the suction tube diameter smaller... to get milk and steam mixture correct.
Jul 08, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Trying to purchase spare milk jug
The following site has all of the accessories like pitchers
http://www.delonghi.com/Int/USA/customer.html
I believe the milk pitcher is about 1750
Jun 17, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker Logo
1,256 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
