I have an HP psc 2200 series all-in-one unit. It has always worked beautifully, and I love it. Until recently, when I attempted to install a new ink cartridge. First, the cartridge wouldn't go in correctly, kept getting the read out to remove and reinstall. I did that three or four times. Then I put the old one back in to see if that would work. Then it seemed ok, and was going to do the alignment print, then it stopped, and the read out says that alignment was cancelled. I can't get the unit to do anything, it won't do the alignment, and it won't turn off, the light on the scan button just blinks continually. When I open the unit to try to see if I can remove the cartridge, nothing happens. The cartridge units won't move to the center area so that I can remove them. I try to get the set up button to work, and it just beeps. All of the buttons just beep at me, and the scan button continues to blink. What can I do? What should I do. Thank you, Darleen Frishkorn darleen.f@hotmail.com ( 406-892-3706)
  • 3,037 Answers
First, try resetting it by just unplugging it for a couple of minutes, this should let it start working again
Next, you should Clean the print cartridge contacts
Caution! Do not remove both print cartridges at the same
time. Remove and clean them one at a time.
Make sure you have the following materials available:
• Cotton swabs or any soft material that will not come apart or leave fibers (for example, a scrap piece of clean cotton cloth).
• Distilled, filtered, or bottled water (tap water may contain
contaminants that can damage the print cartridges).
1 Turn the unit on and open the print-carriage access door.
The print carriage moves to the center.
2 After the print carriage has moved to the center, unplug the power cord from the back of the unit.
3 Lift the latch to release the print cartridge, then pull it out of its slot.
4 Inspect the print cartridge contacts for ink and debris buildup.
5 Dip a clean cotton swab into distilled water, and squeeze any excess water from the swab.
6 Hold the print cartridge by its sides.
7 Clean the contacts.
8 Place the print cartridge back into the holder and close the latch.
9 Repeat if necessary for the other print cartridge.
10 Close the door and plug in the unit.
Because you removed a print cartridge from its holder, the HP PSC needs to align the cartridges.
11 After the message appears in the front-panel display, press Enter to align the cartridges.
Next reset the factory defaults
You can restore the original factory settings to what they were when you purchased your HP PSC. Choosing to restore your factory defaults restores all settings, except date information.
You can perform this process from the front panel only.
1 Press Setup.
2 Press 5, then press 3.
This selects Maintenance, and then selects Restore Factory Defaults.
The factory default settings are restored.
Let me know if you have problems with any of the above and I will help you get this working again.
Thank you for using Fixya and Good Luck
Posted on Apr 20, 2008
    Genius:
  • 1,447 Answers
Which cartridge are you trying to change
make sure you have the correct part number
HP 56 black ink cartridge (19 ml) C6656A HP 57 tri-color ink cartridge (17 ml) C6657A HP 58 tri-color photo cartridge* (17 ml) C6658A HP 27 low capacity black ink cartridge (10 ml) C8727A HP 28 low capacity tri-color ink cartridge (8 ml) C8728A
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 20, 2008
    Try this
    Replacing the ink cartridges
    The power must be turned ON to the all-in-one or the print carriage will not come to the center.
    1. Locate and raise the print cartridge access door on the front of the unit, just above the output tray.
      The print cartridge carriage will move into the middle of the access area.
      Figure 1: Raising the front access door and the ink cartridge latches
    2. Press down lightly on the top of the ink cartridge latch of the ink cartridge to be replaced and then pull the lower section of the latch toward you to unlatch the ink cartridge.
    3. Grasping the sides of the ink cartridge, pull the cartridge toward you to remove it as shown in Figure 2.
      Figure 2: Removing the cartridge after raising the latch
    4. Remove the replacement cartridge from its packaging, and touching only the black plastic, gently remove any tape covering the nozzles. Do not touch the gold-colored contacts.
      Figure 3: Removing the protective tape
    5. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage as shown in Figure 4. The black ink cartridge (HP 56 or HP 27) goes on the right side (with the gray latch) and the tri-color cartridge (HP 57 or HP 28) goes on the left side (with the blue latch). If the optional photo cartridge (HP 58) is installed for six-ink photo printing, it is installed in place of the black ink cartridge.
      Figure 4: Inserting the cartridge
    6. Place your hand on the latch as shown in Figure 5, with the thumb pulling the end of the latch toward you. While holding the end of the latch out, press down on the top of the latch until it stops and then release the lower portion of the latch with your thumb so that it catches under the tabs. Do not force the latches into place or damage to the unit might occur. Close the all-in-one after latching the ink cartridges in place.
    Before you change the cartridges turn printer off first and unplug it from power supply for 20 seconds, replug and turn it back on then follow the steps i have sent you
How do i remove the ink cartridge ?
Turn on the unit, then open the print-carriage access door by lifting
the handle until the door locks into place.
The print carriage moves to the center of the unit.
You may want to use a photo print cartridge for
superior print quality when printing photos. With the
color and photo print cartridges installed, you have
a six-ink system. See how to print the best quality
photos on page 22 for more information.
52 maintain your hp psc
hp psc 2200 series
2 After the carriage stops moving, lift the latch to release the print
cartridge, then pull it toward you out of its slot.
3 If you are removing the black print cartridge in order to install the
photo print cartridge, store it in the print cartridge protector.
4 Remove the new print cartridge from its packaging and, being careful
to touch only the black plastic, gently remove the plastic tape.
Caution! Do not touch the copper contacts or ink nozzles.
5 Push the new print cartridge into the appropriate slot until it clicks into
place.
The tri-color print cartridge goes on the left and the black or photo
print cartridge goes on the right.
manual:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01176633/c01176633.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 26, 2010 | HP PSC 2210 All-In-One InkJet Printer
I have a hp 2200 all-in-one printer. For some
if it sends ok, then it has probably been switched to "manual receive" form "automatic mode"
Apr 21, 2009 | Office Equipment & Supplies
HP all-in-one 2200 series printer doesn't work w/Vista
For scanning you can go to Paint/ File/ from scanner or camera
Regards from
amir.tadros@rogers.com
Dec 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
We have a HP printer series 1310 and have recently purchased an ASUS notebook. We have attempted to install this printer to the laptop with difficulty as we continually rec've an error msg stating it is...
Hello
The printer should be compatible with both vista and XP
your printer is a serie 1310 but if you look closer you should find a more exakt nr like
» HP PSC 1311 All-in-One Printer
» HP PSC 1312 All-in-One Printer
» HP PSC 1315 All-in-One Printer
» HP PSC 1315v All-in-One Printer
» HP PSC 1315xi All-in-One Printer
» HP PSC 1317 All-in-One Printer
» HP PSC 1318 All-in-One Printer
or something like it. check for the serie nr or a mark somewere on the printer and you should find the right printer model.
you can download the drivers here when you find the right model.
good luck.
hope I helped.
Sep 04, 2008 | HP Computers & Internet
Vista compatability download for my HP PSC 1500 all-in-one series
The 1510 model is under the 1500 series. It is the same software for your printer
Aug 06, 2008 | HP PSC 1510 All-In-One InkJet Printer
Printing color
no problem ,the printer settings got corrupted.just uninstall the printer drivers and then reinstall properly.it will be fine. thanks.
Dec 03, 2007 | HP PSC 1600 InkJet Printer
Using JETCET Print with OKI C5200n Printer
The OKI 5200 is a 'GDI' or Windows only printer and does not support PCL or PostScript languages.
Most if not all of the printers listed support either PCL or PS or an inkjet based language.
I'm afraid you will not be able to print the the 5200 without it's driver loaded on the PDA.
If the 5200 supported PCL you would be able to choose any of the
Color HP Deskjets.
Oct 15, 2007 | OKI C5200n Laser Printer
Epson 2200 printing problem
More a software problem it imaging try reloading the software[driver] and do it exactly as Epson tell you - disable A/N program for example.
Jul 23, 2007 | Epson Stylus 2200 InkJet Photo Printer
69 people viewed this question
jasbo
jasbo
