Question about Cell Phones
The level of sound of the speaker when I receive a call is quite low even when the volume is set at 7. The phone is new (5 days)
  • 2,069 Answers
You didn't specify the brand but normally, you should check the speaker it self. even if it is new, it can be faulty.
Regards
Posted on Jul 14, 2010
Nokia 6303ci -low speaker level.Volume bar-on max.After clean -same.Someone told me that for this model is normal low speaker level,but I don`t think so.
If the original recording is on low volume then you will get louder sound on the player device while if the recording is at high volume the you get low levels on player. try recording at lower volume settings on the phone. Then when you play it it will sound louder on increased volume.
Oct 26, 2013 | Nokia 6303 Cell Phone
I have the following setup: AV Receiver: Pioneer
Very common problem with today's receivers. Receivers made today don't have a true preamp section in the amplifier and do not amplify the sound to the extent of an older receiver. I have large 15" front speakers on my system, and have stuck with my 15 year old receiver just because I know that a new receiver will not have the power to drive them well. Many of the newer receivers need to be turned up to 50-60% before you can even hear anything from the speakers.
Aug 08, 2013 | Pioneer Audio Players & Recorders
Speaker Imedance Matching - Sony STR DE 997 receiver with 120Watts - 8 ohms output with Benz 6 ohms..Tower Speakers
hi pawanh75,
thanks in advance for a very informative setup that you have.
Here are some of possible mods , only if you like and can DIY
( or have someone to help you )
• Using a 6 ohms impedance for an 8 ohm impedance amp clearly
denotes that it heats up the output stages.
(please forgive my very technical words)
• One way to lessen the heat is to install a blower .
Use a 220V blower on top of the receiver.
( air should be in going up direction ).
• Before I proceed further please indicate if having the speaker
connected and having a zero volume , and just letting the receiver
in an "On" state deliverately produce heat on the receiver, or just
when the volume is at medium to high level.
If it s running hot at zero level with speaker , please post.
If it is running hot even without speaker, post also
• It may also helps , if you have a powered subwoofer ( for the low's),
and set settings on your receiver to "small"
Let me know what you find to help you further.
Sep 11, 2012 | Sony STR-DE997 7.1 Channels Receiver
Volume really low, even when turned right up
So the speakers and the individual amp channels work so that lets out the obvious big hardware items.
This is starting to sound like an obscure setting was set or changed by mistake.
It would be nice to figure out what that is/was in case it happens again but you may eventually have to resort to resetting the receiver to factory defaults and start over by holding the1/0 button for 5 seconds.
Mar 04, 2010 | Sony STR-DE875 Receiver
Can't find the hands free speaker button
In an increasingly hands-free world, the external speaker feature of cell phones has increased the usability of cell phonesmag-glass_10x10.gif in the car, public transportation and at work. The volume controls on the external speaker controls can be somewhat difficult to find and manipulate.
  1. Step 1 Make sure the speaker setting is actually on. If the speaker is turned to off, the volume you hear will be coming from the earpiece and will be very low indeed. Sometimes there is a button on a cellphone which you can simply press and hold to activate the speaker function. You will notice a difference immediately.
  2. Step 2 Check to see if you have external volume controls. On some models, there is a button or two buttons that adjust the volume of both the handset and the speaker volume. If you have these buttons, use them to adjust these controls while on calls. Remember that adjusting the speaker volume will subsequently adjust the handset volume once you've turned off the speaker mode.
  3. Step 3 Access the sound controls in your phone. If your phone does not have external speaker control, it can be accessed by adjusting the controls saved on your phone. Also, the main settings can be controlled even if you do have external controls. Phones are different, but in your menu of options, choose sound and sound controls. This should give you options for ring volume, alarm volume and handset volume.
  4. Step 4 FInd volume controls for all settings. If you wish yo have multiple settings for each function---alarm, calls and speaker---you should be able to adjust these accordingly. Search through the control options until you've found speaker controls. Choose the setting you desire and save the settings.
  5. Step 5 Using the main volume as a foundation, use the external controls (if applicable) to adjust the levels.
Nov 15, 2009 | Cell Phones
Sound is low
try to see if the wave volume is on and maximum on the volume panel ( double click on vol icon on tray system (right low) ) ...also see if your speakers are plugged into the proper place ...and are not in the auxiliary out or something like this ...they should be plugged into the green middle out ...if they are simple stereo 3,2 jack ...so ..if the problem its still on ..its probably the sound card...(actually the pre-amplifier on it ..)
Aug 03, 2009 | Dell Dimension 3000 PC Desktop
My speaker has low volume even though I have it set on 7
I have a RAZR v3 and I used the P2KTools VS to seem edit the volume. It is free and very easy to use.(DO NOT EDIT ANYTHING ELSE AS YOU CAN TOAST YOUR PHONE AND VOID WARRANTY)
Just go to the sound application and load the settings from your phone on that page.Then, just click the arrow next to each volume settings just a notch or 2 to increase the volume (eg: for setting 7 to 9 volume) then set it and your good to go.
Oct 30, 2008 | Motorola Cell Phones
I have no sound coming from my speakers. Have tried all the troubleshooting option and still have the defect.
1-make sure that digital input source is selected.
2-make sure all audio connecting plugs are pushed in all the way.
3-make sure that polarity of speakers is correct.and the bare wire of cables not in contact with any metal part.
4-make sure that speakers cables not short with each other.
5-check volume and confirm that is not set to low level.
6-check that system is not in mute position.
7-head phone jack is not inserted.
8-repeat your speakers set up and confirm all speakers are on and in good sound level.
Aug 20, 2008 | Audio Players & Recorders
I cant hear no sound
please check the following:-1-power plug is connected to wall outlet.
2-it is switched on,3- sound source is selected(dvd-cd-vcr)4-volume level not in low position-setup of speaker is properly set.5-speakers cables are firmly connected.6-no mute switch is depressed.
7-speaker button is depressed.
Jul 22, 2008 | Audio Players & Recorders
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Jul 16, 2006 | HP Compaq nc6320 Notebook
Cell Phones Logo
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
