Question about Cycling
Need to re assembly - Cycling
  • stewartja341 Jul 14, 2010
    this is a schwinn s500 electric scotter
    President:
  • 1,561 Answers
If you are trying to re-assemble you device, i would suggest you check the user manual for this, this will guide you on how to about the re-assembling of the device.
But if you do not have the manual to the device, i would suggest you follow the link below to search for the manual of you device, the link contain almost all the manuals of all devices.
manualsonline.com
Type the above link on your web browser to search for the manual of your device and use it to re-assemble your device.
Take care.
Posted on Jul 14, 2010
    President:
  • 2,185 Answers
Hello there Stewart,
What is the exact model of your bicycle?
Here's a video on how to assemble a bicycle which will guide you step by step.
http://bicycletutor.com/new-bike-assembly/
If that does not resemble your bike, then tell me the make and type of the bike.
Let me know how this goes.
    schwinn s 500 electric scotter
  • 821 Answers
Hello,you can follow the steps below to reassemble your bicycle,
The amount of assembly required varies depending on the manufacturer. Allow a minimum of 30 minutes to assemble a bike. You'll need a screwdriver, socket set and box wrench or open-end wrench. It's best to remove all the parts from the box and verify you have everything before you begin
Loosen the bolt and slide the handlebars onto the frame. Adjust the height of the handlebars and tighten the bolt just until it won't move. You'll need to straighten the handlebars after the front tire is on and then tighten the bolt all the way.
visit the video site below for a more comprehensive view,
http://www.youtube.com/watch?v=KzUGWLhOZMA
wish you good luck,
take care
  • Step 2 Slide the seat post into the bike frame if not already installed. Adjust the height, check that it's straight and then tighten the bolt all the way or close the quick-release lever.
  • Step 3 Flip the bike over so it's balancing on the handlebars and seat. Put the front tire on the forks. Install the retention clips on either side of the wheel axle. Thread the axle bolts on each side by hand. If the front wheal is quick-release, just insert the axle in the fork all the way and close the handle.
  • Step 4 Straighten the wheel and turn it to make sure is spins freely without rubbing against the brake or forks. Hold one axle bolt with a wrench and use another wrench to tighten the bolt on the other side. Then tighten the bolt you were holding. Attach the reflectors to the wheel spokes with a screwdriver.
  • Step 5 Look for the "R" and "L" marking on the pedals designating right and left side. Slide the pedals on the crank arms and tighten the bolts.
  • Step 6 Turn the bike right side up. Pull the front brake several times. Lift the bike and spin the front wheel to make sure it spins freely. If it's rubbing, verify that the wheel is straight. If it still rubs, adjust the brake.
  • Step 7 Hold the front tire between your legs facing the bike while you turn the handlebars to straighten them. Tighten the bolt holding the handlebars.
  • Read more: How to Assemble a Bike | eHow.com http://www.ehow.com/how_2085771_assemble-bike.html#ixzz0ta5UfxHT
      this is an electric scotter schwinn s 500
    • Hammid Disu Jul 14, 2010
      hello,Your bike has arrived in a box and sitting in front of your door
      steps. Now all you have to do is put it together. Follow these steps
      below to assemble yourbike.
      Step 1: You will need Bicycle lubricant, An air pump, An Allen wrench set, An adjustable wrench, and A kickstand or wall (optional).
      Step 2: Remove the bike frame and all the parts from the box. Make sure everything is unwrapped and accounted for.
      Step 3: Squeeze bicycle lubricant on the front wheel axle. Set the wheel in position between the front brake pads. Slide the axle in, replace the spring and cap, and tighten.
      Step 4: Repeat the procedure with the rear wheel, and then gently pull up on the chain, setting it on the gears’ teeth.
      Step 5: Use an air pump to inflate the tires to the pressure recommended on their sidewalls.
      Step 6: Drop the seat post into the seat post tube and tighten the
      clamp. Make sure the seat is aligned with the frame’s top bar.
      Step 7: Slide the handlebar stem into the vertical handlebar tube.
      Adjust the position of the handlebars until they are perpendicular to
      the frontwheel and tighten the neck with an Allen wrench.
      Step 8: Find the pedal labeled “L.” Tightly screw it into the left crank by rotating the nut counter-clockwise with an adjustable wrench. Repeat the procedure with the right pedal, but this time screw it in clockwise.
      Step 9: Reconnect the brakes and make sure all screws and joints are tight before taking off on your new bike.
      you can as well visit this video site below for a comprehensive link,
      http://www.youtube.com/watch?v=KzUGWLhOZ...
      take care.
    Headlight bulb replacement. Does headlight need to be removed?
    If there is enough of room, you do not need to remove headlight assembly. If not remove whole assembly to make it easier to get to. For headlight assembly remove the 2-10mm bolts on top of assembly, there is a 10mm bolt on inside bottom that has to come out. Unplug the wires to assembly. When removing assembly, pull from grill side and wiggle it out. God-Bless! Remove the 3 10mm bolts from assembly.
    Mar 14, 2015 | 2004 Hyundai Sonata GLS
    How do I remove circuit board assembly
    If you need help that how remove circuit board assembly you can find your answer at http://www.dferrantielectronics.co.uk
    Jan 09, 2014 | Samsung Assembly Printed Circuit Board...
    How do I install the headlamp assembly to a 1999 Hyundai Elantra
    • Open the hood.
    • Now on top of the headlight assembly there are two bolts that need to be removed.
    • There are a couple of plastic pieces that need to be removed now.
    • Now remove that third bolt on the assembly that is down a bit lower.
    • Unhook the connector to the headlight bulb.
    • Now slide the assembly forward enough to unhook the blinker bulb connector.
    • Now slide the assembly the rest of the way out.
    • The bulbs are located under one of two caps that screw out.
    • Reverse to install the new assembly.
    • Hope this helps.
    Nov 20, 2011 | Cars & Trucks
    Powertec multi gym assembly manual
    Lost the instructions manual on assembly..powertec support. i need assembly instructions. Im from Argentina.
    I ask apologies for my bad speech. Help me please.
    leonidas33@hotmail.com.ar
    Jun 10, 2010 | Powertec WB-LS Workbench Leverage Gym
    Purchased range used. Burner Head assembly with
    Yes, you need a burner cap to sit on top of the burner assembly and create the normal star shape flame.
    Feb 09, 2010 | Kitchen Ranges
    HP OfficeJet J6480 Feed gear assembly needed!
    Check on www.partsurfer.hp.com it will tell you if the assembly is available, if not on HP site you will need a used unit to get parts from.
    Jan 19, 2010 | Office Equipment & Supplies
    How do i install a new front turn signal bulb on my 2000 pontiac montana
    You have to remove the headlight assembly to remove the turn light assemble. There are two mounting bolts that hold the headlight assembly to the frame that needs to be removed and one mounting bolt that holds the turn signal light assembly on the headlight assembly that needs to be removed. Once all three bolts (black plastic in colour with a wing nut) have been removed the headlight and turn signal assembly can just be removed. Take note that the assembly has a guild slot to be guild in place back when re installing the head light and turn signal assembly. Good luck and hope this helps. Keep me posted and I'll try to explain in a different way if i was un clear, Harder to explain then doing the job it self.
    Jul 20, 2009 | 2000 Pontiac Montana
    Right rear signal light needs replacing
    you need to remove the lamp assembly to replace the bulb. here is the procedure:
    Rear Lamp Assembly —Sable Four Door Removal and Installation
    1. Remove the luggage compartment scuff plate.
    1. Pull back the luggage compartment carpet.
    1. Disconnect the rear lamp assembly electrical connector.
    1. Remove the nuts.
    1. Remove the rear lamp assembly.
      1. Pull the lamp assembly away from the body.
      1. Disconnect the rear lamp assembly bulb connectors.
    1. s1h~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To prevent water from entering the luggage compartment, make sure the rubber grommet is fully seated.
      To install, reverse the removal procedure.
    Jun 25, 2009 | 2001 Mercury Sable
    Looking for directions on how to replace the main headlamp on 2002 pontiac grand prix. Buld comes out the back but no access. Looking for typical approach. Please advise
    You need to remove the entire headlamp assembly. There are a couple of screws on the top that hold it tight that have to be removed. After you remove the screws the assembly will be loose, but still held in place by a plastic tab towards the outside of the assembly. You just need to pull the assembly out. It may not come out easily. One side of mine came out easily, the other side I had to tug and pull pretty hard. After you replace the bulb you need to slide and push the assembly back in place. The tab needs to go in first. You will know when it is in place correctly when there about a half inch gap between the assembly and the bumper. If the assembly rests on the bumper you do not have it in correctly. Replace the screws on the top.
    Mar 07, 2009 | 2002 Pontiac Grand Prix
    How replace break light bulb in on a4 2005
    Replacement of any bulb in the Tail-light assembly is easier then one thinks.
    First thing you need to do is gain access to the trunk area. At the top of
    the tail-light area inside the trunk is a small circle that needs to be
    opened to expose the bolt that you need to remove.
    WARNING: Be careful not to loose this bolt or you are going to have to take
    apart your trunk interior to retrieve it.
    After the bolt is removed the Tail-light assembly will pull out as follows;
    Left side: pull out the right side of the assembly
    Right side: pull out the left side of the assembly.
    The out side of the assembly is held in place by 2 or 3 small nipples.
    There will only be one cable that is connected to the assembly. This does not
    have to be removed unless you really want to. On both sides of the assembly
    there are 2 clips that hold the light plate to the break light lens. After
    the clips are loosened the whole light bulb assembly can be removed and the
    bulbs replaced.
    Restoring the Break-light assembly.
    After you have replaced your bulbs and re attached the the bulb assembly, you
    will have to first fit the nipples on the outer side of the assembly then
    push the inter side into place. Replace the bolt and tighten. You are done.
    Jul 14, 2008 | 2005 Audi A4
    Cycling Logo
    42 people viewed this question
    Top Cycling Experts
    Marvin
    Marvin
    Michial Gueffroy
    Andrew Taylor
    Andrew Taylor
    Are you a Cycling Expert? Answer questions, earn points and help others
