Question about Fisher and Paykel Ovens
F3 fault code on fisher & paykel wall oven.
F3 default on fisher & paykel wall oven. Turned oven off at the main this has not helped.
  • Anonymous Mar 16, 2014
    Fisher and paykel
  • Fisher and P... Master
  • 3,051 Answers
HELLO THERE:
on these ovens the f-3 can sometime be incorporated with the f-4 error code also so here is the code and the things to look for both ok ?
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Posted on Jul 14, 2010
How do I replace the fan in a Fisher & Paykel 60cm oven
ill assume your referring to the cooking fan you see inside the oven and not the outer cooling fan, you will need to turn the breaker off outside to cut power to the oven then you will have to take the oven out of the wall and remove the back cover then its normally just 3 screws and the nut on the inside of the oven that holds the fan blade on (which is reverse threaded by the way) and it should come out
Sep 27, 2014 | Fisher and Paykel Ovens
Fisher & Paykel OR90 Oven just turned it self off and wont work the only thing working is the digital clock.
sounds like its gone in to automatic mode,try pressing the left two buttons and the second to last buttons at the same time
Mar 18, 2012 | Fisher and Paykel AeroTech OS302 Electric...
Fisher and Paykel Paprika Oven Top Elements Full hot!!
No controller. The switch for each element (called a simmerstat) is what controls the heat. It is a common fault and will be fixed if you instal new simmerstat for each faulty element.
Mar 17, 2012 | Fisher and Paykel Ovens
I have a fisher & paykel Astro built in wall oven which has a problem, after using the oven and then turning both switches off for some reason the rear element continues to stay on and will not switch...
Hi - theres a few components that may well cause this to happen - the power module which controls the heating & fans etc - isolating relay which switches the heater & fan relays - it only avctivates when a cook mode/cycle is selected.
One of the two components could be faulty - I guess a sparkie or techie may be your best option..
Aug 07, 2011 | Fisher and Paykel AeroTech OS302 Electric...
Fisher & Paykel double wall oven, bottom oven will not heat to set temp. Stops a 75 degrees
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | Fisher and Paykel Titan OD301M Electric...
What is the f7 fault code
I have the double wall ovens. The lower oven read door lock & flashed F7. Check to make sure the lock is not sticking out a bit, it is on the left side of the oven. I'm not sure if this is what the f7 fault code is, but it worked for me :)
Nov 24, 2010 | Fisher and Paykel AeroTech Double OD302...
I have a Fisher & Paykel double wall oven that I purchased in 2005. The top oven which was used most often stopped heating up to temperature in normal time. What used to take 5 minutes to get up to 250...
Google searches report that after running the self cleaning cycle this can happen. I am experiencing this issue with my Fisher&Paykel AeroTech Double OD302 but with the BOTTOM oven. I'm concerned as Thanksgiving is coming up and I need this baby working!
Nov 08, 2010 | Fisher and Paykel AeroTech Double OD302...
F3 Fault Code appears
What it needs is a new temperature sensor.
Unplug the range. Open the oven. Look in the top right or left side of the oven for a metal rod about 1/2 the size of a pencil. Remove the screws holding it in. Pull it out very carefully. Unplug the wire connector. Reverse this order to replace the temperature sensor.
Sep 15, 2009 | Maytag 30" Built-In Double Electric Wall...
Fisher and paykel B1600E multifunction stove manual
I have a PDF copy of the Fisher & Paykel B1600E user manual
Nov 12, 2008 | Fisher and Paykel AeroTech - OS302M...
Ovens Logo
803 people viewed this question
Top Fisher and Paykel Ovens Experts
Joseph Hoffmann
Oloyede Monsuru
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
