Question about Mercury P4VM800M7 Motherboard
I have no mercury motherboard.i have problem in sound device . there is n o sound in my computer. i want sound card installer
    Novelist:
    Champion:
  • 226 Answers
Firstly check the volume is not low or muted on both windows and the speakers. In windows click the speaker icon in the bottom right of your screen, check the volume is turned up. Then click mixer or advanced and check that all volumes are turned up.
If using a laptop, check that the hotkey control for volume is on. You will see an audio icon on one of your ‘F’ keys, hold the Fn button located near the ctrl and press the volume function key.
Next open Device Manager from Control Panel and check there are no yellow exclamation marks on any drivers. If there are then you need a new driver.
If you are still having issues the sound card may be faulty, this is usually integrated into the motherboard. In a desktop PC you could buy a new PCI soundcard if you have a spare PCI slot in your machine.
You need to goto the manufacturers website, find their support section and there should be a list of drivers for your specific machine. Installing these should resolve your problem. I have a list of links to most manufacturers drivers on my website.
Hope this helps,
www.PuterCare.com
Posted on Jul 14, 2010
I want display drive for mercury mvp 890v
Hello try the driver form here:
http://www.mercury-pc.com/downloads_list.php?productid=742
Please unzip the file before you install.
Or add a AGP graphic card that supports your windows system.
Good luck
Jun 10, 2011 | Mercury P4VM800M7 Motherboard
Mercury sound driver
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 23, 2011 | Mercury P4VM800M7 Motherboard
I have no sound driver then how i can install a sound driver of mercury board,
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
Feb 03, 2011 | Mercury P4VM800M7 Motherboard
Need mercury sound drivers for windows XP
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 20, 2011 | Mercury P4VM800M7 Motherboard
I need sound software for my computer
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
Dec 14, 2010 | Mercury P4VM800M7 Motherboard
Sound driver
If you need sound drivers for your mecury P4VM800M7 Mainboard, download @ http://www.mercury-pc.com/downloads_list.php?productid=644
Nov 07, 2010 | Mercury P4VM800M7 Motherboard
There is no sound device installed on my computer
Mercury P4VM800M7
Check the Audio jumpers on the motherboard.
See page 1, (AUDIO1). There should be two jumpers over pins 9&10 and pins
5&6 for the rear audio ports to function. See pages 17 in you’re manual for a closer look.
Next check the bios. See pages 30 in you’re manual.
Bios, Audio setting should be set to [Enabled]. Save and exit the bios.
Open windows control panel than open Sound and Audio Devices icon.
Check the Audio tab and the Voice tab. Both should list as AC'97.
If not re-install you're audio software from the CD that came with you're MB.
OR you can download it from the link provided below;
http://download.cnet.com/Audio-Realtek-ALC655-AC-97-AUDIO/3000-2110_4-168843.html
If you still receive feed-back try another speaker system. (Still no change)? Audio controller is defective. Replace with a PCI sound card.
Cheers'
Mike
Apr 18, 2010 | Mercury P4VM800M7 Motherboard
My motherboard is mercury with an inbuilt soundcard. the soundcard is not working
Do you know for sure your speakers are working? Or is Windows saying there's no sound device? Does the Device Manager tree show any problems (! symbol) by sound hardware entries? Has the integrated sound been disabled in the BIOS settings?
Try downloading the sound drivers from the motherboard manufacturer's website and reinstall. This often solves the problem.
If the integrated sound has failed, install a PCI sound card if there is an open slot on the board. Or you can also purchase a USB external sound card and plug it into an open USB port, and you don't even need to open the computer. Just be sure to disable the integrated sound in the motherboard BIOS setup.
Thanks for using Fixya! Hope your computer is talking again soon.
Feb 04, 2010 | Compaq Audio card Sound Card
Mercury P4VM800M7 Motherboard Logo
127 people viewed this question
Top Mercury Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
vsri9
Computer Links
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
