Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Intex salt water chlorinator I added a higher flow pump and chlorine levels seem low no matter how many hours I run the chlorinator
  • 297 Answers
Your pump has nothing to do with chlorine generation.
You need to get a salt test kit that reads in #'s not colors.
Now get your salt to 3000ppm or as close to it as you can.
The amount of salt reccomended in the manual is just a starting point
any lower than 2800 and you will not produce enough sanitizer and over 3600 and your pool can go cloudy, taste bad, and rust metal parts
Posted on Jul 14, 2010
  • mark Gianotto Jul 16, 2010
    It would be nice if you used the rating syste
Water is clear but chlorine and copper still low, what I need to do?
The salt generator only works when the pool pump is running. If you want a higher chlorine level, run the pump longer. Also, to keep your chlorine in the pool, be sure to adjust the stabilizer level. (25 ppm for salt systems). As for copper, this level should be 0 at all times
Jul 19, 2014 | Intex Krystal Clear Saltwater System Pool...
Just purchased and installed Intex salt water system. It shows low flow and now, after 5 days of installment, the water is completely green (expecting Swam Thing to come out!) I need your guidance to...
Seems like you may not have the pump and the salt chlorinator in sync... If your water is dark green and not a big pool, you may want to drain and refill, if you have a large pool, you may want to shock and then try the following...
1.Make sure you have added the correct amount of salt...
2.Set your timer for your pump for 12 hrs.
3.Wait 15 minutes and then turn on your intex salt water system..
4.Set you hrs of operation on your salt water system for 10 to 11 hrs...
5.After running the system for 3 days, check your chlorine level..
If water clears and chlorine level is high, adjust the time.. You will have to re-sync the pump and chlorinator.. If the pump turns off before the chlorinator finishes it's cycle, you will get a "LOW FLOW" alarm..
I hope this helps and good luck.. Please rate and comment on the information provided.
Jul 26, 2011 | Intex Automatic Salt Water System for ...
What is the best time of day to run the Salt Water System...Morning, Afternoon or Evening?.....and how long? Manual says run for about three hours but that doesn't seem enough...we have been having...
I have an 18 X 33 oval and temparatures here range from 80 to 102 in the summer. I run my cycles at 10 to 12 hrs pump with 8 to 10 hrs chlorinator. Water stays crystal clear, no cloudy.. Now...if you don't keep the electrolytic cell clean and maintain the proper salt levels, you will struggle with making free chlorine...
Hope I helped??? AND... I HAVE NOT ADDED ANY CHEMICALS TO MY POOL IN THE 2 YEARS I'VE HAD MY INTEX SYSTEM...
Jul 18, 2011 | Intex Automatic Salt Water System for ...
We have a Krystal Clear Saltwater System Model CS8110. We are first time pool buyers. We set up the pool last week and despite several "boosts" the chlorine level is very low. The pool store...
You should always follow the instructions on the manual .. I have a 18X33X4 oval and had to start with over 350 lbs of salt and ran the pump without the chlorinator for 24 hours to properly disolve the salt. Then, I started with 12 hrs pump cycle with 10 hrs of chlorination in between the 12 hrs. Keep checking the chlorine level and adjust time from there. Currently at temperatures of 85 to 100, I run the system at 10 hrs pump with 8 hrs chrlorinator and water is Crystal Clear... In the 2 years with the intex system, I have not added any chemicals to my pool. I once had an issue when the water level went low while I was on vacation, when I came back, the chrolinator had turned off due to low flow and my pool water was green.. As soon as I re-started the cycle, a few days later, Crystal Clear again... NO CHEMICALS OR SHOCK added.... Hope this helps....
Jul 15, 2011 | Intex Automatic Salt Water System for ...
I run the filter pump then turn on the salt water system for 4 hours and test for the chlorine and it is always very low or no chlorine and the ph is always high
pH will always rise over time when using a salt generator. You'll need to periodically add acid to counteract this affect. As far as low chlorine levels try running the system longer...An average pools circulation system is setup to turn over the pool water once in about 8 hours. Running your system longer should lead to a higher chlorine residual and overall cleaner water.
John
Apr 26, 2011 | Intex Automatic Salt Water System for ...
We have a 15' by 48 " pool with an Intex saltwater chlorinator.About two weeks ago the low salt light started flashing .We ended up adding way too much salt (160 lbs)because the low salt light kept...
First of all green water can arrise from a lot of different situation.
Low chlorine is one of them coupled with the crappy filter that comes with the intex pools it does not filter enough.
Start with getting your salt level to 3000ppm
any lower than 2700 and you will not generate enough chlorine and any higher than 3500 and you could go cloudy or trigger high salt alarms
you need to get the salt test kit that reads in #'s not color the color ones has to much of a variance
once your salt is at 3000 clean your cell then filter filter filter
I run my filter 24/7 if it is not generating chlorine I am filtering.
Clean your cartridge every few days
I have had the same 2 cartridges for this being my 4th season and have never been green or replaced the filters.
Also I reccomend a non foaming algecide
Just follow directions on bottle
Aug 29, 2010 | Intex Automatic Salt Water System for ...
Hi i have a 18 x 48 above ground intex frame pool with a salt water pump /chlorinator system. i have put the required amount of salt in 75 kg and it has fully desolved. the alarm keep coming up on the pump...
the amount of salt that they reccomend in the book is just a starting point
Get your pool to as close to 3000ppm as possible
lower than 2800ppm and you will not produce enough chlorine
any higher than 3500ppm and you can trigger high salt alarm, have bad tasting water, or even get cloudy water
Like you have done, when adding salt , filter only for 6 hours or so to fully disolve
Jul 18, 2010 | Intex Automatic Salt Water System for ...
My water was crystal clear when delivered. I added the salt, ran the filter pump for 24 hrs as instructed. Turned on my Intex saltwater pump and within an hour water is green. Cannot find anything on...
I am not impressed at all with these salt water chlorinators.Shock the water and keep the filter running next day add a powdered chlorine.filter still running. check the balance with test strip in about four hours.If chlorine level is good start vacuming the algee off the bottom of the pool. Now throw away the salt generator and stay with the chlorine packs every week to two weeks continue to monitor with test strips
Jun 17, 2010 | Intex Automatic Salt Water System for ...
I have an intex chlorinator and an intex 24' x 48" round pool. I added only 250 lbs of salt, but the table said 290 lbs. I never got a "low salt" reading. When the water level got low I added water and...
high chlorine can cause problems too it will give false readings for your ph and alkalinity.
The most important thing to remeber is that there is a sequence to follow.
First buy a test kit for salt about 11 bucks for 10 tests. you need to have the ppm's at 3000
if it is to high drain 20% water re-fill and filter/curculate for 6 hours then test again. once at 3000 then go for your chlorine it should be between 1.0 and 1.5 with a test kit now with those 2 in line go for ph adjustment ph should be as close 2 7.6 as possible. Ph will cause more problems like cloudy water or algea more than anything else.
another thing you need to realize is that the intex salt system sucks. Once you set it for the # of hours to chlorinate you are basically guessing as to what is needed. Yes there is a guidence chart as to hours to run but it is over kill and lets too much chlorine be generated start with 3-4 hours of generating but remember also that at 4 hours generating that is nowhere near enough filtering
you will need to shut power off get it out of sleep mode and continue to filter
on avberage a pool should be turned over 3 times a day my pool 7000gl and the 2000gph all in one intex salt pump needs run at least 10 hours a day alone without the chlorinator
my pool only 18' so with your total gallons it will be longer
one last thing to consider is that when in chlorine generating mode the filter slows down because of all the electronics. You can not hear it happen but if you put your hand in front of the discharge you can tell
Jun 27, 2009 | Intex Automatic Salt Water System for ...
No chlorine reading
Salt is sodium chloride, you can only measure salt levels now as your CL (cloride) is bound to a NA (sodium). Table salt =NACL, Your Intex system will tell you if your salt level is too high or too low but your old test equipment for free chlorine will continue to tell you no chlorine as it can't react with the chloride any longer as it is bound to the salt. That is why they tell you you never have to add more because the salt stabilizes it. Your chlorine is there it's bound to the salt. Use the pool it's fine and it makes your water feel really soft! Just keep the salt level right and your fine> It's confusing as they call the unit a chlorine generator! I had the same issue, called Intex and they told me the above.
Jun 01, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
490 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
