I want a download of the operating manual. When I press the copier button, it will start blinking and will not copy. At times it will be showing F35. What should I do.
  • Andy Bell
    Andy Bell Jul 14, 2010
    what is the make and model
  • Valerio Jul 15, 2010
    hello, that model of
    copier you? Hello Valerio
  • 41 Answers
Go the site of your vendor, and u have to find out driver download page thats all, then select model ............
Posted on Jul 24, 2010
I need to set the date on my Canon P23-DH V calculator, and don't know how to do it
Press and hold the ClockDate Set button for three seconds until the display shows the date with the first digit blinking. Enter a two-digit month, a two-digit date, and a four-digit year, followed by the ClockDate Set button.
Press and release the ClockDate Set button. Press and hold it for three seconds until the display shows the time with the first digit blinking. Enter a four-digit time, press AM/PM as appropriate, then press the ClockDate Set button. Press CE/C to finish and return to calculation mode.
If you can't find yours, you can download a new copy of the manual from the manufacturer's web site at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=346&modelid=15431
Jun 16, 2010 | Canon P23-DHV Calculator
How do i set my date and time on my p23-dh v
Apr 27, 2010 | Canon P23-DH Calculator
I am trying to set time and date
You can download a copy of the manual from the manufacturer's web site at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=346&modelid=15431
Apr 23, 2010 | Canon P23-DHV Calculator
How do you set the time and date?
Apr 07, 2010 | Canon P23-DH Calculator
Have a P23-DH V Canon Calculator. Am trying to
Mar 30, 2010 | Canon P23-DHV Calculator
Setting the date and time
If you've misplaced your manual, you can download a new copy of the manual from http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=346&modelid=15431
Oct 13, 2009 | Canon P23-DHV Calculator
F35 error code
Warm-up was not completed
within a specified period from
the start of warm-up.
• The low fixing temperature
fault detection software is
activated.
The fixing temperature at the
end of warm-up is less than the
specified temperature.
activated.
The fixing lamp does not turn
OFF within the specified period.
SOLUTION
Rewrite the data at
address “P47” in the
25 mode to “0”.
(1) Turn the main switch OFF.
(2) While pressing the numerical keys 2 and 5 of the copy
quantity setting button, turn the main switch ON. This
will enable the 25 Mode. The 25 Mode is used exclusively
to rewrite in memory and, therefore, does not
support normal copy operations.
Apr 21, 2009 | Konica Minolta Office Equipment & Supplies
Locked up AL-1642CS with blinking Drum Light
Older Sharp AL copiers will go on working with the drum light blinking, but yours will not. Newer models do stop working when the drum reaches its limit. Now keep in mind that just as almost every copier in the market, these units count the copies they make in order to determine toner & drum life. So it is possible to reset the drum counter if you inspect the unit and see no markings or visible wear & tear. Also keep in mind that the toner & drum units have been the same for all AL units through time, so there are plenty of good replacements in the market (not recycled, but re-manufactured or brand-new compatibles).
As for your unit, if the drum is Sharp original or a good quality replacement, you should have to do nothing after installation, for the internal chip in the drum will tell the copier to reset the counter and begin working automatically. However if that is not the case, or should you want to reset the counter on your existing drum, this is the correct sequence to do so.
  1. Identify the buttons used for adjusting exposure (darker or lighter copies), amount of copies, clear copies and start copying.
  2. Now press the following sequence of buttons: [CLR], [EXPOSURE], [CLR], [EXPOSURE]
  3. Your unit should turn off the numbers in the panel.
  4. Now press 24 as if asking for 24 copies and press [START].
  5. Press 07 as if asking for 7 copies and press [START].
  6. Your unit should restart by itself and start working normally.
Be blessed.
Nov 07, 2008 | Sharp AL-1641CS Laser Digital Copier
Konica 1015
While holding 2 and 5 turn on machine.Press 4 then 7 then p.Press 0 then p.Turn off then on ,this will reset copier if it does not have a fuser problem which is f35.
Aug 01, 2008 | Ricoh 6513 Copier
Cant get rid of blinking error message, nothing works
H4-00 is a fuser related service code. you need to get into the simulation programs and run sim 14 to reset the code. Make sure there is no paper jammed in the fuser. (The hot part on the right side inside the door)
Dec 02, 2007 | Sharp AL-1655CS Copier
29 people viewed this question
k24674
