Question about Apple MacBook Pro Notebook
My macbook pro will not turn on is there something that I can try?
  • 160 Answers
Is it hooked up to a power source? Are you trying just with the battery? Try holding the shift ket down while pressing the power button, but make sure you are connected to a working power source. Try eliminating any extension cords, power strips, etc..
Posted on Jul 15, 2010
Pro 435pu
that should find it automatically just turn your computer on and tv and set to hdmi 1 or whatever it should be there shoud no have to set anything up if it is a newer macbook pro or something , goto youtube if this does not work
Mar 28, 2014 | Televison & Video
How do i fix my macbook pro?
Is it plugged in? Is the battery functioning? Try holding down the keys command/option/p/r while turning the power on to your mac. Let it reset a couple of times. You will know it is resseting by hearing the apple chimb several times.
Jun 25, 2013 | Apple MacBook Pro PC Notebook
2006 Macbook Pro replacement screen problems
You have a bad driver. Reinstall your screen driver or clear your P ram by holding the letters P and R and the control button when you boot your laptop. Hold them until it chimes and reboots.
Apr 12, 2013 | Apple MacBook Pro PC Notebook
Macbook pro when i hit the (return/backspace/delete) button it only moves one letter at a time. also every letter i type it makes a weird sound like stop
Something was turned on with in "Universal Access" under system preferences. Most likely it is Sticky Keys. This can be turned off under the keyboard tab of "Universal Access"
Oct 17, 2012 | Apple MACBOOK PRO 13 INCH NOTEBOOK 266 GHz...
Keyboard Backlit not coming on at all
Set your backlighting in
Apple menu
System Preferences
Keyboard.
otherwise try:
Resetting the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jul 08, 2012 | Apple MacBook Air
My MacBook pro is asking for a system lock pin how do I bypass it because I don't know the pin
You can reset your password with the OS disc. Reboot using the disc and choose Reset Password from the menu bar.
May 20, 2012 | Apple MacBook Pro Notebook
How do you turn off DOS mode on a 13" MacBook Pro?
Is this a trick question? There is no "DOS mode" on a MacBook Pro.
Do you have WIndows installed as part of Boot Camp, and your machine is booting into Windows? To boot back into the Mac, either use the Boot Camp control panel in Windows, or hold down the Option key after you hear the startup chime and select the OS X partition to boot from.
Nov 14, 2010 | Apple 13.3 MacBook Pro Notebook Computer ...
Cursor and keys are unresponsive tryed 2 check if it was number lock witch its not
There has been a known issue with the first key (any key) of a Macbook Pro, not responding when typed and Apple appears to have addressed this with this software update for the Macbook and Macbook Pro:
Run the Macbook Pro Software Update v1.1 and the Macbook, Macbook Pro Keyboard Firmware update v 1.0 per this link:
Keyboard Issues with Macbook Pro
Let me know if this helps.
Regards,
-Mactechtrainer
Mar 24, 2010 | Apple MacBook Pro Notebook
The keyboard of my macbook pro stopped working it
Once it turns on, use the mouse and either try updating keyboard drivers from device manager under the control panel, or last resort, try system restore
Aug 25, 2009 | Apple MacBook Pro Notebook
Apple MacBook Pro Notebook Logo
105 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
