Have a samsung lcd monitor/tv When starting up it takes a long time before it strarts up. During this time speaker makes a ticking sound and then then display starts to flicker and finally starts up. have disassabled the unit could not find a apparant problem
    Problem Solver:
YOU HAVE A CAP PROBLEM ON YOUR MAIN POWER SUPPLY BOARD . CHECK ON THE MAIN POWER SUPPLY BOARD ONE OF THE CAPS LOOK SWOLLEN ON THE TOP. CHANGE THAT ONE
Posted on Sep 07, 2010
17" flatron crt monitor only green led blinking and tick tick sound .No display
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | LG Flatron F700P 17" CRT Monitor
How to fix mute
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it in XP
right click on the speaker icon in the bottom toolbar select playback devices should be a green tick in the speakers if not right click select configure also check the communications tab make sure the are not muted
hope it helps W7
May 28, 2012 | Samsung T220HD LCD Monitor
Cannot use microphone during chatting in WINDOWS LIVE MESSENGER
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
don
Feb 16, 2011 | Samsung SyncMaster 713BM 17" LCD Monitor
No sound on my Samsung SyncMaster 930MP All drivers are updated
Lets find out first if it is the monitor amplifiers problem or PC sound card problem.
Try feeding the monitor with sound source such as MP3 player to see if you can get the sound or not, the sound system in the monitor is nothing more than Powered PC speakers mounted inside the monitor, no driver required to make the sound to work.
If it is the amp problem inside, you will be better off spending money on a good set of Powered speakers system that will have 100 times better sound quality than the monitor built-in speakers.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Dec 31, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
No sound from my Samsung 40" flat screen tv
probably your cable or sat box malfunctioned. try unplugging the power for 2 minutes and then plugging it back in. my cablebox would do that to me all the time. let me know if this doesn't help. check sound on dvd or other sources to narrow that down.
Jun 06, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
LCD TV LA40R81BM/XTL tv tick tick sound 5min then strat
Hi my name is Roety,
I can help you with your issue ,
This is most likely a power supply issue
I usually replace the swollen capacitors I can see
A repairman would charge about $300 to replace them for you.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Dec 15, 2009 | Samsung LA40A450 40 in. LCD TV
Samsung 2253bw lcd monitor makes loud, fast ticking noise > 10hz. Noise occurs even when monitor is powered off with switch.
Turned out ticking noise was harmonic vibration triggered by a nearby airconditioning compressor. Once I guessed the cause, putting a rubber pad under the monitor to dampen the vibrations eliminated the ticking. Removing the pad caused the ticking to reoccur. Ditto with turning the A/C off or on. Weird!
Jun 05, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Samsung-SyncMaster-940MW power problems
I experience the same "power on" problem with mine, bought february 2007.
Just called the Dutch servicedesk of Samsung Electronics, just gave the serialnumber, next tuesday I will receive a new monitor.
Thumbs up this time for Samsung service
Sep 02, 2008 | Samsung SyncMaster 940MW 19" LCD Monitor
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
