Question about Cuisinart DGB-600BC 10-Cup Coffee Maker
Have a Cuisinart modle DGB600BC coffee maker with grinder that has quit working. When you push the start button the red light goes on while holding the button but it does not start. Releasing the button - the light goes out and the beeping starts. Can the electronics be replaced?
Did you find a solution for this? Mine does the same thing.
Posted on Sep 12, 2010
  • Fixit Fox Oct 18, 2014
    There is a button on the inside the grinder/water reservoir compartment of the machine. What happens is the plastic tab on the underside of the lid breaks, disabling its ability to press the "lid closed" button. So the machine thinks the lid is still open, hence the warning sound.
DCC-790 Cuisinart coffe maker won't grind
what showing on display ,when push to make coffee? If showing grinder block-then you have to replace the grinder to fix it. Try to grind coffee ,but without beans-if grinder start but rotate slowly -you have to replace grinder and change the brushes of the motor.
Oct 04, 2013 | Saeco Royal Professional Espresso Machine
Doesn't work, just beeps
press and hold the power button, that should reset the unit.
Oct 02, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Problem with a Cuisinart Coffee Maker
Hi I have a dgb600bc coffee maker the beans do not grind all the way and it makes a funny noise when grinding. thanks
Nov 28, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
DGB600BC, only completes ~25% of brew cycle (based on water level
run some straight white vinegar through it and when it starts to pump through shut if off for a few hours and let the vinegar sit in the tubes. start it up again and let it finish. run the same pot of vinegar through again about 2 more times. then rinse with cold water about 4 times through and see if this helps.
Oct 04, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
It wont stop beeping
Is it still beeping? ;) It will beep if you have the automatic brewing programed and the grinder and it's lid are not in place.Once you have put the grinder back in place, push the small white button down that is on the grinder lid. The beeping will stop. Don't press the program button again or it will start beeping again...but if you do, just push that white button again.
Aug 12, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
DGB-600BC - Coffee maker (grinder combo)
Unplug for 20 minutes or longer - this one has a longer than normal reset.
Dec 07, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Cuisinart DCC2000 quits brewing after 1or 2 cups
I have the same problem with the exact same coffee maker I have tried pushing the 1-4 cups button. That worked for a couple weeks, now it is back to only brewing half the water in reservoir whether I push the 1-4 button or not. It is very annoying.
Nov 14, 2008 | Cuisinart DCC-1200 Coffee Maker
Won't grind
the container were the coffee bean go .remove the bean, in the hole were the coffee goes you see the grinder wheel clean the grinder wheel with a brush you may have coffee residue on the wheel thanks for using fixya pierre
Feb 07, 2008 | Cuisinart DGB-300 Coffee Maker
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Nothing works, only flashing program light and time
listen to this! we called Cuisinart at 1-800-726-0190 and they are going to sihp us a replacement coffee maker and all they are going to charge us it the price of shipping. good news since spending so much for a product. great customer service.
May 28, 2007 | Cuisinart Thermal DGB-600 Grinder
Cuisinart DGB-600BC 10-Cup Coffee Maker Logo
390 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
