Question about Jazz HDV178 High Definition Camcorder
I have lost my battery charger and I tryed with a similar one (same mini USB, same voltage same Ampere) but it was the Blackberry one. Camera swich on but battery doesn't charge. What to do? Buy a new one? where? I'm In Italy. thankyou
  • 560 Answers
Hi. I found this on ebay for US$12.94 and will ship to Italy for an additional cost. Just ask the seller.
http://cgi.ebay.com/JAZZ-ELITE-HDV178-CAMCORDER-WALL-CHARGER-AC-ADAPTER-/130404912573?cmd=ViewItem&pt=Digital_Camera_Accessories&hash=item1e5cbd0dbd
Posted on Jul 14, 2010
  • 6,826 Answers
Try to get a generic battery charger for it that has the same volts, amps, and polarity. Try Radio Shack if you have them in Italy. Or, try a department store.
Digital Camera Travel Charger for Canon
Have you actually checked the output of the charger with a digital volt/ohm meter to determine if there is any voltage present? What type of terminal is on the end of the charger, barrel type, mini or micro usb?
Jul 10, 2014 | Hi-Capacity Cameras
I dont have my chrager and my phone is dead
You can charge the battery of your iPhone by connecting it to a USB-port of a computer.
If you're on the road, try a gas station with a shop and look if they sell alternative USB or car chargers for your iPhone. A USB charger will always have an output of 5 volt (5V) but the current must be minimum 1 ampere or 1000 mili Ampere (1A or 1000mA).
When you see a charger with (5V/500mA) it will not work.
-(5V/1A) = OK
-(5V/2,2A) = OK
-(5V/1000mA) = OK
-(5V/2500mA) = OK
Feb 08, 2014 | Apple iPhone Cell Phones
I have one i2! which I used to use with an iPod, but now I tried to use it with an iPhone and with an iPad, and the USB doesn't show the charging capability any more. Does the i2! not work with iPhone and...
All iPhones and iPad's charge with a USB cable. Everybody knows that. What moest people don't know is that it's a bit more technical then that. Every USB port has an electrical voltage of 5 Volts. The voltage of a electrical socket is in Europe 230 or 240 Volts, in America it is (i think) 110 Volts. In a car there is a voltage of 12 Volt. An adapter (charger) will convert a higher voltage to the 5Volt needed for the USB-port. Now i did talk about voltage, but not about current. The current is the amount of electricity running through the device. An old ipod can charge with a current of about 700mA (milli Ampere). Newer iPod's and all iPhone's need 1000mA (or 1A = 1 Ampere). An iPad needs even more. The largest component inside an iPad is the battery. It would take too long to charge this large battery at 1000mA (1A) so it needs 2100mA (2,1 A). If you check the label or the printed information on your FM-transmitter you will see the Ampere rate will we too low, and that's why your other devices won't charge. I suggest you to go to a store and buy a compatible charger or FM-transmitter.
Aug 19, 2013 | Aerielle FMT300IP Model i2i Universal FM...
My blackberry bold keeps showing a battery with a redline on the screen instead of booting.
the device is drained to the bone this should go away and boot after 30 minutes max. I'm assuming you are using the original blackberry charger using a charger that fits but doesn't match the voltage/amperage that the blackberry charger outputs you wont be able to get rid of the drained battery screen if your blackberry haves juice you can use a non-approved weaker charger but that screen means it needs the original....also the blackberry USB is lets the same amount of electricity
Apr 09, 2011 | RIM BlackBerry Bold Smartphone
I need to know what the charger looks like. does it take batterys? where do they go? how do I charge the camara?
You can purchase a charger for this camera at http://www.amazon.com/Wall-Charger-Adapter-Vivitar-Vivicam/dp/B003M6BXBO/ref=pd_sim_e_1
Feb 28, 2011 | Vivitar ViviCam 8025 Digital Camera
Lost power charger will a telephone charger with the right dc voltage work? jazz hdv188 also its a usb jack in camera instead of the little round holed one
Some phones charge the battery in the camera like a phone, but many do not. The USB connection is meant to be used to transfer photos from the camera to a computer. If your (now lost) charger was plugged into the camera to charge it, and it plugged into the USB connector, then you can charge the camera with any lead that will fit the USB connector, as this will have a standard voltage. You can even charge it from the computer, without buying a separate charger.
However, if your charger charged the batteries outside the phone, by removing them from the phone and placing them in the charger, then it is very unlikely that they will charge in the phone, whatever you connect to it. I have a camera just like this, that requires an external charger.
Oct 29, 2010 | Cameras
For v3 razr charger can you use it with htc touch pro 2? it fits mini usb. Are voltages and amps similar?
USB Voltage is always 5V. That is standard. As far as your charger for your V3, different motorola chargers have different ampere or mA, but I wouldn't worry about it, you cannot overpower the Touch, it just may charge slower if the charger for the V3 is a weak one.
Other than that though, if it fits USB, you should definitely be fine.
Dec 02, 2009 | Motorola Mobility RAZR V3
Motorola S9 headset won't charge batteries
This might work if you aren't using the ORIGINAL charger. I had this problem when my cat chewed through the original Motorola charger. I figured my Blackberry charger would work fine, but it didn't. I then discovered that my Blackberry charger was 700mAH and the broken charger was only 550mAH. When I found another charger with the proper power it charged. I also found that it worked when plugging it into my computer with a standard mini USB. I hope this helps.
Jun 03, 2009 | Motorola Mobility S9 Headphones
Hello, my godmom just purchased a Brand new Blackberry Curve phone.When the saler put the battery in the phone, it didn't power on and she said that the battery was not charged and that we had to charge...
Its very hard to pinpoint the problem from your few descriptions. However since the light came on it mostly means the charger should be okay. As for the phone, if the battery is really dead, it sometime takes up to 30 minutes before it shows that it is charging. SO leave it plugged in for some time to see what happenes. If it did not come on after that then the phone is bad. Just to make eveything sure, you can also try any other MINI USB charger or a simple MINI USB cord to the computer to charge the phone with as well. They all work on the Blackberry
May 06, 2009 | RIM BlackBerry Curve 8310 Smartphone
Sony DCR-PC110E - can I charge the battery through USB?
no man u can"t....in all sony brands the mini usb is meant only for data transfer...so better you go for a an ac power adopter...mail me at sharuputta@gmail.com
Jan 26, 2009 | Sony Handycam DCR-PC110 Mini DV Digital...
Jazz HDV178 High Definition Camcorder Logo
583 people viewed this question
Top Jazz Video Cameras Experts
mohamed salim shaikh
Are you a Jazz Video Camera Expert? Answer questions, earn points and help others
