Question about Whirlpool GBD277PD Electric Double Oven
OVEN CUTS OFF POWER
IS THE INTERNAL LIGHT BULB A FUSE?
    President:
  • 1,891 Answers
No.. mm/ if this does not help then more info is needed like model/ brand / and the real problem your having ..
Posted on Jul 15, 2010
Do I have to replace the control panel on the oven if it isn't lit?
Without a full schematic, and an understanding of electrical wiring, you have no idea if the internal 120 vac light is even on the same circuit as the control panel. Electric ranges are generally powered by 220vac, which means that both 120 lines are run through the unit.
you could have full power to the appliance bulb and have a blown fuse to the control panel, how much of the range actually functions at the moment would be important information to share.
Mar 04, 2015 | Whirlpool Gold 30 in. Double Electric Wall...
What can cause the Circuit Breaker to trip out when the door of my Zanussi ZYB594X oven is opened and the internal light comes on?
I suppose, the light did not work because the circuit breaker was released.
In this case, try to find a short-circuit in the following circuit : microswitch (door lock) - power board - light bulb.
Dado
Oct 18, 2014 | Zanussi Ovens
Electrical short circuit
Likely an internal fuse
Oct 05, 2017 | GE Ovens
My wife was heating the oven to 400 degrees for baking. As she walked away, she heard a pop sound. The control panel was off. I checked the breaker and it was OK. While I was in the oven, I checked the...
it sounds like something shorted in the clock assy. check the elements to see if they are damaged,sometimes they blow apart and also take out the clock assy.when you change the bulb anywhere you want to make sure the power is off to it,shut off the light switch and when you open the door hold in the door switch or just unplug it or kill the breaker,you can try to get the rest of the bulb out with a pair of needlenose plyers,next time send the model number and i can look up your machine to help you find out how much the part is and part number.
May 14, 2011 | Frigidaire 30 in. Electric Gallery Pro...
My oven light bulb keeps blowing on my Whirlpool oven.
becoz of some problem that might be your oven is on for long time
Apr 10, 2010 | Ovens
Oven elements suddenly quit
check your power supply for 240volts, at your service panel and have it checked at the range thats the easiest step to start with and if both elements are that way thats what it sounds like now,theres no internal fuse I know about.
Jul 23, 2009 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
I have an AEG B6139 electric oven and the interior light and fan comes on but the oven will not heat up despite putting the setting on high. Next to the dial for the interior light and fan a small red...
Hi I am Vortash it sounds to me as if the oven element has blown you need to have it tested by an engineer .. he will check for continuity .. if it is open circuit then you will need to replace it .
I would hev thought that if the fuse had gone the oven would have no light or functions of any kind as the power would be off .. unless this model has an extra fuse fopr the element alone doubtful however it does have a heat sensor cut off above the oven that cuts off the element from the supply .. If you have no manual for this unit you will find one free to download from http://www.safemanuals.com .. regards Vortash
Apr 29, 2009 | AEG B3101-4 Electric Single Oven
Electrolux EOB5630 oven cuts out
First thing you would want to check is, make sure you don't have any issues with the electrical connection to the oven first. Possible cuircut breaker issue.
Check these things first, you are probably going to find a loose connection somewhere. If that doesn't fix your problem.
Let me know and we can go from there.
May 15, 2008 | Electrolux EOB5630 Ultrafan Electric...
Cuts out over 100deg Celcius
the oven cut out stat may be cutting out to early first try this, it should be mounted at the top of the oven unit.
Jun 23, 2007 | Baumatic B180 Electric Single Oven
Light
easy. unscrew bulb cover then unscrew bulb. switch off at wall first.make sure you use a heat-proof bulb to replace
Apr 22, 2007 | Baumatic B180 Electric Single Oven
Whirlpool GBD277PD Electric Double Oven Logo
91 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
