Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Condenser fan 220v
I am looking for a replacement part for my Whirlpool fridge: 3XART735G00:
Condenser fan 220v
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool refrigerator
you can try replacing the overload relay mounted onthe side of the compressor ( kit number 4387835) sounds like its gone bad, trying to start yor compressor, but tripping off on overload.
Posted on Jan 12, 2009
localwonder
  • 6784 Answers
SOURCE: Whirlpool Refrigerator not working
Hi. Due to the fact that the fans are not operational, this will confirm that the Main PCB has failed. This is the main power control board. It must be replaced, asap. The general location of this affected board will be just behind an access panel, near the compressor unit, or on the backside, mounted in the middle section of the unit.
Once the Main PCB board is replaced, the unit will return to its normal operating status.
Posted on Dec 21, 2009
hh0405
  • 77 Answers
SOURCE: Refrigirator stop cooling
if you hear a noise like clicking when the compressor tries to start and unit will not cool the starter overload on the side of the compressor that starts it has burnt out simple replace the starter overload and it should start
Posted on Apr 03, 2010
heatman101
  • 43501 Answers
SOURCE: Fridge not cooling Freezer ok
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 20, 2010
Condenser fan not turning. Placed a house fan behind the fridge and the freezer got cold. But .... fridge not cold. ??
Condenser fans are usually not difficult to replace. Clean the condenser coils, too.
Aug 29, 2015 | Refrigerators
Whirlpool side by side full drip pan
The condenser fan should be running whenever the compresser is running. With all of that condensate, I would look at your door gaskets. If they are leaking and you are in a high humidity area you will produce more condensate than what the pan can Handel. Then again. If the compresser is running the heat from the discharge line should evaporate the water with ease. I would look at the seals possibly leaking and ignore the full drain pan.
Sep 08, 2012 | Whirlpool Refrigerators
Update on whirlpool fridge not freezing meats. Colinnnnn you rock! I replaced the condenser fan motor just before dinner and she's been humming happily and quietly I might add. She used to make a
Hay thanks for the you rock, I appreciate it, and if you ever have any problems again just dig me up and I'll do my est to help Have a good one
My GE fridge PSi23SGNA BS freezer defrosted.
Condenser fan should be about 1300 rpm, I believe!
Jun 13, 2012 | GE Refrigerators
Freezer part not working,fridge ok
The first thing I would do is to check the compressor and the condenser fan. Remove the cover on the back of the fridge and check how hot is the compressor? Is the condenser fan turning well? Also check the condenser coil under the fridge, it is very possible it needs cleaning.
If the condenser fan is not working properly then it has to be replaced
If the condenser fan motor is fine and the cleaning did not help then the sealed system is low on Freon and in such case you need a certified technician to fix a leak and to charge the system.
Good luck.
Aug 15, 2010 | Zanussi ZEBF250W Bottom Freezer...
My fridge light and digital readings turn on and off and the fridge doesn't stay all that cold. My freezer light is always on but the food is not staying frozen. The ice maker isn't making ice.
If the condenser fan is not working properly then it has to be replaced.
Good luck.
Jul 28, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
The center wall of our side by side fridge is hot to the touch, and seems to be getting hotter.
clean the condenser coils. also check the condenser fan motor. ) behind the fridge. bottom part)
Apr 04, 2010 | Whirlpool Refrigerators
Bad fan
The condenser fan - the fan which blows across the coils outside the fridge - should be running any time the compressor is running. If you hear the compressor but don't feel air moving under the unit, then the condenser motor is probably bad. It's not hard to replace. Find a replacement motor at a parts store or website like www.repairclinic.com . Some of the fans come with instructions, but it should be easy to figure out. Just be sure to unplug the fridge before you start.
Sep 07, 2008 | Whirlpool GD5SHAX Side by Side...
Freezer cold but not fridge
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
18 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
