Question about Magic Chef 31000 Gas Kitchen Range
Back burners wont light - Magic Chef 31000 Gas Kitchen Range
  • Magic Chef Master
  • 17,130 Answers
Remove the back burners top lids and using a good blower jet and a good brush clean up the areas around it. this must allow the mixing of the gas properly. try to light. if this wont solve you will need to open the front flow controller, remove the knob, check from within after opening the top lid for the jet screw, open and clean and use a pin for cleaning. reset the flow controller after checking for gas flow into the flow controller. now set back and the burner should light up. Hope this helps you out. Good day
Posted on Jul 14, 2010
Pilot light lights but burners wont light
If this is a stovetop, there are little holes on the side of the burners were the tube from the pilot light goes, they are probably clogged not allowing gas to get to the pilot light to light the burner
Nov 27, 2016 | Heating & Cooling
How to get burner light to go off on Maytag range model5555QAB?
The indicator light is wired directly from the infinite switch (burner switch). This mean one of the switches has a shorted switch. So Did you have an issue with one of the burners? I hope this helps.
Apr 13, 2016 | Maytag Kitchen Ranges
My back burners wont light but my front two will genesis silver edition
If the Cross Over Tube/Burner is clogged, the ignition flame can't get to the last 2 burners to light them. To check this, light the front 2 burners using the ignitor button and try match lighting the back burners. If they match light, that indicates that the Cross Over Tube is clogged. You will need to remove it to clean it properly. Which can be a chore in itself. Be careful removing it, because if it's rusted, it may break.
Hope this helped you, Kevin and thanks for choosing FixYa.
Aug 07, 2011 | Weber Genesis Silver A Grill
Frigidaire professional series gas stove does not light. When handle is turned the "clicking" sound happens, with the smell of gas but no flame. what could be problem? 3 other burners work...
A few months ago I lost one igniter on the left front burner. It clicks and gas flows but wont ignite.Now when I turn on the left back burner, the gas still flows but I hear clicking on the right side, not from that burner. It wont light either.
Dec 17, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Front Burners very low back burners not working
Front 2 burners light properly but back burner does not light. Checked cleaned spider guards, even removed the burner making certain it was clean. Reassembled the back burner but it still does not light.
Jun 23, 2010 | Weber Genesis Gold B Grill
I smell gas and my burners wont light - is there a pilot light in these ranges?
The best way to find out if if your stove has a pilot light, is to lift the top panel of the range . The pilot will usually be located between the burners. Typically you will have two pilots. One for the left and one for the right. The pilot light will ignite with a match without having to turn the burner knobs to the "on" position. Good luck
May 20, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Center and back burners won't light
cross over tube could be out of postion blocked or you need new burner
May 15, 2010 | Weber Genesis Silver B Grill
Top burners often wont light if oven is already lit
I have fix that problem before, the oven heat is soficating the top burners, you will have to adjust top burners with the oven on, so that they will light by them selfs.Or put a shield under the cook top section on the back, so that the heat will not come to the burners where they get the oxigen.
Dec 07, 2008 | GE JGBP28 Gas Kitchen Range
Magic Chef 31000 Gas Kitchen Range Logo
200 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
