Question about HP LaserJet 4700 Printer
I put a refurbished cyane ink cartrage in and I get error. It says it cannot read the ink cartrage take out and put back in. I do that and it still will no work.
  • HP Master
  • 17,130 Answers
It is possible that the cartridge is not getting detected with this action. before you changed the cartridge did you use the maintenance ? the printer need a reset. shut off the PC and the printer. Now switch on and try if the pc is updating. If not click on the printer and open up settings. Do a head cleaning, check if it detects.you can also reinstall the software of the printer. this will reset off any earlier program errror that happened witth wrong method.
Hope this helps? Good day
Posted on Jul 14, 2010
  • HP Expert
  • 222 Answers
your printer cant "read" cartridge E-label
you have to replace it or replace cyane cartridge whit new one
Good Luck!
I have changed the black cartrage but get Error 88/69
1) Remove all ink cartridges, unplug, plug back in,
put all ink cartridges back in--should now work
2) if not, download drivers from epson.con, and install &
then do 1 above again
Jan 23, 2015 | Epson Stylus NX400 InkJet Printer
Inserted new ink cartrage, but printer saying remove tape from the ink cartrage. I've done that but it still say error. Also the not printing correct. I've had the ink cartrage for a while could that be...
Clean the contacts of both the cartridge and the print head with some alcohol. Reinsert the cartridge.
Power off the printer and wait 1 minute. Power if back on and then make it go thru calibration cycle if it
has one.
Mar 23, 2011 | Office Equipment & Supplies
I have a Hp photoshop 3210 printer ink cartrage error empty or
I installed new cartriges, but my printer keeps giving me an error msg, Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: Oxc18a0206. What do I do now?
Nov 06, 2009 | HP Photosmart 3210 Printer
Rx680 epson ink cartridge error
I was changing my cyan cartridge and got this error. I thought for sure it was that cartridge. Tried a few things including pulling them all out and putting them all back in. Didn't work.
Finally, I found a place in the software that showed the info on all the cartridges. Turned out the light cyan was not reading. Took it out and rubbed the contacts with a pencil eraser. Voila! Problem solved.
Sep 21, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Error 1681 more than one Cyan cartridge installed
Dear all,
To fix this problem, first check which ink blinks, then replace it with new one. If this does not fix your problem, here are possibilities: carriage part error, logic board error. Be careful of short circuitry problem in this case. It may harm other electrical part
Regards,
Related Topic at:
Canon Inkjet Printer Forum
Sep 06, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
MP530- Printer issue
Install recommended ink tanks in the correct order MP500 / MP530 / MP800 / MP800R / MP830
Ink Tank Order Install ink tanks in the correct order (from left to right) CLI-8BK (Black) PG-5BK (Pigment Black) CLI-8Y (Yellow) CLI-8M (Magenta) CLI-8C (Cyan) mp500_inktankorder.gif 05sj00141_08_en.gif
Jan 01, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Cyan & magenta ink will not flow + yellow ink full but error message says almost empty
(Use new carts for this procedure because it consumes some ink!)
press menu then start mono (blue copy button) then fourtimes arrow up. machine will be in maintenance mode. press 7 then 6 then 4 then start mono (blue). machine will refresh ink within tubes and print head and do some cleaning. when in mantenance mode again press 7 then 6 then 3 then start mono. machine will do a power cleaning. afterwards leave the mode by pressing 9 then 9. Run a quality test print by pressing ink etc.
If you cant see any mag and/or cyan the ph is clogged or dryed out. It has to be replaced then.
If you can see some of the blocks do the power cleaning (7/6/3)again.
BTW: Do use only DYE ink for all brother printers! The pigment ink will clogg the micro filter infront of the nozzels. When running machine with generic ink print a quality test sheet once a week!
Dec 03, 2007 | Brother MFC 420CN All-In-One InkJet...
Misreads ink tanks: says full ones are empty and there are 2 cyans, etc.
I had the same problem -- error message saying two cyan print tanks installed. Nothing helped (including disconnecting power cord). Then found I had an older cyan print tank still in its pack on hand, Installed that. No further problems. Assume this means print tank giving error is part of a faulty batch so am returning to retailer for refund from Canon.
Oct 24, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
HP LaserJet 4700 Printer Logo
87 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
