Question about Amana Refrigerators
The water filter is just dripping hardly flowing when you try and get any water. I have changed the filter, and have done all the correct prodedures when changing it, but that didn't make any difference to the flow of water. What else can I do?
  • kmcclatc Jul 17, 2010
    Thanks, but I think we have a bigger problem, so I need a technician to look at the fridge. Any suggestions?
  • 11,800 Answers
Check the water pipes, one might have a kink in it that's blocking the flow. Or there's been so much lime accumulation that a pipe has been clogged. Or a valve is closed. The only way to know it for sure is to test everything : start from the pipe that connects the refrigerator to the water main and go from there up to the exit.
Posted on Jul 14, 2010
  • Azrael SRL Jul 17, 2010
    If you're going to call a technician make sure he checks the entire water system, not just the pipes. And while he's there ask him to take a look at everything else, it will be cheaper to fix whatever is broken now, then later.
1992 F350-7.3 4wheel drive is hard to start after changing fuel filter and fuel pump. Why is it hard to start?
indicates fuel leak back and fuel pressure drop
check filter installation for seal not sitting properly, loose fuel line fitting , pump installed correctly (flow wise ), filter installed correctly (flow wise)
air getting in to fuel lines
the thing you are looking for is indicated by the initial hard start but when started runs ok ( good fuel to the engine eventually) and then by the fact that if the engine is allowed to sit for a long period the problem returns meaning that the fuel pressure is not being held
could even be a problem fuel pressure regulator allowing the fuel to bypass ( no pressure =hard starting) then gets enough pressure to run ok but allows that pressure to drain off over time
Oct 29, 2016 | 1992 Ford F350
Water dispenser dripping
Sounds like you have a bad water valve, it is located in back of refrigerator where your water line comes in. Change that and you will stop the leaking.
Jun 27, 2015 | Whirlpool Refrigerators
Jen Air Refrigerator (JCD2290HEW) developed problem with having low water flow at water dispenser and water hammer after changing water filter and depressing water dispenser to remove air. Have changed the...
I understand the correct manufacturers number for the PuriClean II water filter for your refrigerator should be UKF8001 or UKF8001AXX, that you have the correct filter, and you have plenty of water out of the dispenser when the filter is not installed. If all that information is accurate you have 30 pounds or more water pressure (although the minimum is 20 pounds the higher the pressure the better for flow will be), then I would try holding the filter under the faucet to be certain the water flows through the filter without a lot of resistance. If that checks out, I would look for a gasket or some other part from the old filter that is stuck in the filter housing.
Nov 03, 2013 | Jenn-Air Refrigerators
Drinking water dispenser inside my Maytag MFS2561 is dripping.
Hi Bud, welcome to FixYa. To address the water drip problem, I have 2 question's. Have you recently changed the water filter (or done anything else) and can you double check you have correctly posted the entire model number ? Let me know and I'll be glad to continue to help you from there.
Regards,
Macmarkus :)
Nov 03, 2011 | Refrigerators
ICE MAKER NOT WORKING
Good day!!!!
The water filter may be plugged with sediment, or you may have low water pressure. The water pressure for icemakers needs to be at least 40 psi, and up to about 120 psi for proper operation. Water filters need to be changed every six months. If you would like to test your water pressure, we have an Icemaker Water Flow Tester available from our website. This will help you to determine if the water pressure at the supply line is high enough for the icemaker to function properly. To determine if your filter is plugged, look for water both before and after the filter. It may be hard to determine if there is water flowing through the filter. Sometimes it is necessary to pull the filter out of the feed line to see if water is flowing from the exit of the filter into the refrigerator or freezer. You can do this over a bucket to catch any dripping water. Some models have a filter bypass plug to help determine if the filter is clogged. If so, you would remove the filter and replace it with the filter bypass plug. Now test your water flow.
If your refrigerator has a water dispenser, you can hold a large cup or glass under it for 20 seconds. You should have poured about 13-14 oz. of water in that 20 seconds. If the amount is less, try removing the filter and bypassing it. If you now get the 13-14 oz. of water, the filter was clogged and it's time to replace it. If not, you have low water pressure in the line, and your icemaker may not work properly.
On occasion, the water inlet tube will freeze where it enters the icemaker. This can happen because the water is dripping slowly, or the freezer is just set too cold. A hair blow dryer can be used to thaw this, but be careful around the plastic tubing. You don't want it to crack or deform. You may want to turn the thermostat up a little bit if this is a regular occurrence. If you have a constant, regular drip, you may want to invest in a new water fill valve.
Another reason that your icemaker may not be making ice is the bail arm along the side of the icemaker. This arm must be in the lowered position for the icemaker to operate. If the arm is stuck up, it has shut the unit off. This is a safety feature of the unit. Normally, if there's too much ice in the bin, the arm will get stuck in the raised position and keep any more water from entering the icemaker. You must lower the arm to begin making more ice.
I hope this solution will be helpful...
Thanks for using fixya and don't forget to rate and write a testimonial if it is work..
Aug 31, 2011 | Refrigerators
I changed my filter, PUR 4396841 and now it is vibrating when I stop dispensing water. Any suggestions? Do I have it installed correctly?
The vibration is a tiny bit of "water hammer." Previous to your filter change, the water flow was restricted, and therefore incapable of causing water hammer. Now that you've changed the filter, the flow is large enough to cause a little water hammer when you shut off the flow.
How to fix: shut off the flow SLOWLY. Water hammer is caused when the flow of water is shut down quickly. This is just as true with large flows (as in fire engine pump panels), as it is in itsy bitsy
filtered water lines & filter housings.
May 13, 2011 | Whirlpool 4396841 Whirlpool Refrigerator...
Keeps spilling over during brewing
These tanks can't actually be overfilled since all water poured in displaces the exact same amount of water coming out the spout. So, whatever amount of water you pour in, will be the same amount of water that flows to your pot minus the amount absorbed by the coffee grounds and filter.
Your problems sounds like an undersized (Non Bunn) filter, or clogged brew basket. To verify this, try pouring in only half the water for your brew cycle and wait for it to finish dripping, then pour in the rest. If no overflow has occurred, you simply have the wrong type of filter. If overflow begins again, you have a clogged brew basket, since no Bunn can flow too fast for the brew basket to keep up with it.
This is because Bunn filters are manufactured differently than generic store bought paper filters. They will flow faster, brew cleaner and stand up better than normal generic filters.
Remember, Bunn makes their OWN filters for good reason.
They made the first, best paper filters for drip coffee pots, and all others are just generic dioxin gas producing paper.
Mar 05, 2010 | Bunn VPR Coffee Maker
WATER DRIPPING FROM DISPENSER IN DOOR. GE Model TFX20JRBG WH
You are correct. this is actually a faulty inlet valve(dual) assembly. replacing this faulty valve will fix this issue.
Jun 19, 2009 | GE GSH25JFR Side by Side Refrigerator
WATER DISPENSER,
GSH25JSTASS -- I have a one year old ref..Same problem..Ice comes fine, no water. Changed filter..defrosted Freezer compartment. Kept the light ON for a couple of days, .used compressed air to check water tube between water disp to bottom of the freezer. Not frozen...
What could be wrong with this SMART water filter from GE!
Aug 02, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Water leaking at filter
If this is a Pure source 2 filter in the upper right hand side of fridge, Purchase an Electrolux filter bypass, P/N 241944302. This is a empty cartridge that lets water flow without water drip when filter is clogged. Fridgidaire/Electrolux made no bypass in these filters, so when clogged they leak. Plus they NEVER last more than about 30/60 days. If you use the bypass, you will need a separate filter elsewhere such as in water line under sink or behind fridge. Call me at 816-560-8545 if you need more info.
Feb 26, 2008 | Refrigerators
Refrigerators Logo
19 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
