Question about Husqvarna Designer I
My designer I is version 1.52 and i don't know how to updated , can you help me how can i do it?
    Problem Solver:
  • 6 Answers
This link has the update and instructions.
http://www.husqvarnaviking.com/us/402.htm
Hope this helps!
Posted on Jul 26, 2010
Cant embroider on toyota quiltmaster 50
The Quiltmaster 50 can only do free-hand embroidery. Use the darning foot. Set the machine for a satin stitch with a stitch length of 0 and lower the feed dogs. Manually move the hoop to stitch your design. (Trace the design on the fabric and place on a stabilizer if needed. Center the design in an embroidery hoop and move the hoop under the needle. In my limited experience, all fabrics need stabilizers. Some require multiple sheets of stabilizer.)
Personally, I have trouble moving any fabric under the pressure foot. This is mostly a matter of practice. You have to make a lot of scrap piece trials.
This site has the manual for the Quiltmaster 50 (European version): http://www.home-sewing.com/WebRoot/Store/Shops/homesewing/4AAF/95FA/5ED9/1505/56BA/4D44/240A/754B/QUILT50_0020_EFNI_0020__0020_679111-CEA10.pdf . See page 37 (49 of the PDF).
I hope this helps.
(who actually cheats: I either use an embroidery sewing machine or I use a late 1960s Singer Sewing machine with its Monogramming accessory. This has pre-programmed designs on little discs. That's why I don't practice free-hand stitching.)
Jun 15, 2012 | Sewing Machines
I have a HV mega quilter w/ a quiltsewclever. It was in the middle of sewing a design on row 7 of 8 on my log cabin quilt and I got a Y motor failure message on the quiltsewclever screen. Don't know...
Either you have the Y belt too loose or the Y constant in the setup needs to be changed. If you feel your belts are already at a good tension you can adjust your constants. Go into Home-Setup-Constants. There you will adjust the Y axis in increments in 10. Adjust and try again. If you have eliminated the vibration, then you should be free of Y motor failures. Also, I just found out that there is a update from 2.0 to 3.0. Go to Home-Setup-System Info...if you do not see a.) Software Version should be "3.04" b.)MC Firmware: 3.03 then you may want to go to http://www.husqvarnaviking.com/us/18891.htm
and download the PDF's and the QCC Update ZIP File.
Aug 29, 2011 | Husqvarna Viking 1
My Bernina Artista 180E no longer works with updated Windows. Is it possible to upgrade so that I can still use my 180E and not have to buy another machine?
Just use the free download software from Bernina called Artlink. I used it along with a USB to Serial converter cable to connect to the machine. Works wonderfully. Allows me to still use my old Artista designer software if I want to on an older machine and then when I want to actually transfer the designs I use the laptop with the USB cable.
Feb 01, 2011 | Bernina Artista 180
Viking designer se screen is stuck in welcome screen when turned on. update did not help me! my steps: 1turn on Designer SE le and connect to computer. 2install Designer SE 3D embroidery Software...
I purchased my designer se in 2006, and the frozen screen happened for the first time tonight as I was installing fonts on the machine. I did as suggested...got into update mode and installed the latest update and it worked! Thanks so much. I thought I would have to pay a lot of money to have the problem resolved. I am a happy DSE owner.
Dec 04, 2010 | Husqvarna Designer I
The 3-D embroidery system seems to be only compatible with downloading the designs to a floppy disk. I have a Husqvarna Designer I that has a USB port. Is there any way to download designs to an USB...
USB Designer 1s use Disk Manager, just like their floppy disk sisters, but it needs to be Disk Manager USB. New USB Des1s came with this program on a CD, and this software was also included free when a floppy disk Des1 was converted to USB. If you bought your D1 USB new, check the disks that came with it - one should be Disk Manager USB. If you purchased the machine second hand, contact the seller and ask for the program. It is a free standing program and you don't need a dongle. Check your 3D software - you might already have what you need. Open 3D, click down arrow for Accessories (far right-hand side) - what does your Disk Manager say? If it says Disk Manager USB you are okay to go.
I am not 100% sure of this, but I think that maybe the last update for 3D software (version 7.25) might have included Disk Manager USB. Go to the Husqvarna website and make sure your 3D is updated to the latest version.
If none of the above helps you, there is always the cheap cost embroidery software alternatives: Embird or Sew What. I believe they can write to Designer 1 USB sticks now.
Nov 09, 2010 | Husqvarna Viking 1
Re-set computer the language will not stay memorized on the sewing machine tried everything the book suggested.
Hi Michella, How long have you had your Designer 1? Has this problem just started happening? Have you updated to the newest update lately which the last and lasted one for the last Designer 1 meaning before the SE, Ruby & the Diamond which came out here in the last year or two, the update version is 2.24. I've looked at my manual and there isn't really anything but a couple of lines on page 30 under the set tab in the screen menu that tells you anything about the language and next to the language tells you to touch next until you get the language you want then press ok. I turn my machine off and it still shows up in English which is what i.ve always had it set for. Resetting the computer I guess is just turning your sewing machine off & on(which is suppose to recalibrate it's self). If you're setting your language which you didn't say what it was and pressing ok, then when you turn your machine off then on again and it changes then it's probably something you need to go and take it in to your local tech cause it could be a problem with a pc board or something. I myself don't like to do that if I can fix it myself but sometimes it's kind of unavoidable. Let me know if any of this helped. excuse me if I couldn't help further. Maybe we can Google the problem further. Kathy:-)
Aug 22, 2010 | Husqvarna Designer I
Bernina 180 with Firmware 2.08 - can it run DesignerPlus 5 or 6?
You will need to update the software in the machine, to a min of version 3.08 this can be done at BERNINA dealer (usually free of charge) once this is complete you designer will fully be compatible. WHEN YOU TAKE YOUR MACHINE IN TO BE UPDATE DO NOT FORGET TO TAKE THE EMBROIDERY UNIT IN AS WELL AS IT CONTAINS ITS OWN SOFTWARE
Mar 22, 2010 | Bernina Artista 180
I have windows xp with service pack 3. I installed futura software with no problem. When I go into design browser and try to open a document to send to the machine to sew it says "document failed to open"
Make sure your software is updated (Main menu->Help->Live Update) You should get a message "No new updates".
Make sure software supports design format your are trying to open (List of supported formats you will find in the manual).
If your software has the latest version and you are getting this error trying to open a design from older Futura version (extension .fhe), send it to Singer to check it for corruption.
Dec 08, 2009 | Singer CE-200 Quantum Futura Computerized...
Machine does not sew steady or fast...have to pump foot pedal
Machine is slowing down if it has to change the speed. So if design contains a lot of long stitches or not optimized it will be sewn slow. If your software is surely updated to the latest version and still machine is sewing slow then probably you need to optimize your design.
P.S. Software Live Update you can find under "Help" submenu.
Nov 21, 2009 | Singer CE-200 Quantum Futura Computerized...
When I try to open design enhancer I get an error
This error can appear when you attempt to start 4D software. This will happen if you have installed any version 8.0 4D software, and the 4D Embroidery System software that is already installed has a later version than your 4D software.
If you have a CD (or DVD) containing 4D Embroidery System Software for version 8.1 or later, install the update for the 4D Embroidery System found in the Patch folder on the CD (or DVD).
If you have updated your 4D Embroidery System to version 8.1 or later using an update obtained with Smart Update, find the update you have already downloaded and run it again.
If you are unable to find the update, or you are not sure if you have the latest update, use Smart Update to obtain the latest update, as described in CC007.
When you run the update, you may be asked to choose between Modify, Repair and Remove. This selection appears because you have updated on a previous occasion. Choose the Repair option, and this will ensure all your 4D Embroidery System software is updated.
Mar 14, 2009 | Husqvarna Viking 1
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
