Question about Microsoft Windows XP Professional for PC
I wanna resize my drive space. My current drive space/capacity is 40 GB i want to expand it upto 46 GB . I have More Space on Other drive.
  • 524 Answers
Hi...
for resizing you drive you need to reboot your computer using the OS cd. by doing this the content in the C drive may get errasedb ut other remains.
1.put the OS cd and restart the computer
2.it asks boot from CD..??
3.press enter and it strts to boot from the CD
4.follow the steps as it teels you to do.
5.in one step it asks for spillting of drives so slipt as you want and it wil do rthe required set up...
if my answer was usefull please vote me
Posted on Jul 14, 2010
Testimonial: "Hi it is very helpful"
How to expand laptop C partition space?
You can compress the partition/disk to have more space, or you can use an external storage drive.
Sep 23, 2014 | Sony VGN-FS740/W Notebook
My Satellite Pro S200 running XP has a 30gb C drive and 100gb D drive. The computer constantly whines that is low on C drive space. I have moved everything possible to D drive, cleared 2.8gb space a few...
windows - start - control panel - administration - computer administration - hard drive administration - resize your C drive to bigger capacity, but first resize D drive to smaller capacity to free a space for C drive enlarge, then apply setting, reboot, my computer drive C right click - propertis- service - defragmentation and same operation and chek it for errors
Nov 15, 2012 | Toshiba Satellite Pro P300-28L 17-Inch...
MY COMPUTER SAYS NOT ENOUGH DISK SPACE AND THERE IS
2Gb hard drive is no good for storage or much else its very small best off changing it to a much bigger one 120GB or 250GB to be honest this will solve the problem
Feb 11, 2012 | Computers & Internet
Hi, I have WD 1TB Elements SE. When I checked the usage space on the partition after I plug in the drive, it shows a total capacity as 1,000,200,990,720 bytes (931 GB) and it shows 921,753,505,792 bytes...
If you have a 32bit system, it is expected to have miscalculations, a 32 bits can only go up to 4Gb for calculations (that is, 2^32 = 4'294'967'296 bytes) a 64bit system can make calculations to 2^64 bytes this is also why you couldn't copy a file larger than 4Gb in a 32bit operating system...
So, if you are running a 32bit OS, you should expect a discrepancy for the total space of the Hard Drive and the amount it shows (that's the 93Gb you are missing as total capacity).
Another reason why it can show you incorrect calculations are damaged sectors on the hard drive it-self. These will present themselves either as occupied memory or missing memory.
So, you should expect some miss calculations and you can expect some damaged sectors on the hard disk (a external drive spins on and off too often, eventually damaging sectors... its a problem of physical drives).
In the end, your disk might be fragmented, so run a disk analysis and a defragmentation on the disk so it can recalculate.
A note: A disk is like a shelve, you put things where there is space, if you remove things, that space will be open, and if you want to put something there it has to be the exact size or small enough to fit there. This effect, when things are small enough leaves blank spaces unusable, consuming space on the hard drive and making the access of files slower, this is fragmentation. In order to expand your disk life expectancy you should run defragmentations...
To run a defragmentation, go to START, write "Disk Defragmenter", choose your disk and run and analysis and defragmentation.
Jun 24, 2011 | Western Digital Wd Elements Se 1tb...
How to re-join two partitions on one external hard drive?
You cannot. You delete both and then make one partition.
There is software available that will let you resize a partition. (E.g. Acronis Disk Director). In this case you delete one partition and the resize the remaining partition to use the space created.
Most important: Back your data up to another hard disk before making any changes to your disk.
If this helps please vote for my solution.
Oct 01, 2010 | Verbatim External, USB 2.0, 750GB...
I have a SAMSUNG HM320JI (320GB). After loading Windows XP Proffesional, I found that the C Drive only has 116 GB assigned t it and the hard disk proerties (in Device Manager) shows 117 GB in "Unallocated...
To increase the capacity of formatted disk space on your computer, you will need to go to Disk Management. This can be found under the Control Panel, Administrative Tools, and Computer Management. Under the Control Panel's category view, Administrative Tools can be found under Performance and Maintenance.
On the left pane, you will see several options. Disk Management is available under Storage. You will definitely be able to format your unpartitioned space here. However, you may or may not be able to expand your C Drive space with this option, it may end up becoming a D Drive, or another letter of your choosing.
If this does not work to extend your C Drive space and adding a second drive letter is not an option for you, you can either reformat to receive the entire available disk space, or, if you prefer, there is commercial (such as Partition Magic), and potentially free, software available to perform this.
Please let me know if I can be of any additional help. Thanks!
Aug 11, 2010 | Samsung Computers & Internet
How to add free disk space in hard drive?
Use a bootable CD and use partition magic 8.2 program for this purpose. You can change any desired format without data loss and also resize without any data loss. It will work 100% and guranateed beter work.
Good Luck
Dec 01, 2009 | Computers & Internet
My sp0411n my hard disk of capacity 40gb it is showing 5gb space my know reason why it is showing 5 gb space
hi first off what OS (operating system) is installed. Did you install that OS?
If the answer is yes ,did you format and partition your hdd or did you format and create separate partitions and left atleast 30 gb unpartition
Feb 27, 2009 | Samsung (SP0411N) 40 GB Hard Drive
Desperate for C:drive space!!
unfortunatly u cant expand a hard drives allocated space past its original limitations. your only options are to buy a new 2.5'' hard drive, a external hard drive or a cheap secure digital card. u can pick sd card up for around £4 a 1gb.
look in second hand electrical retailers for cheap options.
hope that helps.
kev
Oct 02, 2008 | Acer Aspire 3680 Laptop
C: Drive space issue
Hi Ginnydoll,
You need to used Hard Drive Partition which you can resize your available space by increasing drive C: capacity and decreasing available space in your drive d: capacity without deleting any files on it. And this is not a harmful to your hard drive all your important files are intact in each destination.
If my solutions sounds great please email me for further assistance. diazphi@gmail.com. because it is really hard to demonstrate on this page because there is no features to attached pictures for visual instructions.
best regards,
Philip
Oct 30, 2007 | Acer Aspire 3000 Notebook
Microsoft Windows XP Professional for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
