Question about Refrigerators
Kenmore mini fridge freezes all contents even when set on lowest setting 1
  • Refrigerators Master
  • 1,606 Answers
Your mini has no timer , heater , bimetal . It has to be defrosted manually . The freezing is caused by a bad thermostat . This small aluminum tube is connected to the bottom of the freezer coil . If you can pull out the thermostat body ( piece with the knob ) and look for a small hole where a small screwdriver can be inserted , you may can try turning the inside small screw clockwise to raise the operating temp . If not , replace the mini . Est $100.00 .
Posted on Jul 16, 2010
  • 1,998 Answers
Three things you have to check your defrost timer,your defrost thermostat, and your defrost heater you would need to use a multimeter on all three of these and check for continuity between each side of the terminal ends the one that gives you no continuity is the one that you would need to replace hope this helps
Posted on Jul 14, 2010
Haier minifridge freezing everything
My mini-fridge did a similar thing, until I realized that managed to put on the wrong temperature knob. It was technically backwards. They may have done this to you. I mean, it is a longshot, but try putting it on the highest setting to see if that helps. If it does not, you're most likely dealing with a faulty knob that's not actually changing the settings on the thermostat.
Apr 10, 2014 | Haier Refrigerators
Black and decker mini refridge freezes food on lowest setting
The lower the setting the colder the fridge should be, the dial should be turned to the right. A refrigerator should be kept around 35-36 degrees F
Jan 03, 2012 | Food Processors
Our amana fridge fruit and vegetable bins freeze the contents. Fridge is set at lowest temp.
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 27, 2011 | Refrigerators
Kenmore upright freezer only 3 years old running ,no clicking noise, no ice build up but won't completely freeze although set to 7 (lowest temp)
check door seals, also check vent direction, a dial or lever in fridge, it adjust how much air goes to fridge and freezer
May 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezer temp turned down but still freezing everying
just look for a better fan to buy to prevent the compressor from having problem . thanks.
Feb 15, 2010 | Freezers
Temperature too cold even when on lowest
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Refrigerators
Refrigerators Logo
425 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
