Question about GPS
I have a Wayfinder VT220. I do not have the instructions. I need to re-calibrate as the readings are inaccurate and i dont know how to do that.
2 Suggested Answers
r321567499
  • 74 Answers
SOURCE: inaccurate reading
I'm not sure why you need it calibrated if your Docotor says it's accurate but here is a web site link....
I hope this helps.
http://www.omronhealthcare.com/product/s1-1126-186-manual-monitor
Posted on Dec 25, 2008
Air ride suspension compressor comes on but shuts off before all the way up
Bad pressure sensor is telling compressor inaccurate pressure readings. If fixed value, replace if not, have it reset and calibrated.
Sep 04, 2016 | Cars & Trucks
Echo ecr2 reading wrong distance and speed. have lost manual
It must be re-calibrated to match the outter circumference of the tire. Sit on the bike and measure how far the wheel rolls on one revolution, exactly. Multiply the inches of the circumference by 2.54. This converts the inches into mm and that is the number you use to calibrate the cyclo-computor's basic need. You can probably find the user's manual on the web. Save and keep ALL your instructions in a shoe box or folder. OK?
Dec 31, 2014 | Cycling
Kal equip
what does tack & dwell have to do with CB radios?
Aug 24, 2014 | Radio Communications
How to calibrate omega 1445 bp monitor
My first question is how do you know it's not accurate? I would tee in a digital manometer (measure in mmHg), wrap the cuff around a glass bottle and let the cuff inflate. When it fully inflates the cuff...look at the readings between the monitor and your manometer. If they are within a few digits of one another, I would leave it alone.
Inaccuracies with patient nibp readings are usually related to improper cuff placement on the patient. There's usually a mark on the cuff to indicate where the cuff should be placed in relation to the brachial artery. I believe this unit utilizes oscillatory technology to determine readings and an improperly placed cuff can create inaccurate readings.
May 23, 2014 | Criticare omega 1445 BP Monitor
I am using a UA 767 digital bp monitor, and I am being told it is giving inaccurate readings, so I wondered how to calibrate it. Battery is full, everything else seems to be working, so I was at a loss.
The only way to recalibrate it, is to send it to the manufacturer. Generally, they do not charge for this service (except for shipping it to them). The reason they have to do it, is that they have to certify that the calibration is correct.
Contact the manufacturer before sending it, for any special instructions they may have.
Hope this helped you. Please let me know. Thanks.
Jun 18, 2011 | Lifesource UA 767 Plus Digital Blood...
New Bushnell Backtrack 3 points in the wrong direction most of the time by about 30 - 90 degrees. VERY inaccurate!
Try calibrating the compass by following the instructions in this video
http://bushnell.com/media/Bushnell_BackTrack_Compass_Calibration_Demo.flv
Sep 13, 2010 | Bushnell BackTrack Handheld GPS Receiver
The DEC setting circle on my Konusmotor 90 is not fixed
This is a small equatorial mount. The setting circles are very inaccurate on these small telescopes -- you will NOT be able to find anything in the sky, even if you set them properly. Sorry.
You bought an equatorial mounted telescope which is never recommended for a beginner. However I have posted instructions for aligning the mount on Polaris on my profile page in the TIPS section. Read those instructions. You must first align the scope on the North star in order to use the telescope.
Mar 25, 2010 | Konusmotor 90 (91 x 90mm) Telescope
Does other terminal emulation VT220/VT100 work on WYSE?
vt220 on wyse
Sort of but f3 and f4 wont work and f1 would be ctrl + o
Dec 11, 2008 | WYSE WT3235LE (902032-68) Network Terminal
Inaccurate reading
I hope this helps.
Oct 30, 2008 | Omron Automatic Blood Pressure Monitor w/...
Cobra 29 ltd classic antenna calibration ??
You should not calibrate the antenna before you install it on the car!! the antenna needs to be calibrated on the vehicle that it is going to be on. Type of vehicle, different mounts, and many other variables can change the amount of reflection you will get.
j0hn9999 did a much better job but left some info out.
Take your SWR readings on channel 1, then on channel 40.... NOW, if your SWR is higher on ch 40 then ch 1, then your antenna is too long and it needs to be shortened. Refer to the antenna instructions on how to shorten the antenna.
If your SWR is higher on ch 1 then on ch 40 then your antenna is too short. You must lengthen the antenna. Again refer to your antenna instructions on how to lengthen your antenna.
You must calibrate each time you take a reading.
Make sure your doors and windows are shut when taking a reading
Make sure you are in an open lot when taking a reading as buildings, trees and other structures can cause reflection and give you an inaccurate reading.
If you adjust the length of your antenna on another vehicle and then put it on yours, the SWR will be off. It will need to be tuned again.
An external meter is better then the one in the radio, but will need to be hooked up in the vehicle you have the antenna on.
If you are not running any kind of power, or do not have a swing kit installed, and the radio is stock, the meter in the radio is more then enough to get a correct SWR reading.
Sep 27, 2008 | Cobra 29 LTD CB Radio
GPS Logo
349 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
