Question about Sony NWZ-E438F Digital Media Player
On hold... cancel Hold function to activate
On hold... cancel Hold function to activate controls. how do I do that
  • 455 Answers
This is not an issue with the Walkman player. You can resolve this by sliding the HOLD switch located at the side panel of the Walkman Player (Model specific).
HOLD switch is used to protect the Player against accidental operation. By sliding the HOLD switch in the direction of the ">", all the buttons are disabled. If you slide the HOLD switch to the opposite direction, the HOLD function is released.
Posted on Jul 25, 2010
  • 1 more comment
  • rickterps Aug 26, 2010
    Had the same issue with an nwz-e344 and the hold button was the very obvious solution that unfortunately did not work........any other suggestions to 'cancel hold' when the device is not on hold??
  • sailormoon91 Jan 14, 2011
    I have the same problem!! The buttons on my sony walkman and-344 crashed suddenly while I was listening to music. I've done the boot and it usually connects and everything but the buttons will not work except for the hold. sometimes respond but the volume works like I was moving the buttons to the left and right. do u manage to solve the problem?
  • Sujay V Krishnakumar Sep 15, 2012
    Answer to the question understanding that the person asking is knowledgeable. I have 2 sony Mp3 players. Both have the same issue. When it is not on "Hold", it is on hold. Can't seem to get of the "Hold". Tried resetting, put on Hold and try to release it. It sets back after short time.
I cannot open my ipod 4H506986RSA in my computer when I open the file there is a promt about the I/Q device.
Posted on Aug 18, 2010
5 Suggested Answers
SOURCE: can not cancel HOLD function to activate controls
There is a "Hold" switch on the back of the unit. Just move the switch to the other position.
Posted on Oct 22, 2008
SOURCE: display says
Hey Man, To Solve This All You have to do is look on the left side of the player,(where the silver line is going around the outside), and push the hold switch towards the other direction.
Posted on Sep 14, 2009
  • 30 Answers
SOURCE: cancel hold function on mp3 nw-a808
Hi there you can download the manual here http://support.sony-europe.com/dna/wm/nwvp/nwvp.aspx?site=odw_en_GB&m=NW-A808 which i highly recommend but for quick answer the hold switch is on the back bottom right corner. Merry Xmas!
Posted on Dec 23, 2008
SOURCE: ON HOLD - how do I cancel hold function to activate controls
There should be a "hold" button on the side of the player. Sliding it one direction puts it on hold and sliding it in the other direction takes it off hold.
Posted on Jul 17, 2009
Help have onix split system air con and remote not working and it s the only way to turn it on have tried every where to get one model no is TEM-84CHSBE heat unbearable in summer nth qld aust.
Auto-restart Presetting:
The appliance is preset as no auto-restart function by manufacture. If Auto-restart function is needed, follow the
step below to activate this function:
1) Make sure the Air-con's power is off:
2) Press down and hold the Emergency button (ON/OFF )on the indoor unit then electrify.
3) Keep pressing the Emergency button for over 10 seconds until three short beeps are heard.
The Auto-restart function is then activated. To cancel the Auto-restart function, repeat above procedure until four
Remarks: When remote controller is out of work, open the panel and you can see emergency button there, see the
The emergency button for 50, 70, 90 series is at the top right, see " ON/OFF " button there.
Auto-restart set:
the appliance is preset as no auto-restart function by manufacturer. If Auto-restart function is needed, follow the
below step to activate this function:
1) Make sure the Air-con's power is off .
2) Press down and hold the Emergency button (ON/OFF )on the indoor unit then electrify .
3) Keep pressing the Emergency button for over 10 seconds until three short beeps are heard, then Auto-restart
function is activated. To cancel the Auto-restart function, repeat above procedure until four short beeps are heard.
Oct 31, 2011 | Heating & Cooling
Err68
Hi
Error E68 on Frigidaire dryer means that One of the keys (buttons) is stuck closed (active). Please check whether any button is pressed or stuck. Also try removing the lint filter and clean the contacts of the inside of the filter.
Try performing function test to check which button is at fault. Enter function test mode and perform key (button) test to determine which button is at fault. Carefully free the and perform the test again. If button is free but the key struck code still exists then you'll need to replace the electronic control.
Function Test--
1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound 1 time and “rES” will be shown briefly in the display.
2. Immediately after, rotate cycle selector knob 5 turns counter-clockwise to the second position from the bottom. Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control will enter test mode, the buzzer will sound 3 times and all LED’s will rapidly flash.
To EXIT test mode, press and hold the Select and Cancel buttons simultaneously for 6 seconds or disconnect power from dryer. Dryer will be reset for regular operation.
Please post back for any further assistance.
Daniel
Jul 21, 2010 | Frigidaire GLEQ2152ES Electric Dryer
How to cancel HOLD function to activate controls?
By rotating the HOLD switch in the direction of the arrow given on back side, all the buttons are
inoperable.
If you press buttons while the HOLD function is activated, “HOLD” and the current time appears in the display.
If you rotate the HOLD switch to the opposite position, the HOLD function is released or canceled.
Please rotate the hold switch on the back side of your mp3 player opposite to the arrow mark given there.
Please go through the user manual if you are having any doubts.
manual
Hope this helps you
Thank you
Oct 03, 2009 | Sony Walkman NWZ-B105F MP3 Player
Hi. My Sony MP3 hold function has frozen.
I had a mobile phone that got caught in the rain, it didnt want to know that day. I popped it on a radiator on a towel overnight and it was fine after that.
Dan
Sep 05, 2009 | Sony Walkman NWZ-B105F MP3 Player
Nwz-s639f stuck on hold
try reseting it if theres a way you can. or if theres a hold button
Sep 03, 2009 | Sony Walkman NWZ-B105F MP3 Player
Display says "on hold..cancel HOLD function to activate controls"...how do l do this?
Jul 12, 2009 | Sony Walkman Video NWZ-S618F MP3 Player
Mar 26, 2009 | Sony NWZ-E436F MP3 Player
Cancel hold function on mp3 nw-a808
Dec 23, 2008 | Sony Walkman NW-A808 MP3 Player
Can not cancel HOLD function to activate controls
Oct 07, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Sony NWZ-S615F walkman-trouble
When you hold your MP3 player with the screen facing you, on the left side there is a small button-like "Hold" control which slides up and down. When you slide it down, "hold" is off, and when you slide it up, "hold" is on. Hope that helps you! =D
Sep 22, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Sony NWZ-E438F Digital Media Player Logo
928 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
