Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My macine draines the water but dont want to turn over to spin, what can the problem be?
Having the same problem on 8-year-old one. technician check and suggest to replace the transmission for about $500! junk it and buy a new one is the best solution when it doesn't spin.
Posted on Jul 17, 2010
  • 1,998 Answers
Soundsw like you have a bad clutch on your unit costs about 25 dollars problem is you would have to know how to remove and then reinstallthe entire transmission to replace the clutch heres some instructions on how to get the job done fixitnow.com/.../how-to-replace-the-clutch-in-a-whirlpool-direct-drive-top-loading-washer
hope this helps any problems write me back
Posted on Jul 14, 2010
Leak in washing macine
The most likely place on these to find a leak is the pump
This training MANUAL will hep
May 28, 2010 | Whirlpool LSR7333 Top Load Washer
The water is not draining from the drum during the 'drain and spin' cycle. I tried unplugging for 10 minutes to reset the macine but that did not do anything. It sounds like the pump is running but...
It sounds like you may have a kinked drain hose or an obstruction in the hose coming out of the tub to the pump. The pump filter screen may also be clogged.
Are you getting any error codes?
Mar 20, 2010 | Kitchen Ranges
Washing macine won't drain.
Door switch problem. The switch is either cracked or broken and not registering as closed. If the unit is most likely also not spinning too.
If the unit DOES in fact spin, then the hose is kinked or clogged. But i believe it isn't spinning too.
Replace the door switch.
Mar 14, 2010 | Whirlpool Washing Machines
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Won't spin or drain. Only a hum. Rocky
Ur internal engine if busted u have strap to change for the spinn and chek the outside of ur macine neer her drain to se were is the plug. if not and ur machanie is in the basement see bout the house drain
Nov 19, 2009 | Roper RAS6233KQ Top Load Washer
Will not drain and spin out water i turn the dial to drain and the spinning begins but the water is not emptying into the sink from the rubber drain hose.
well i would have to say its your pump
its either bad or clogged
but i dont have a model number to be more specific
Oct 06, 2009 | Washing Machines
Amana clothes washer alw880qaw
Hi, Check the belt first. Remove the lower front panel and see if the belt is ok. Please let me know if I can assist you further.
Thankx
Vic
May 25, 2009 | Amana ALW880WH Top Load Washer
LG fuzzy Logic 5.5 WF T552
check drain to see if plugged. if it can't spin water out, it will shut down.
Oct 21, 2008 | LG Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
260 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
