Question about Nintendo 64 Console
N64 + A High def TV
I have my Nintendo 64 plugged into a High Def television and when I turn on the system the screen slides up repeatedly but the game still plays.....can anyone help with this problem??
  • 3 Answers
Double check all the connections. Make sure the cables are plugged into the TV's jacks completely (when I first plugged my N64 into my new HDTV, I had to use some force to ensure the cables were in all the way). Maybe swab down the N64's AV port with isopropyl alcohol or glass cleaner using a Q-tip to ensure a good connection.
Be sure that your HDTV isn't trying to do any odd scaling with the N64's image output.
Posted on Jan 02, 2009
    Problem Solver:
  • 13 Answers
Yes. Consult your Nintendo 64 manual or your tv manual for more details.
Posted on May 10, 2008
Picture problem on panasonic Vierra plasma tv
It looks like you are saying standard definition pictures do not cover the screen like HD pictures do. Standard def is formatted 4:3 and high def is 16:9. They are not the same so your high def screen is made to display the not as tall but wider high def picture. In order to fill the screen with the taller and not as wide 4:3 aspect ratio std def picture you must tell the TV to stretch the picture or otherwise fill the screen.The TV will have controls you can exercise for this purpose and you can set it up to always show std def in a particular manner. The alternative, if you want the standard Def picture to look true to form, is to view standard def in Letter Box form. It's appearance will then include black panels on the sides of the picture. So the problem is not with the TV but in accepting older format pictures playing on newer format displays (TVs.)
Mar 11, 2014 | Televison & Video
Can't get HD on my TV. Tried with every cable type but cannot get High Def
2 things have to happen. first, your tv has to be set for the correct resolution, second, You need to be recieving high def from your cable/sat provider.Your tv does not make programming high def, it allows high def.
Mar 10, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
How do you erase memory from the memory pak
  • Plug an N64 controller into the "Player 1" port on the Nintendo 64.
  • 2 Place the N64 Controller Pack into the memory card slot on the Nintendo 64 controller.
  • 3 Insert a Nintendo 64 game into the cartridge slot on the N64.
  • 4 Hold down "Start" on the N64 controller.
  • 5 Turn the Nintendo 64 on via the "Power" switch on the device. After the console loads, the Controller Pack menu will appear on the screen.
  • 6 Release the "Start" button on the N64 controller.
  • 7 Browse through the saves listed, using the N64 controller's directional pad.
  • 8 Highlight the game you want to erase.
  • 9 Select the "Delete" option. The pages that were occupied by the game save will be erased from the Controller Pack.
  • 10 Repeat Steps 7 though 9 until you're finished erasing pages on the Controller Pak. Restart the N64 if you wish to play the game that was inserted into the device, or turn the Nintendo 64 off if you are done using the console.
  • Read more: How to Erase Pages on an N64 Controller Pack ' eHow.com http://www.ehow.com/how_6566153_erase-pages-n64-controller-pack.html#ixzz15ZouU9Pe
    Nov 17, 2010 | Nintendo 64 Console
    Hello i was wondering if the nintendo 64 is compatible with a high def tv? thanks
    Absolutley, just hook up your RCA cables and your power supply, have your TV on the right input, and your good to go.
    Sep 13, 2010 | Nintendo 64 Console
    I have a HIgh Def DLP TV can I hook the 64 up to it.
    All newer TV's will have the old connections, the composite ones (red, yellow, white). So, yes, you will be able to connect your 64 to your TV.
    Good luck.
    Jan 17, 2010 | Nintendo 64 Console
    Tv turns on and has sound but no picture. Only black screen, the menu from the cable or dvd cannot be seen.
    Make sure your using a cable box that is compatible with a high def tv, if your tuning a high def channel and your converter does not support high def, it will only play the sound, no vidio at all.
    Sep 25, 2009 | JVC LT42P789 42 in. LCD TV
    Nintendo 64 to jvc hdtv
    Check all of your plugs, make sure they are clean. Make sure the game that you have inside the system is clean and free of dust as well as the game connector port on the system. Make sure you are on your A/V channel. If all else fails, you ma have to gt a new A/V plug. When I got my Nintendo 64, I tried to plug it in to my TV using the plug that came with it, but it did not work. I soon found that the Playstation 2 A/V cable that I have also has two additional cables to it, and one of them works in the N64 system. So, I tried to play the system with that cable plugged in, and it worked, so I would suggest buying a new A/V cable that works in the N64 system.
    Hope this helps!!!!!
    Please Rate
    Jun 28, 2009 | Nintendo 64 Console
    It works fine with a high def cable, but when i go to connect it to a tv with the audio video cords nothing at all will come up on the screen.
    There are certain settings on the PS3 that has to be changed each time that you switch from High Def to AV. You have to plug both cords in and turn the PS3 on and view the screen with the High Def. You have to go to Settings --> Display Settings --> Video Output Settings
    then follow the instructions.
    Watch this video and it will help you switch from High Def to AV.
    http://www.youtube.com/watch?v=TBqfeIpKm70&feature=related
    Jun 25, 2009 | Sony Playstation 3 (PS3) Console
    The whole screen is shifted 1 inch to the left.
    When in high def and on the PC the formate buttom on the remote is disabled. The formate will have to be done with the high def remote or through the PC. You will have to contact the high def and the PC provider to adjust the format.
    Sep 24, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
    Mitsubishi WS-55807 tv and my x-box 360, no high def
    its under the settings on the xbox system, in the dashboard.
    Aug 08, 2007 | Mitsubishi WS-55807 TV
    Nintendo 64 Console Logo
    568 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
