Question about GE JSP47 Electric Kitchen Range
Start bottom does not work on oven
When I try to turn on oven everything works till I go to hit the start botton
  • 1,998 Answers
And then what happes when you hit the start button does your oven do nothing at all? sounds like a touch pad or control board issue you might want to call a tech they can usually decipher which one it is so you dont buy the wrong one these can get expensive or if you wish to order the part yourself try marcone appliance parts
Posted on Jul 14, 2010
When you push cook time and a time, or just hit the auto 1,2,3,or 4 minutes, it lights up on the display like it is cooking, with the timer till finished going and everything, but it does not actually...
Highly likely your microwave has "failed".
Down inside the microwave is a part called the Magnetron. This is the part, (about the size of your fist), that makes the sound waves to cook the food.
On some models, it can fail, whilst all the other stuff works.
3 possibilities:
1) You need a fuse replaced.
2) You need a capacitor replaced (That part "starts" the magnetron) or
3) you need a new magentron.
In any regard, very often people will not opt to have it repaired, because the labor & parts can cost more than a new Microwave.
God bless your efforts.
Sep 08, 2017 | Jenn-Air JMC8127DD Microwave Oven
The oven does not start
One of the interlock switches is defective or out of adjustment. By pressing the door release you were causing the switches to make or break briefly enough to allow the oven to turn on.
Jun 20, 2010 | Welbilt MR96TW Microwave Oven
None of the bottons work, tried to cancel but off came on.
Ok, will it allow you to reset the clock? That has to be done before you can use the oven.
May 20, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
I do not have a manual and need to know how to set it up and the code for a vizio tv.
On your remote you will find a setup botton and what i want you to do is hit set up then hit the tv botton and hit channal up and do that untell it turns off your tv are the channal if that works it tv botton again and your remote will work other wise in the back of your remote it well tell you a code number and go on line to philips and they will give your your codes for you.
Dec 09, 2009 | Philips Magnavox Learning Universal Remote
I need the code to program my dish network remote for the Polaroid 42 inch LCD television
press and hold the tv botton on you dish remote till all the lights light up release the tv botton it should stay flashing then hit the larger of the two red power bottons next you will need to hit the up arrow one at a time till the tv shuts off when the tv shuts off you then hit the # botton at the bottom you wiil see the tv botton flash your code will then be saved
Dec 02, 2008 | Televison & Video
Viking Wall oven Electric - Botton element doesn't work
there isn't a fuse. if you could confirm you have 240 volts going to the element that would tell you replacing the element should fix your issue
Nov 15, 2008 | Viking VGIC485-6G Gas Kitchen Range
Top broiler working but botton part not
Try changing the oven ignitor.
Nov 13, 2008 | Kitchen Ranges
How to find discontinued Dacor oven part?
Here's a link with a pdf file that lists your part #82810 for $202.31. http://ww1.dacorservice.com/PartsCatalog/docs/Links/2.pdf. The date on the pdf is 6/12/08. You can also locate a dealer or authorized service providor for Dacor applicances at: http://www.dacor.com/Customer-Care/Locate-A-Servicer.aspx. Good luck!
Jul 20, 2008 | Ovens
Everything works... except the heat!
Maybe one of the fuses, get an engineer to look at it, for safety reasons.
Mar 03, 2008 | Kenmore 66469 / 66462 / 66464 Microwave...
Gas oven will not work
No, the broiler does not work either.
Jan 26, 2008 | Kitchen Ranges
GE JSP47 Electric Kitchen Range Logo
125 people viewed this question
Top Kitchen Ranges Experts
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
