The orange light on my hp deskjet f2100 all in one printer is flashing and a message says that theres a problem with the tri colour cartridge but all looks ok and it worked with it before.
  • 263 Answers
SOURCE: deskjet f2100 series
what kind of software did you use or did you just install the printer with the computer drivers i need more info about this problem
Posted on Jan 05, 2008
SOURCE: Paper jam in HP Deskjet
Thank you. Problem solved. Original cause was my inexperience: learning new tricks at age 88 isn't easy. I simply manhandled the paper jam and it worked.
Posted on Jul 04, 2008
SOURCE: HP Deskjet F4180 colour lights flashing and printer offline
don't know what worked -1.i removed the lid and restarted but again same pblm.
2.kept the lid open and in the on condition itself plugged out the power-put it back.now there was error only in one refilled cartridge-reinstalled it-viola! problem solved.
I opine the latter was of greater use than opening the lid
Posted on Aug 17, 2009
don_farr
  • 1011 Answers
SOURCE: orange cartridge keeps flashing after cartridge
Are you using a factory new HP ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Also take a moment and make sure that all of the protective tape coverings have been removed from the cartridge.
Don
Posted on Oct 22, 2009
SOURCE: my hp deskjet f2100 all-in-one
i have a same problem.
and i can't use photo copy features. (Not Responding)
any suggestion??
Posted on Nov 22, 2010
Hp 2050 deskjet printer: colours are confused and orange is printing green.
Try checking you color settings on printer and computer. Also, check your ink cartridge and it's date of manufacture. Sometimes old cartridges behave like that.
Nov 02, 2012 | HP Deskjet 2050 All-in-One Printer
I have 2 hp F2100 printers that will only print in
Problem may be clogged print heads. This not uncommon, especially if printer sat idle for an extended period. If you can see the print heads after removing the ink cartridge you can try cleaning it with a Q-TIP moistened in warm water or alcohol. You can also google "print head cleaning", there are several site that have step by step instruction for cleaning and/or removing the print head. If the head is beyond repair it is cheaper to buy a new printer than have the head replaced.
Mar 16, 2010 | HP Office Equipment & Supplies
Flashing Orange light will not stop printer will not print
THIS IS A CARTRIDGE OR PAPER JAM ERROR.CHECK FOR ANY PAPER STUCK IN THE PRINTER,ALSO TRY REPLACING INK CARTRIDGES
Feb 11, 2010 | HP DeskJet 1220c InkJet Printer
Hi I have exactly the same problem, and can't scan or make copies. I went to HP Online, and tried their advice, which didn't work. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00867129&lc=en&dlc=en&cc=us&product=3177566&rule=25623〈=enHP's solution made me realise it might be a scanner problem. I made a wild guess and kept the cover above the glass panel open. Turn off your printer, lift the cover up and turn on again. The lights should stop blinking and you should be able to scan/copy/print. I guess the cover prohibits the device to scan properly causing the blinking lights. Hope this helps!
Jul 01, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
The orange light flashes even though I have changed the colour cartridge, The printer will not print
change the catr insecting unit and the cable together for it to work well. that the problem
May 23, 2009 | HP DeskJet 940c InkJet Printer
Hp deskjet f2100 problem
ok..remove all printer software first
go to www.hp.com and get fresh drivers for your model and operating system
then reinstall it..
http://tinyurl.com/6qcpgy
Aug 16, 2008 | HP DeskJet F380 All-In-One Printer
HP DeskJet 722c orange ink light flashing
Try changing the color cartridge. Also it is a good idea to clean the electrical contacts if it looks dirty.Use slightly damp(use water only) q-tips .
Hope this helps
Mar 27, 2008 | HP DeskJet 722c InkJet Printer
Orange flashing light on printer
No the ink is not to low you could try removing the ink cartridges and using a soft cloth wipe clean the little gold contacts on the cartridge and also the printer. Is the ink cartridge a original one if not even though the HP software states that there is 20% in there the likely thing is that the cartridge is empty replace and this should be OK.
I hope the first suggestion works for you as will not cost any money.
Thanks J
Jan 12, 2008 | HP DeskJet 930c InkJet Printer
299 people viewed this question
jasbo
jasbo
