Question about Samsung LN26C450 26 in. TV
My 4 year old 26" Samsung hd tv whistles constantly when on stand by - it is ok when actually on and ideas?
  • Samsung Master
  • 8,457 Answers
Take the tv aparts.The board where the power a/c cord plug into.That the power supply board.Take some super glues,put it all around in all those transformers will stop the high voltages air escape in those transformers to make those whistles noises.
Posted on Jul 14, 2010
  • Samsung Master
  • 1,606 Answers
Usually the singing ir whistleing you hear is a capacitor. Usually the ones that go are in the power dection or high voltage as they get worked harder.
They can be easily fixed but you have to identify them first. Your repair shop may be able to figure out which one by the sound. The other way is to actually let it go pop. then they are rather obvious.
What I would suggest is to call a few repair shops and see if they want to track it down when its singing or if they want to wait till it goes out. Sometimes this can take a bit longer to find so they don;t want to spend the time. As well get an estimate before getting it fixed. Know what a replacement is worth just in case. This should be a cheap(ish) fix but depends on what goes out.
So it should be safe until it goes out but may cost more to fix if you let it go as it could do more damage.Or it may cost a bit more to fix if they have trouble finding it. So its one of those can't win for loosin problems. If your repair guy is sharp I'd take it in as soon as I could but wouldn;t worry too much if I couldn;t.
No HD pic on Samsung HP-R5250
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Samsung HP-R5052 50 in. Plasma HDTV
LN-S4695D replacement stand
do you by chance have a pic of your old broken neck? I have a few Samsung pedestals in stock.
Dec 01, 2012 | Samsung LN-S4695D 46 in. LCD HDTV
About four years old Samsung LW26A33W 26 lcd tv (1500 euros) and power went out suddenly while I was watching it. I then had a tech give it a once over and he claims the power supply box should change, and...
We bought a new one. The old one went to basket. The seller gave the new one little bit cheaper.
So its nowadays. Much more rubbish! The way to solving this problem was the baddest way.
Mar 18, 2009 | Samsung LW26A33W 26 in. HD-Ready LCD...
Protron PLTV-26 Television
Here is the number to Spectroniq, which is the manufactor of Protron, you should be able to purchase one from them directly.
1-877-778-8876
Aug 18, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
Mar 21, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
High pitch noise
Hello there, You have to specify where the noise is coming from. Is it coming from the speaker or from the back of the unit. SMPS power supply powering your unit create this kind of noise when some capacitor gone out of their value.
Good Luck.
Jan 26, 2008 | Samsung LW26A33W 26 in. HD-Ready LCD...
Frozen digital screen
Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Dec 21, 2007 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Need help
ensure the tv is in analogue mode, not dtv and turn it off. with the remote: press info then, menu, then mute then power. these buttons need to be pressed sequentially not all at the same time and in quick succession. a menu will appear on the tv. navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button) the tv will reset itself and turn off. turn the tv back on & it'll re tune all its channels. DTV should be working again.
Aug 23, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Samsung LN26C450 26 in. TV Logo
109 people viewed this question
Henry  Thomas
Henry Thomas
