Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Icemaker and water dispenser not working - KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
  • 560 Answers
Replace the water filter located in the upper right rear of the refrigerator section...push up on it and turn it counter clockwise to remove it (looking up at it from below as a reference for the turn direction)
Posted on Jul 14, 2010
Why water to icemaker , none to water dispenser , replaced water inlet valve fghs2655pf1 or 4a32520097
Refrigerator Not Making Ice? Water Inlet Valve Test - Fridge ...
? 2:47
https://www.youtube.com/watch?v=aXIX73EI1Z4
May 15, 2012 - Uploaded by RepairClinic.com
This video demonstrates how to test a water inlet valve on a refrigerator. ... Ice maker or water dispenser not ...
Refrigerator Ice And Water Dispenser Not Working - Repair ...
www.repairclinic.com/...---/Refrigerator-ice-and-water-dispenser-not-wo...
How It Works: Refrigerators · How It Works: Refrigerator Icemakers · How It Works: ... Most Frequent Causes for Refrigerator ice and water dispenser not working.
Nov 18, 2015 | Refrigerators
The water isnt getting thru to the icemaker, i have used a hairdryer on the water valve and still nothing , i even changed out the water valve but alas no water is being pumped thru to the icemaker, what...
Does water dispense through the dispenser ok in the door dispenser??
If yes wate r dispenses through the door ok the problem is going to be with the icemaker itself and its not sending power to the water valve when its supposed to fill so it could make the ice
If water doesnt dispense through the door check that water pressure into valve is sufficent..even if water does dispense what seems to be ok check first that thier is good water pressure into the valve before replacing icemaker
GENE
Sep 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Automatic icemaker stopped working yesterday. No problems before that. Arm is down, no problem with water line, (water still works in dispenser) temp is fine.
there are two solenoids that control water input. One foe the dispenser and one for the icemaker.Its called a double valve
and you have to replace both. even tho the dispenser is working.
Check ice tray for water if it has none pour it full and wait to see if it ejects after it freezes if it does then you probably need th double valve replaced if it don't then probably icemaker replacement
Aug 24, 2010 | Maytag Refrigerators
My refrigerator water dispenser is not working. I
In the back of the refrigerator there is a water inlet valve. It will have three hoses one coming in, two going out. A 1/4 line for the icemaker and a 5/16" for the water dispenser. If your icemaker is working and you dont have water at the door the valve to the water dispenser is faulty, you need to replace the water inlet valve. If neither icemaker or water dispenser is working chek your water supply line
Feb 22, 2010 | Refrigerators
Icemaker works but water doesn't dispense. I have
I think our water will dispense but our tab(arm) came off track and we don't know how to put it back on. Our icemaker works fine but can't see how the arm should be on. Let me know if you have any advice. Thanks, Shelby ~ Ohio
Feb 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jenn-air side-by-side water dispenser leak
Check the fill tube to your icemaker and see if it has ice in it or in the fill cup to the icemaker. Most of the time when this problem happens it is the icemaker spraying the water. It could also be a bad module on the icemaker which can get stuck in the fill position and spray water all over the freezer.
Sep 14, 2009 | Refrigerators
Water dispenser doesn't work
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 12, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Icemaker not working, but water dispenser is
Water valve has separate coils for water to door and to icemaker. If icemaker is cycling the valve is likely the problem.
May 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker not working,water pours from dispenser side
it could be water valve or ice maker that has gone bad.check all connectins to icemaker and tubing to icemaker and water valve.
Mar 20, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
The icemaker stop working on my Whirlpool side by side frig
If there are ice cubes setting in the icemake waiting to be dumped then the icemaker is bad. If the icemake is dry then the water valve is bad. You have one water valve with two solenoids. One works water in the door and the other sends water to the icemaker.
Dec 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
184 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
