Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
Mcculloch electramac ems300s chain is loose how to tighten
Need to tighten the chain how do i do it?
    President:
  • 2,220 Answers
A link to an OM for a similar model follows:
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-MCC1514-6096210915-966993001.pdf
Tension adjustment is on page 10. All chains are adjusted similarly, this one is reasonably complete, the only addition I suggest is to elevate the nose of the bar when adjusting and tightening. Experience tells me adjustments require many fewer tweaks when the nose is elevated.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 14, 2010
Why does my electramac leaks oil
The chain oil feed is a gravity feed and will continue to feed when you put the saw down. Empty the chain oil resoivour when the machine is being stored. or store it in a driptray.
Jul 19, 2014 | McCulloch Electric Chainsaw Final Gear...
Oil leak mcculloch electramac em250 ?
You have a cracked tank, or busted chain oiler. Will have to take apart to view the chain oiler , and check if oil is puddling just under the oil tank. There is some epoxy sealers, or gas tank stop leak material that can possibly repair the busted or leaking oil tank.
Jul 19, 2014 | McCulloch Garden
Tighten chain
Follow the procedure in your owners/service manual. Otherwise, I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Oct 12, 2013 | Mcculloch 16" Electric Chain Saw Mcc3516f
I need a part for a McCulloch EM14E Electramac a bar for the chain
Contact us
User manuals
McCulloch Service
Jan 18, 2012 | McCulloch Garden
I need the owners manual for Electramac EM16 ES electric chainsaw
Without test: http://es.gigabytedownloads.com/signup/mcculloch_electramac_em_16_es.rar
Need register.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 11, 2011 | Garden
Chain comes off mcculloch electramac em250 chain saw
Adjust the chain until you can pull on it and it will come away from the bar but will not hang from the bar. If that does not solve your problem then the chain or drive gear is worn out. If the oiler is not working it is for sure worn out.
Apr 25, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Your chain is too loose or it is worn out. Adjust the tension on the chain. The chain should not hang away from the bar but should be loose enough that you can pull it away from the bar with not much effort. Adjust the tension until it is set correctly.
Apr 25, 2010 | Plumbing
I need to tighten the chain. Is there a way to do
there should be a screw at the back end of the bar.Screw it in to push the bar out ,or forward, thus makeing the chain tighter
Apr 04, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
203 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Matt Olenzek
Matt Olenzek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
