Question about Harman Kardon AVR-630 7.1 Channels Receiver
Hello my reciever has a problem with the mian
Hello my reciever has a problem with the mian front channels (l+r). I just hear crackling and static. The other channels are all ok. This started as an intermitant problem but now it seems permanent. Is there a relay(s) that connect these channels whos contacts have gotten worn out? please advise or provide schematic / part no. If possible. thanks tis
Our fax machine says recieve error and will not recieve faxes
I presume the machine has its own telephone line. Lift the handset and make a telephone call. Can they hear you ok? Can you hear them OK? If both ok then have them ring the fax and you answer it with the handset. Can they hear you ok? Can you hear them ok? or can you hear crackle on the line or any other strange high frequency noises? If you hear these noises then your telephone company will need to clean the line. Thats usually why this problem arises. the SF5100 was Samsungs best fax in my opionion. It did not suffer from any problems except wear and tear like all machines.
Jul 21, 2011 | Samsung SF-5100 Plain Paper Laser Fax
I have been experiencing static noise/crackling from my front left and right speakers just recently. (I have a 5.1 dell system - the front center - attached to the monitor and rear speakers do not emit...
This seems like at cables have gone bad or either the connections in the speakers went bad. Its best to replace them unless you know how to disassemble and re-soder the connections.
Mar 01, 2011 | Dell WL6000 Computer Speakers
Really bad crackling on line cant hear any conversations phone rings ok and dials ok but cant hear anything but crackling
Without the make and model of the phone unit, I would guess you are suffering from interference if you're using a cordless phone system.
If you are, move the base unit to a room that doesn't have appliances, wifi, or computers and check to see if that removes the static.
Jan 12, 2011 | Lands Phones
I have a Sanyo DCTS760 surround system. A couple of weeks ago i got a loud static noise coming from the front left speaker. I tapped gently but forcefully on the top of the reciever cabinet and this ,...
if the left front channel is not working, first test the speaker with the right channel that is working to make sure the speaker is still good.
If the speaker is good, then it means the fuse of the left channel has burnt. Open the receiver and check the left channel fuse.
Good luck.
Jul 21, 2010 | Sanyo Televison & Video
Can not hear anything
Take the cover off, hook the antenna up and turn the unit on. Take a pencil with the eraser end and press around on the circuit board, look for cold solder joints....hope this helps..
May 17, 2010 | Radio Communications
My Harman Kardon AVR 220 reciever's front-right channel isn't working. I have switched the two front speakers and the right speaker works on the left channel so it is not a problem with the speakers or...
if front left is working it is possible u have a dry solder on ur right channel line. try resoldering or if u want to know exactly where dry solder is, shake gently every right channel components and connections. if resoldering does not work it is possible u have a faulty ouput amp for ur right channel. if ur not sure about this i suggest u get it checked by a qualified tech.
Apr 05, 2010 | Harman Kardon AVR 220 5.1 Channels...
Crackling Sound
Not sure what model but there is a coil on some LG LCDs that needs to be replaced on the SMPS.
Jul 01, 2008 | LG 42LB5D 42 in. LCD Television
Crackling Sound
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
Jan 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
My speakers have almost constant crackling noises
Hello, there is no chance that you can fix this problem by replacing speaker wires. Resoldering the output stages as well as area around the microprocesor could be the efficient solution. If you need more info please advice.
Apr 12, 2007 | Sony DAV-BC150 System
Harman Kardon AVR-630 7.1 Channels Receiver Logo
23 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
